led j older astra drl
LED DRL Older Astra J
Anyone know if I can put led bulbs in my drl's by adding a resistor first something similar to these ?
(22:nd-Sep-2016, 23:53:15)Starie Wrote: Anyone know if I can put led bulbs in my drl's  by adding a resistor first something similar to these ?
I do not think these will be a straight fit. The Astra J are dual filament so you will find 3 wires on it, low, high, ground. Also the sockets itself is not a direct fit to the headlight housing so may find that it will be loose.
you will want to do this
https://www.vxoc.org.uk/forum/Thread-HOW...a-J-5-door
Thank you !!
Do you have any links on where buy all items needed ?
  Astra 1.6 CDTi Turbo Issues P2598 shaky411 1 2,546 12:th-Sep-2021, 15:24:05
  Vxr bumper on 5 door Astra j Sh4rk2007 10 8,102 6:th-Jun-2021, 18:25:04
Last Post: jeniferbitcoin71
  New Battery for Astra J 2013 reg 1.7 diesel Galway11 6 3,598 13:th-May-2021, 11:38:55
  Astra J 1.4T Exhaust help sammpennington 1 3,812 12:th-May-2021, 14:29:50
Last Post: azajus
  Astra j gtc modifications BillyBryan 2 1,904 9:th-May-2021, 17:15:36
Last Post: Spaghetti
  Astra J Fault code reader suggestions Euroshopper 1 2,049 22:nd-Feb-2021, 08:50:12
  Astra j bonnet won't open help Paul in sheppy 2 2,179 17:th-Feb-2021, 13:13:46
Last Post: Paul in sheppy
  Astra J GTC PDC bracket milozic 5 2,517 2:nd-Feb-2021, 09:39:35
  Astra J Rear Bench Seat Clip. MrScottyMan 1 1,834 24:th-Jan-2021, 14:44:22
  Astra J workshop manual Euroshopper 1 1,977 9:th-Jan-2021, 08:09:36
