light reverse brake rear
Rear brake/reverse light
Anyone have any red reverse/brake lights? I have found the one I need on ebay for £40 (£20 for the tinted one) but I'm after the red none tinted version to replace my damaged one and I'll tint it myself with the spray.
The one in the centre of the boot?
(19:th-Oct-2015, 18:28:49)sheppy1 Wrote: Anyone have any red reverse/brake lights? I have found the one I need on ebay for £40 (£20 for the tinted one) but I'm after the red none tinted version to replace my damaged one and I'll tint it myself with the spray.
If your not intrested in the tinted version could you share the listing as i need a tinted one.
@WheelanUK I'm referring to the one in the boot lid itself that houses the brake and reverse light Smile (red version of the one I've popsted below). I've actually found one now for £20 so will buy that if no one here is selling.
@Nick Here's the one I was referring too but if you search "astra j tailgate light" in eBay you'll find tonnes of listings and most are the tinted ones and are cheaper than the red ones Smile
http://www.ebay.co.uk/itm/Genuine-Vauxha...SwNNxWFSD2
Cheers for that. I thought you ment the high level one at the top of the boot.
  Lowering springs identify front rear martinpe68 1 4,146 12:th-Sep-2021, 15:22:37
  Brake pedal sensor learn. Richiew1986 0 3,011 22:nd-Jul-2021, 16:53:31
Last Post: Richiew1986
  Coolant light coming on when coolant is full (new sensor and no leaks) baffling me! Brasseyebaby 3 8,122 2:nd-Feb-2021, 21:12:47
  Astra J Rear Bench Seat Clip. MrScottyMan 1 7,156 24:th-Jan-2021, 14:44:22
  Rear diffuser Elad1962 3 5,257 29:th-Sep-2020, 22:14:18
  BiTurbo Rear Bumper Dudderz 3 6,865 5:th-Jun-2020, 19:49:44
  Rear Bumper PN 13346637 Jonnymac07 1 4,030 13:th-May-2020, 14:56:05
Last Post: paula9568
  Gtc 2017 1.4t 120 front brake disc size Nathan191210 2 8,346 25:th-Apr-2020, 07:41:05
  DPF REGEN LIGHT Starie 113 147,914 19:th-Apr-2020, 21:00:20
Last Post: Multiskilled
Shocked Spanner Light illuminated with engine off Wwood1991 2 5,959 11:th-Feb-2020, 13:01:57
