R/C Astra GTC
Very rare astra gtr remote control car only available to vauxhall
Pick up only from Cheshire
£150 ono
[Image: http://www.vxoc.org.uk/Images/rusty/Dicko%20RC.jpg]
Changing temp from F to C
Hi everyone , on the radio display how do I change the outside temp display from Fahrenheit to Celsius
Thanks in advance ....Cheers....
A/C pressure sensor location
Can someone tell me how to access the a/c  pressure sensor on a 2013 GTC
Brian
VXOC Electrabizz T&C's
Terms
All invoices must be paid in full before item/s are sent or vehicle leaves.
PayPal payments are accepted but paid as gift only, cash is preferred method of payment or bank transfer.
[align=center][color=#1d2129][font=Helvetica, Arial, sans-serif]Due to buying parts for customers and being let down I will now be charging a deposit before a
Failure Code 597, temp only 75 C
Hello
Astra J 2010 1.6 has servivce light on. Can be reseted by Menu button but comes back after 10 minutes. Code reader gives code 597 - related obviously to thermostat. Engine temp does not come higher than 75C, normally about 90C.  Both upper and lower cooler hoses are warm but not hot. Heater and ac works normally (blowing warm air). Runs smoothly all seems to be OK. Please help whether this is typical failure and where to start to fix it. Does this engine have electrical controlled/heate
Zafira c - Shift knob not returning
Hello to all.
I have a 2012 Zafira C (Tourer) and started to have a problem in the shift knob.
The shift drives normally for shifting gears, but the gear does not return to its original position by itself.
Same as this video : https://www.youtube.com/watch?v=5Bx6XjWofEw
Can anyone help, or already had this problem?
IS there an "easy" solution for this?
Thank you
Navi950 retrofit in Zafira C
Hello everyone,
I’m new to the forum and I’m from the Czech Republic. I drive a 2012 Opel Zafira C and I really like this car.
My original Navi 900 stopped working, so I decided to replace it with the Navi 950. I already have the Navi 950 unit, but I read that it needs different microphone wiring. Is that true? What exactly needs to be changed?
I’m not very experienced with retrofits, so I would really appreciate any help or advice. Has anyone here done this upgrade in a Zafira C? Was i
