time lights day help
Help day time lights
Got a problem with daytime lights. They come on then one works then doesn't then does.
Could be a faulty connection
Is it a daytime lamp with bulb?
Could be also broken filament of the bulb (touching the contact here and there).
Thanks for replying. They are led. That's why I thought they either work or don't.
In this case, it is probably a faulty contact.
Did you fit the LED's yourself? Is there any chance of CANBUS complaining about it? my headlights have been upgraded and the CANBUS isn't friendly so they flicker about from time to time or simply refuse to come on. One side working 90% of the time okay mind.
Fitted myself. Don't interfere with canbus as not on it (so I thought)
If you have a 5dr then the DRL/sidelights and dipped beam are on canbus, however main beam isn't. See helpful list below:
https://www.vxoc.org.uk/forum/Thread-Bul...-reference
Mine is gtc not on can bus going to buy a new set and try that
  Happyblue module ambient lights Kdun 1 4,889 9:th-Mar-2019, 10:22:32
  New member - Led lights HarryH 7 8,234 4:th-Jan-2019, 13:55:53
  Astra J GTC Daytime running lights Wanna_be_dj 5 11,902 1:st-Jun-2018, 09:49:33
Last Post: Wanna_be_dj
  Ambience lights gtc Wullie1967 0 3,810 10:th-Mar-2018, 10:24:05
Last Post: Wullie1967
  Astra GTC ambience lights Wullie1967 2 5,845 9:th-Mar-2018, 19:14:13
  Unlocking with lights on Mspencer 10 12,121 21:st-Jan-2018, 20:32:19
Last Post: Hummelshøj
  Licsence plate lights Nathjnz 2 5,792 11:th-Dec-2017, 16:37:25
Last Post: Nathjnz
  Auto Lights Breengin 8 9,243 11:th-Nov-2017, 21:17:42
Last Post: umognog
  Fitted rear led lights, now bulb warning issues twinpipes 3 7,844 27:th-Jul-2017, 21:02:41
  New lights Nick 2 4,995 11:th-Jun-2017, 22:16:56
Last Post: srea064
