That looks good to me mate
You need a U4D DAB module.
Thanks Rusty,
- Bracket -> 13263525
thanks!
Bracket yes.
Hi again,
some open questions:
Thanks!
.pdf   dab_sch.pdf (Size: 28.63 KB / Downloads: 30)
.pdf   A11 Radio X1.pdf (Size: 106.77 KB / Downloads: 26)
.pdf   A12 Digital Radio Receiver Control Module X1 (UBT).pdf (Size: 91.44 KB / Downloads: 26)
hoooooray!!
so
so
Please
  DAB retro fit for cars with the CD 400 tucpal 203 111,425 13:th-Mar-2021, 13:20:56
Last Post: Morpheus75
  POWER FOLD MIRRORS retro fit tucpal 121 92,167 19:th-Jan-2020, 09:18:53
  AUTO DIM ANTI DAZZLE REAR VIEW MIRROR retro fit tucpal 72 48,128 4:th-Aug-2019, 18:26:52
Last Post: KKEVANSKK
  USB factory retro fit tucpal 20 26,465 13:th-Jan-2018, 12:12:55
4 User(s) read this thread:
Adi (30:th-Nov-2023, 18:36:23), Big Dave2 (23:rd-Feb-2024, 11:48:57), milozic (11:th-Jun-2023, 21:09:20), giderci (26:th-Feb-2024, 17:11:37)
