wiring reverse camera
Reverse Camera wiring
Hey all
I've ordered a reverse camera to go wit my new head unit (when it arrives) and it requires power from the reverse light itself...Now I already have my reverse parking sensors wired into this reverse power light...So would it cause too much power draw to have the reverse camera wired into this same power cable?
I think the current consumption of camera is max. 150mA .. don'r worry just do it. Smile
Poslano z uporabo Tapatalk
Hahaha I like your style! When my car bursts into flames... Then I'll worry second question... The wire I already have from the reverse lights to the aftermarket parking sensors box I have... Will that be safe to splice into or should I splice right into the source (reverse light power cable) again?
The park sensors (20-200mA) + reverse camera (50-150mA) in worst case around 4W.
It doesn't matter, you can do the splice wherever it is easier for you.
And how much can that reverse wire give out before it becomes an issue? Never been good with electrical stuff! Ha. Okay brill! Thanks for that
I'm actually thinking of disconnecting the sensors as there's no real need for them if you e got a camera
i would not trust a camera alone keep them it can handle both the cam and sensors
Ah ok, thanks mate and there you go Sheppy lol!
Result! Thanks all but yeah after all the effort I went through to fit the parking sensors... I ain't removing them or unplugging them! Hahaha.
If you have a wire 0,5mm2 (square millimetre) it can take almost 8A and 0,75 more than 10A.
Back-up lamp 16W and additional 4W (for park sensor and camera) -> less than 2A.
Wink
more info:
http://www.bnoack.com/index.html?http&&&...rage1.html
Huh...well you learn something new every day! But... What if there is a fuse on the end... That would limit the amount of power that could be drawn wouldn't it?
Nope the fuse is there to protect the device from blowing incase of overload the fuse goes first
Ahhhh well that's orite then ta again all
it's always best to ask mate
  Front PDC wiring diagram milozic 1 8,158 2:nd-Feb-2021, 09:33:19
  No wiring for the interior boot light marcus01 5 9,241 20:th-Dec-2017, 16:48:23
Last Post: rlievens
  Camera Patrick050289 13 12,474 7:th-May-2017, 18:35:26
Last Post: Tonto
  Front facing camera behind the rear view mirror? ellis0896 3 10,143 26:th-Dec-2016, 19:26:43
  Help wiring ambient lighting Daz21 1 7,583 12:th-Sep-2016, 20:14:05
  Reverse bulb upgrade snapshot11 7 10,849 5:th-Jan-2016, 15:09:52
Last Post: DNT
  Wiring Crimping Help sheppy1 15 14,657 3:rd-Jan-2016, 19:05:19
  Rear brake/reverse light sheppy1 4 7,069 19:th-Oct-2015, 21:22:27
Last Post: Nickmagicfingers1981
  Wiring sheppy1 8 9,277 12:th-Apr-2015, 18:25:37
