automatic headlights
Automatic Headlights
Astra Gtc
Hi just fitted 9012 bulbs from lushlighting which look white and look a lot better , But my Automatic Headlights dont work now any one else had this problem please cheers Clive
They should work mate have put your hand over the light sensor or a bright torch?
I know they auto lights are very weird and don't turn off a lot of the time.
No mate , But since fitted not getting the green light on my dash board either thank you for reply cheers clive
The green headlight symbol that comes up when the lights are on?
The one on the left?
Rusty
The one under the rev counter I think m8 it used to come on when I pushed the high beam stork forward that put it into auto mode thanks again
Do you mean the HBA (high beam assist)? As the auto lights would be done off the light switch and its standard position is auto.
changing the bulbs should have no effect on the auto lights
is the head light switch set to auto ?
Yes m8 going to check again tomorrow bulbs fitted correctly @ try old ones back in thanks again
that is what i would do
Tucpal The switch is always in auto unless you turn the lights on. You can twist it left to switch them off and it spring loaded so goes back to auto.
Tried that and YES it works again thanks a lot !! Next question brought LED number plate lights and they come with a resister I think to stop any error codes they say put them away from the bumper etc because it gets hot . But the all plastic any idea what to do with them I now it sounds silly but should I put some electricians tape round it ? Thanks again I am getting to old for this modding lark
Just need fog lights doing 😀
they look very nice
and check this out
http://www.vxoc.org.uk/forum/Thread-How-...erse-light
i zip tied them to the parking sensor wires i have in the bumper so they dangle down and do not touch the plastic bumper
but Cameron glued the resisters to the led lights
Cheers Thanks again !
Glad it's sorted but so happy I got the xenon & LED as optional extra lol
What drl bulbs you using mate?
  Dipped Headlights queries Michael C 1 782 26:th-Dec-2023, 13:07:38
  Headlights Peterrl 3 2,212 12:th-Jul-2020, 07:26:51
  Astra gtc headlights to Astra j leemallin 2 3,111 14:th-Feb-2019, 15:42:54
Last Post: vjeko::..
  Headlights Mspencer 1 2,223 25:th-Jan-2019, 08:34:00
  LED Headlights Martz66 0 2,181 26:th-Oct-2018, 17:22:01
Last Post: Martz66
  Upgrading my headlights Mspencer 12 6,137 27:th-Sep-2018, 22:49:38
  Automatic worries PPJ82 5 3,909 27:th-Apr-2018, 14:23:01
  Headlights Mspencer 3 3,567 17:th-Apr-2018, 22:14:03
Last Post: Mspencer
  Astra j updated headlights Rmc 10 7,271 5:th-Feb-2018, 11:44:31
Last Post: JETHRO54
  Aftermarket headlights Iaintruten 6 4,374 5:th-Nov-2017, 09:01:07
