check lamp plate warning number
Check Number Plate Lamp Warning
Replaced both blown bulbs this morning and are working fine but the "Check Number Plate Lamp" error is still coming on when ignition turned on. Any ideas?
Sometimes it can take a few starts before it goes away as the BCM has the error stored in memory.
if you replaced them with LED bulbs you will get the error.
Cheers for your reply, Rusty, I actually sorted it out. Just in case anyone else comes across this it was due to the wrong bulbs. I used 504 (12V 3W) instead of 501 (12V 5W). Even though the bulbs were both working they weren't drawing enough power and so the management system thought they weren't working.
Glad you sorted it.
Replaced both bulbs with 501's 3 days ago & lights are both working yet error is still coming up on the dash check number plate light ?
Is there any way I can reset?
(18:th-Oct-2020, 19:10:07)Galway11 Wrote: Replaced both bulbs with 501's 3 days ago & lights are both working yet error is still coming up on the dash  check number plate light ?
Did you replace them with halogen bulbs or LED bulbs?
no replaced like for like .... 501 osram halogen
That is very strange then, a couple things you can try.
1. Make sure the contacts are clean and holding the bulb tightly.
2. Remove the battery negative for 1hr+ this will allow all systems to fully shut and reboot once reconnected (which can sometimes solve these errors).
Did you use the correct wattage bulbs? I had some 501's kicking about in my garage but they were only something like 2 watts, and thus I still got the bulb fail warning when I fitted them. IIRC they need to be 5 watt 501's.
I had a similar problem with a front side light when I had an Astra twintop a few years ago, it only seemed to happen this time of year and found out it was condensation on the connectors
Cheers. Problem resolved by taking negative terminal for 1 hr
  Inlet air pipe gasket part number. Euroshopper 1 3,866 31:st-Dec-2020, 17:23:19
  No sound on indicators, seat belt warning and quiet front parking sensors mpotsb 4 13,044 22:nd-Feb-2020, 19:24:53
Last Post: mpotsb
  Number plates Flick19191 0 2,777 26:th-Sep-2019, 10:54:13
Last Post: Flick19191
  Lacking Power - What can I check everson38 3 5,677 10:th-Jul-2019, 10:44:50
  Tyre Pressure Warning Niggle phlyer 4 7,547 23:rd-Mar-2019, 11:39:36
Last Post: andyp
  Replacing door check strap robk999 5 10,089 7:th-Feb-2019, 21:27:33
  Licsence plate lights Nathjnz 2 5,704 11:th-Dec-2017, 16:37:25
Last Post: Nathjnz
  Fitted rear led lights, now bulb warning issues twinpipes 3 7,675 27:th-Jul-2017, 21:02:41
Last Post: Hummelshøj
  Number Plate Lights JJ00 1 4,875 15:th-Feb-2017, 21:57:03
Last Post: Wayneofwolves
  Airbag Warning Message sheppy1 7 11,538 25:th-Sep-2016, 21:23:20
Users browsing this thread:
