led lights
LED Lights
i have put some led lights inside my car power via the fuse box in glove box
but they seem to stay on when i take the key out unless i turn them off myself is there a certain slot i should plug them into?
thanks
You need to find a supply fed from the ignition switch that is only live when the key is turned. Something like the ciggy lighter/accessory socket.
Have you got a multimeter? Makes life a lot easier.
Switched ignition is the purple wire on the 12v outlet socket iirc.
There's an how to guide here which I would assume apply to most interior light setup...
https://www.vxoc.org.uk/forum/Thread-how...ELL-LIGHTS
okay no I don't have a mulitmeter but I will check out that link stigeye thanks
  Happyblue module ambient lights Kdun 1 5,087 9:th-Mar-2019, 10:22:32
  New member - Led lights HarryH 7 8,668 4:th-Jan-2019, 13:55:53
  Astra J GTC Daytime running lights Wanna_be_dj 5 12,310 1:st-Jun-2018, 09:49:33
Last Post: Wanna_be_dj
  Ambience lights gtc Wullie1967 0 3,952 10:th-Mar-2018, 10:24:05
Last Post: Wullie1967
  Astra GTC ambience lights Wullie1967 2 6,076 9:th-Mar-2018, 19:14:13
  Unlocking with lights on Mspencer 10 12,679 21:st-Jan-2018, 20:32:19
Last Post: Hummelshøj
  Licsence plate lights Nathjnz 2 6,058 11:th-Dec-2017, 16:37:25
Last Post: Nathjnz
  Auto Lights Breengin 8 9,630 11:th-Nov-2017, 21:17:42
Last Post: umognog
  Help day time lights andiman t 8 10,041 22:nd-Sep-2017, 07:08:53
Last Post: andiman t
  Fitted rear led lights, now bulb warning issues twinpipes 3 8,166 27:th-Jul-2017, 21:02:41
