led in color of speedometer change
Change of LED color in Speedometer
Hi Mates,
I changed the leds of the uplevel display in my speedometer, but just have a look Grin
[ATTACH=CONFIG]193[/ATTACH]
I have made an instruction in how to disassemble the speedo, but only in german, you can find it here: KLICK
that looks alot better i like that Thumbs
That looks much better been wondering what colour to do mine think White looks really good
Looks great, can you do this to the cd400 screen??
Cameron UK Wrote:Looks great, can you do this to the cd400 screen??
The CD400 screen has about 16 PLCC-2 side LED (same as the interior light).
Rusty2009 Wrote:The CD400 screen has about 16 PLCC-2 side LED (same as the interior light).
Hmmm, the I would want to change all my ambient lighting to white lol
I want to change the colour of the dial surround from white to Red or Blue.
that looks really nice
rusty what SMD has he used for this i want to go ahead with this
i also want white
PLCC-2 side load mate.
cheers mate
i just want the white as the read does not match the NAV display to well
Iam not Rusty (edit: Iam too slow haha), but I can answer your question ;-)
These are PLCC-4
[ATTACH=CONFIG]341[/ATTACH]
Blue circled is for the arrows
Green circled is for the lcd
Red circled is for the dials
thanks i do like what you did there
Jens the greens are PLCC-2 aren't they?
i got the SMD today Plcc 2 and Plcc 4 so i will have the correct one ether way
just need to find the time now and i will get this done soon looking forward to getting rid of the red display now Smile
should have this done at the end of next week Doublethumbs
I did mine last night and it turned out really good. Pic with phone so colors are not 100% to naked eye colors are solid black and white.
[ATTACH=CONFIG]389[/ATTACH]
On my way home i noticed my rev counter doesn't go past 2k and sometimes stays at 0. Hope it's just a bad connection. Also when you desolder old led's be careful not to lift pads. Led's have large contacts so they need to be heated up properly.
well done. Doublethumbs And welcome
i have a day next week were i can find the time to get this done
it may be the needle position may be out of line [MENTION=58]A20DTH[/MENTION] may know how to help.
Hi Mates,
your solder iron should not have more than 350°C, just give the led on the board some solder on both pins.
If done, just heat both pins at the same time with a little more solder so you can move it with the solder iron simply away.
After that just clean the pads.
For the rev counter it sounds like you put it too tight to the ground plate. Check the gap there, must be around 2-3mm.
Yeah need to check that also, it's a pain to remove whole speedo again Sad
Just takes 5min. to get it out ;-)
well i am all set for tomorrow :cool
totally one waste of time today got the speedo out the car took it ll apart and the SMD are not Plcc 4 or Plcc 2
there the ones baz use for the gear gator LED
[Image: PLCC%20003_zpskkzu15w3.jpg]
SO I NEED I LINK FOR THESE IN BLUE
http://www.ebay.co.uk/itm/351305339638?_...EBIDX%3AIT Blue
thanks rusty your a saint Thumbs
Damn that sucks. I hope those blue ebay ones are bright enough.
rusty tried a few and says there better
They are the brightest I've found I did try the orsam ones they were too dim and in sunlight you couldn't read anything.
[MENTION=18]cornishtaz[/MENTION] have you got a pic as you've used the same LEDS.
This is the only one I've got until I sort my laptop out.
Will get some daytime pics
[Image: 20140521_061848_zps6f9efza4.jpg]
that looks better
These are with the cheaper orsam LEDS
[ATTACH]398[/ATTACH]
[ATTACH]399[/ATTACH]
That's on full brightness when the Hit the screen you couldn't see a thing.
Better pic this is with the kingbright leds
[Image: 20150301_110201_zpsoybetat4.jpg]
When can you do mine Baz? Lol looks so much better.
There easy to do once you've got the speedo out
cheers baz they look mush better when they turn up i will get it done this week Smile
it will match my blue NAV display and will be better than red
Its done at last and i am very happy with it
but not an easy job to swap them Tiny SMD,S over but i did it Dance_2
Here is the first few Pictures in the Daylight
i will add a few more later into my Progress Thread Thumbs
[Image: led%20sppeedo%20003_zpslywlmk75.jpg]
[Image: led%20sppeedo%20004_zpstla2invp.jpg]
The Blue SMD are much better and match the NAV display.
Donr mine today need to tweak the needles a little.
[Image: 1.jpg]
[Image: 2.jpg]
They look much better like that. Would have to do everything blue to match now.
Looks like I've started a trend
thanks everyone for all your help i have hated the red display for ages Lol
Hey Tucpal, looks great! I also don´t like the red ones, that´s why mine in white :-)
thanks for the how to it help alot Thumbs
It looks even better at night :cool
[Image: clockv%20002_zpsv1xiqggj.jpg]
Well just an Update Day two still over the Moon with This
I can Drive about now Without the Big Red Display intruding into your Vision when Driving
The Blue is so Shuttle and is Such a Pleasure to look at Without Distracting you like the Red Does,
The Blue is Just Perfect i love it :cool it is so much Better and Less Tacky
I Really do Recommend this. But if you Have the CD400 Display you would have to Change that Also To Match
But with the NAV 500/600 Display you only need the Clock Display Color Changing
Do not forget Cornishtaz can do This in his Trader Section It is Tricky to Do so if you are not Confident give him a Shout.
http://www.vxoc.org.uk/forum/Forum-Cornishtaz-Baz
A20DTH where did you get the white side leds
I got them from ebay germany
http://www.ebay.de/itm/SIDELED-long-life...27dc930081
Hey guys just been looking at some of the posts and have to admit the blue does look good, has anyone done it all blue with white needles? also does anyone know where i can get it done as im not too confident on doing it myself lol
Hey guys just been having a look at some of these and have to say that the blue does look good has anyone changed it to all blue with white needles? also is there anyone that can do it as im not too confident doing it myself haha?
Any help would be great Smile
Cornishtaz does them I've gone all blue but red needles. The problem with white is getting a led bright enough.
Yeah gone with red needles what does yours look like is it any good?
  Window switch LED colour change cornishtaz 41 33,748 10:th-Oct-2020, 16:05:52
Last Post: Jinkie
  How-To GID Colour change umognog 7 12,095 18:th-Feb-2018, 08:58:05
  Gear surround LED colour change cornishtaz 24 29,062 24:th-Jan-2016, 22:24:30
Last Post: cornishtaz
obsidian (27:th-Feb-2025, 12:24:45), N0madd_builds (20:th-Dec-2025, 15:45:44)
Users browsing this thread:
