sensors oem j parking astra
ASTRA J OEM PARKING SENSORS
Hello.my car havn t parking sensors.i want to put the oem front and rear with button in fash.can help me?i want the oem style from inside to out .thanks!
you will need the module, wiring, sensors and switch.
I have retrofitted the rear sensors and will be retrofitting the fronts at some point this year.
You might need a VCI to make them work, depending on the year of your car
As Vocky has said.
There is no VCI needed for parking sensors on any any Astra-J just module programming.
CAN YOU SAID THE PARTS?
can help somebody with part numpers?i want factory style with small sensors!
(93191445) SENSOR, PARKING PILOT SYSTEM (NLS.- USE 39006734 12 49 104) (PRODUCTION NO. 13242365) RRP £36.90
Or New part number
39006734 SENSOR, SIDE RRP £37.25
Thanks .i want all the part numbers!can help me somebody?after of that i will put and the front as factory if can do that!!!
Hello.can help somebody with the set of part numbers of parking sensors with bottom in dash?
(12:th-Mar-2019, 07:39:06)blacknik Wrote: Hello.can help somebody with the set of part numbers of parking sensors with bottom in dash?
I've given you the parking sensor part number already.
For the button in the dash it depends what else you have on that button.
I HAVEN T NOTHING.ITS EMPTY.I WANT TO PUT ALL THE KIT.YOU SAID ONLY FOR THE SENSORS.THE OTHET PARTS?CABLES?MODULE?ETC!!!!@
(14:th-Mar-2019, 10:53:30)blacknik Wrote: I HAVEN T NOTHING.ITS EMPTY.I WANT TO PUT ALL THE KIT.YOU SAID ONLY FOR THE SENSORS.THE OTHET PARTS?CABLES?MODULE?ETC!!!!@
There is no need to type in full capitals that wont help you get the info you want as it will put peoples backs up as it's considered as shouting on forums.
I'm sorry I saw you asked for sensor part numbers.
As I said in my last post the button depends on what you have fitted, also looms depend on what you have fitted I'm not going to list every single loom as I doubt you will even know which one you would need from the list. Supply your VIN or Reg number and I can find the correct parts needed for your car (if you a UK car) otherwise you would need to go to your dealership and ask if they could help supply you the part numbers.
Hello.can you tell me if you know.because dealr said 2 part kits:
13306620 rear
13365681front.but the sensors have big holes!!
I need to replace one of my parking sensors its part number is 13368131 am I to get the same sensor or are there any other part numbers I can use sounds a dumb question but looking on ebay there are quite a few for the J but not with that number.
Part numbers get superceeded over time.
@Jpbroad1970 can you look into this when you have 5 mins?
As far as I can see you can use 93191445 or 39006734 also, they are the later numbers
thanks for the help appreciate it
  Factory Reverse Camera, Astra j/GTC, insignia tucpal 34 39,731 30:th-Aug-2025, 20:00:16
Last Post: obsidian
Insignia B cluster fitted in Astra J milozic 0 3,872 19:th-Jul-2023, 17:25:46
Last Post: milozic
  Parking sensors, missing switch? carolef1984 2 3,851 2:nd-Jul-2021, 06:12:35
Last Post: carolef1984
  fit reversing camera on astra j gtc tzr608 23 24,299 14:th-Mar-2021, 20:35:53
Last Post: _Mita
  How to retrofit flex floor Astra-J (MK6) 5 Door Rusty2009 11 36,182 18:th-Feb-2020, 08:13:37
  Astra J Sport tourer and OEM rear view camera saarits 47 55,479 26:th-Mar-2019, 23:38:23
Last Post: tzr608
  Retrofit Rear Power point 5 door Astra J Ballinlea 3 15,056 20:th-Mar-2019, 18:13:44
  Astra gtc retrofit foglights Daniel199025 1 6,766 19:th-Jul-2018, 07:32:40
  astra j gtc bluetooth tucpal 19 44,587 18:th-Feb-2018, 12:54:24
Last Post: Dooks
  Astra J 11 Radio Upgrade Dolenc 1 10,204 14:th-Feb-2017, 07:47:16
3 User(s) read this thread:
milozic (31:st-Mar-2025, 19:21:05), Buashei (27:th-Mar-2025, 14:53:05), TonyP (7:th-Dec-2025, 21:30:47)
