brake noise??
Brake Noise??
I have a 2012 J, 1.4 Turbo, 28k.
I have had a brake noise for a while, not your usual squealing noise but more of a shim noise, anyway, today I was braking from around 30mph to 0 and I had a loud clicking noise coming from the brake? I wasn't breaking hard, I have no lights etc on the dash but the noise was strange.
I'm going a 10min drive later and will see if its still there and if it is, I'll take all pads out tomorrow for a clean, as they have a lot of meat left on them!
Was wondering if anyone else has had this issue?
Cheers.
we have a good how to here for how to stop brake noise
a good clean usually does the trick also check the piston is not seized
http://www.vxoc.org.uk/forum/Thread-How-...al-Astra-J
try this first
Nice one! I'll get the stuff ordered and do it at the weekend and report back!
it usually works a treat
Cleaned out all the brakes on Monday, man were they dirty! Especially the rears. It has, for now, stopped the brake noise, I'm hoping it doesn't return! Cheers for the advice mate!
On a side note, I realised I'm gonna need new rear pads soon, I know how to fit them etc, its just for when I have the handbrake to do, how do I calibrate it? I have the EPB.
All info should be in here for you mate.
http://www.vxoc.org.uk/forum/Thread-How-...oval-5Door
Nice one! Cheers guys.
  Brake pedal sensor learn. Richiew1986 0 3,032 22:nd-Jul-2021, 16:53:31
Last Post: Richiew1986
  1.4T Engine noise Nathan191210 1 3,920 29:th-Jun-2021, 09:05:07
Last Post: jay2801
  2017 GTC Limited edition - Front wheel noise Nathan191210 4 6,631 12:th-Jul-2020, 07:37:10
  Gtc 2017 1.4t 120 front brake disc size Nathan191210 2 8,397 25:th-Apr-2020, 07:41:05
  Rear brake pads and discs everson38 4 7,026 28:th-May-2019, 10:53:57
  Noise when turning engine off Marc_81 6 9,686 30:th-Jan-2019, 20:46:28
Last Post: Marc_81
Grinding rotating noise from GTC? MattDe123 2 6,433 1:st-Nov-2018, 10:30:33
Last Post: MattDe123
  Jolt when releasing brake on autobox Djones55 3 7,451 21:st-Oct-2018, 10:42:34
Last Post: Canasta
  Clicking noise THOMAS123 1 4,863 16:th-May-2018, 08:06:00
Last Post: rlievens
  Brake bleed nipples? Jake 4 8,852 27:th-Apr-2018, 18:36:07
Last Post: Jake
