clutch j depressed 2013 astra 4 noise 1 when
Noise when clutch 1/4 depressed 2013 Astra J
2013 Astra J SRI 1.7 diesel 130BHP   80K on clock
Engine noise when clutch 1/4 pressed & 1/4 released.
If car in neutral & clutch pressed 1/4 way down the noise is loudest,
Could it be DMF & if so what the cost approx of fitting?
Car running fine otherwise
  Astra J 2014 1.6 petrol, dashboard noise help Steve1982 0 1,022 9:th-Sep-2025, 08:39:49
  Astra J 2014. Electric static noise under dash Steve1982 0 942 8:th-Sep-2025, 21:22:49
  2010 Astra J - Cooling Fan issue Madal101_uk 3 3,932 19:th-Dec-2024, 22:04:08
Last Post: Madal101_uk
Sad Chirping noise Zaf312 1 1,903 7:th-May-2024, 07:34:19
  High pitched noise (Astra OPC J) maximame 0 6,961 24:th-Mar-2021, 08:34:13
Last Post: maximame
  Gear Knob issue (Automatic 2014 Astra GTC) DC23 1 8,124 22:nd-Feb-2021, 08:08:37
  Astra J. Can a tyre valve be replaced without replacing the TPMS? benawhile 2 7,812 5:th-Aug-2020, 12:33:14
Last Post: benawhile
  Astra GTC auto gear knob replacement Jayrich872001 12 31,545 22:nd-Jul-2020, 12:21:46
Last Post: DC23
  Astra J SRI 13 Plate - Radiator Fan Gavin1506 2 6,958 11:th-Jul-2020, 22:08:04
Last Post: Gavin1506
  Astra J 1.6 CDTi increased fuel consumption _Mita 2 11,690 1:st-Mar-2020, 22:27:38
Last Post: _Mita
