to changing temp c f from
Changing temp from F to C
Hi everyone , on the radio display how do I change the outside temp display from Fahrenheit to Celsius
Thanks in advance ....Cheers....
Don't think you can I'll look tomorrow unless some else knows
Hi, it can be done as I`ve  done it before but cant remember how its done , will have a mess about tomorrow and if I sort it I will post how to do it .....that's  if I don't forget again...... (it`s an age thing)....
Lol don't worry mate I forget things all the time and I'm only 31
Sussed it.....1) on the left stalk press the menu button ....2)rotate the stalk to position 1 , 3) scroll to metric and select via the push button on the end of the stalk....hey presto.....the outside temp is shown in Celsius....to go back to Fahrenheit select US.... for some reason Imperial will not change tp fahrenheit....Thanks for your help anyway Rusty.....Cheers...
Thank's for the info sure that will help others out.
Regarding the Fahrenheit it's most likely because in the UK we use Celsius.
  Changing instrument panel? ephumuris 3 5,877 11:th-Jul-2017, 07:39:43
