led headlights
Headlights - LED
Hi guys!
I have changed my OEM headlights from my Astra J, to OEM LED headlights daylight. However, the car give an daylight error. Can this be resolved by updating/change settings of the software?
Best Regards from Portugal!
You need to wire in resistors to stop the errors. It's because a led uses less power than a standard bulb
Like these
http://pages.ebay.com/link/?nav=item.vie...80&alt=web
(24:th-Feb-2016, 16:27:40)bhalay207 Wrote: You need to wire in resistors to stop the errors. It's because a led uses less power than a standard bulb
Like these
Thanks!
Exist another way to do it without the resisters? by changing the car software settings?
Sadly not no. The GTC doesn't have errors but the 5 doors do. I've got LEDs but have to have the resistors fitted.
Have you swapped the whole headlight to an LED headlight or have you just swapped bulb?
(25:th-Feb-2016, 17:15:26)Rusty2009 Wrote: Have you swapped the whole headlight to an LED headlight or have you just swapped bulb?
The whole headlight, also OEM.
Ok in that case I would advise getting a VCI request sent in to GM asking for the software.
They may say no they may allow it.
Request the VCI via the BCM.
Select no programming possible.
What I would put in the comments box is.
Custom has fitted LED DRL/ sidelight headlamps due to a accident of ordering the wrong parts.
Custom is now getting a warning to check bulbs.
Could you please supply a VCI code for the software / calibration files for these headlamps to work error free.
Thank-you.
  Rear light out but works again with headlights Willcbrbikeboy 6 5,132 14:th-Jan-2019, 09:43:44
Last Post: vocky
takir1 (20:th-Jan-2024, 21:23:34)
