issue power lighting
Lighting power issue
I've cross posted this from my OP in the tech section as after 3 weeks I've not had a flicker of interest....
Anyone got any ideas.  My 2L cdti has developed an issue that has the fog, reversing and rear right indicator lose power.  The Cambus keeps giving a bulb warning but the bulbs have all been checked and they are all good.  I've also checked the power tracks in the clusters from the cable socket pins to the bulb socket and they are OK too.
This spreads across 3 of the 4 rear clusters and all the other lights not mentioned are OK.  Same time as this I believe, the dash power socket has also failed.  I've gone round all the fuses and they too are a ll good.
I'm guessing this means it's a wiring issue,  potentially a plug somewhere that's maybe come loose?  I don't really have a clue other to start checking connectors etc I can find.
Any ideas on a common denominator?
Tia,
Phlyer Phil
Head In The Clouds
Mind In The Gutter
To anyone who cares, result.  My trials over the circuit diagrams to find a common point all drew a  blank.  Anyway, auto elections went to work, they were initially as baffled as me, but they were able to take it to the next level.
Turns out it was a short on the front power socket and the system had shut off the power to the lights.  Sorted the short out and everything started working again.
Phlyer Phil
Head In The Clouds
Mind In The Gutter
The following 1 user says Thank You to phlyer for this post:
  • bill33
  Wonky lighting and other behaviour umognog 3 8,535 5:th-Jul-2018, 06:52:33
  Lighting problem on exit AlanMac 17 17,520 27:th-Nov-2017, 12:46:03
  Bulbs and lighting upgrades for Astra J and GTC - complete list for reference Rusty2009 71 114,705 25:th-Sep-2017, 07:23:38
  Ambient Lighting Davidog1994 4 9,786 22:nd-Sep-2017, 07:05:38
  Astra j gtc sri lighting problem Quinniain 44 45,176 22:nd-Feb-2016, 10:26:05
Last Post: Quinniain
  lighting again stevie_d 17 19,728 11:th-Feb-2016, 20:17:45
Last Post: cornishtaz
Rusty2009 (5:th-Aug-2025, 19:02:40)
