wiper nightmare front
Front wiper nightmare
Hi guys,
I'm having an absolute nightmare trying to source replacement wipers for my 60 plate Astra J.
I've had three sets so far, all A585S Bosch Aerotwins.
They have clips as per below, not what my current Bosch wipers have.
They will fit, but they don't clip into place, they just don't slide down enough.
Anyone else had this issue? The box even has my car written on it to say they are a direct fit... Help!
Ps, Tried Vauxhall.. They want £70 for a pair of blades!
i had the bosch wipers they were fine did you push the tab down when you slide them on
i have the origanl ones back on now so i can not check
I did push the tab down yeah, these clips don't look like the Bosch ones I currently have on the car though.
So if you look here..
http://www.ebay.co.uk/gds/What-Wiper-Bla...525/g.html
My car currently has 'Pinch tab' but I keep being supplied with 'Push button'
here are my genuine ones from my 60 plate 5 door
they are push button on my car
can you show me your wiper blade on the car
(8:th-Apr-2015, 09:39:56)tucpal Wrote: here are my genuine ones from my 60 plate 5 door
Hmm,
My wiper arms look identical, I'll get a photo today.
My blades fitted to my car now however are Bosch and have the 'pinch' tab style fitments.
I'll try these blades again later and will take photos too.
Found this pic on another thread, mine only fit in as far as this?
May sound silly but can the fixing be swapped over?
I've not had to change my wipers yet so I've not looked at them.
(8:th-Apr-2015, 10:35:55)Rusty2009 Wrote: May sound silly but can the fixing be swapped over?
That was my next idea, looking at swapping the 'rubber' if needs be. I'd much rather fit a whole new pair of wipers.
in the pic you posted see the very small black tab try pushing that down then push the wiper on
Yeah I've tried that, even tried 'levering' it down with a small screwdriver but even with my full strength they won't clip in. I'll try again tonight & get photos/video
My wiper:
And how far the new one sits in..
I've stripped them down and rebuilt the old ones with the blade from the new. They aren't great & haven't cured the noise I was trying to fix. They make noise when they start the downward sweep once at full reach which is annoying.
Think il try a set of cheap eBay ones.
i got rid of the Bosch wipers for the noise reason
they look exactly like my old Bosch ones apart from the little arm i dont remember that
So do you not get the noise with GM wipers? Il have to check the price on masterfit club.
no i paid the extra and it is high but they are fine noise wise
has anyone on here used any other brands ??
I didn't think the wipers were that expensive, I'm sure my local dealer said they could do them for around £40 for me.
If your dealer is still been crazy on the price front might be worth trying Autovaux
they are £60 crazy
  Retrofit Coolant and Wiper Fluid Sensors sheppy1 13 15,069 2:nd-May-2025, 17:32:02
Last Post: dellpiron
  Retrofit front parking sensors (GTC) pedroc1999 4 5,989 8:th-Apr-2025, 22:18:56
Last Post: johnny77
  Lowering springs identify front rear martinpe68 1 3,955 12:th-Sep-2021, 15:22:37
  Front PDC wiring diagram milozic 1 7,892 2:nd-Feb-2021, 09:33:19
  Front suspension knock????? Sri~mike 10 14,521 22:nd-Dec-2020, 10:21:36
Last Post: M222RJF
  VXR Front Bumper onto a 5dr Bear 2 6,292 3:rd-Oct-2020, 11:48:59
  2017 GTC Limited edition - Front wheel noise Nathan191210 4 6,301 12:th-Jul-2020, 07:37:10
  Gtc 2017 1.4t 120 front brake disc size Nathan191210 2 8,020 25:th-Apr-2020, 07:41:05
  Can You Add Front Fogs to an Astra J? SAMW98SO 2 9,221 10:th-Apr-2020, 13:29:58
Last Post: SAMW98SO
  No sound on indicators, seat belt warning and quiet front parking sensors mpotsb 4 13,401 22:nd-Feb-2020, 19:24:53
Last Post: mpotsb
