led fit light plate number lose
Number plate led light lose fit
Hey guys
I ordered some led units from lush lighting before I decided I was getting rid of car and I happens that both bulbs are now no longer working so I went to fit the ones I purchased but for some reason the units are a loose fit.
It said on eBay they we're for my GTC so I'm confused why there's some play in the unit just wondered if anyone else had this problem and some suggestions to getting them in as tight as the original unit.
Got a pic below if people are not sure what Im talking about.
They are slightly smaller do they fall out or anything?
They don't fall out but the feel so loose it's unreal and getting rid of the car or not I just want them to sit tight.
Are you'res like it as I looked at your how to so presuming there the someones
the ones i have are a perfect fit no movement at all
do you have any sticky tabs you could use
Nope
Think halfords would have some ?
I'm thinking that the j 5 door must be a perfect fit but the gtc must just be loose but they said they were for my car so confused.
Wish I just got the bulbs now but after last time getting errors didn't want to waste my money again
give riza from lush a pm and ask him why they dont fit
he may have sent you the wrong ones
but yes you can buy sticky pads from halfords
I'll give the pads go and send him a message and hope for the best.
Cheers fella
What happend to rustys how to seems like it's gone missing ?
Found it my bad
Was gonna say it's still there but it's Tucpal's How-to.
  Coolant light coming on when coolant is full (new sensor and no leaks) baffling me! Brasseyebaby 3 7,683 2:nd-Feb-2021, 21:12:47
  Inlet air pipe gasket part number. Euroshopper 1 3,921 31:st-Dec-2020, 17:23:19
  Check Number Plate Lamp Warning mp21 10 15,123 10:th-Nov-2020, 23:33:17
Last Post: Galway11
  DPF REGEN LIGHT Starie 113 142,502 19:th-Apr-2020, 21:00:20
Last Post: Multiskilled
Spanner Light illuminated with engine off Wwood1991 2 5,682 11:th-Feb-2020, 13:01:57
  Number plates Flick19191 0 2,812 26:th-Sep-2019, 10:54:13
Last Post: Flick19191
  Rear Light Replacement (Need Advice) A.ROD 2 7,292 17:th-Dec-2018, 19:17:48
Last Post: A.ROD
  Help engine light Mspencer 12 16,584 18:th-Mar-2018, 17:17:36
Last Post: Mspencer
  No wiring for the interior boot light marcus01 5 8,863 20:th-Dec-2017, 16:48:23
Last Post: rlievens
  Rear fog light bulb ID jl47 0 5,467 15:th-Dec-2017, 15:24:34
Last Post: jl47
