pedal creep brake
Brake pedal creep
Just a query those of you with a diesel astra j (mine is a 2.0 auto) have you noticed brake pedal creep where if you sit with the engine running - press the pedal down hard and constantly - do you find slowly the pedal drops to the floor?
I have heard all about vacuum depletion of diesels but as I have never seen this before I was wondering if this was a common characteristic of these cars or I have a servo/ master cylinder problem
Can't say I've noticed on mine
(6:th-May-2017, 16:19:53)Rusty2009 Wrote: Can't say I've noticed on mine
Hmmmm sounds like an expensive bill coming my way. It's interesting as some people have complained of this on the insignia
probably caused by a small vacuum leak in the servo system
(6:th-May-2017, 15:07:27)Kippermcflipper Wrote: Just a query those of you with a diesel astra j (mine is a 2.0 auto) have you noticed brake pedal creep where if you sit with the engine running - press the pedal down hard and constantly - do you find slowly the pedal drops to the floor?
Pedal creep is normal with diesel cars. My 2.0 CDTi also does it.
http://newtyresquick.blogspot.co.uk/2013...creep.html
http://www.brakesint.co.uk/technical.html#techNote202
http://www.nbsbrakesupplies.com.au/techn...edals.html
With the engine off, and the brake pedal pressed a few times, it should then be solid and not creep to the floor if all is ok.
So quite right - the dealer checked it over said it was normal. Apparently it is due to excessive vacuum pulling the pedal down and you'd never have this type of effect in real life. Thanks to all for the responses. Apparently it's apparent on all vauxhall cars since like 2005 odd.
  Astra J manual – pedal box gone? pretty expensive! Mr Writer 5 16,993 9:th-Sep-2021, 14:27:28
Last Post: Gav-Astra
  front brake discs bgb65uk 4 5,022 23:rd-Jul-2020, 10:56:25
  Changing rear brake discs Big Dave2 3 5,122 26:th-Jun-2020, 18:54:19
  Remapping and brake upgrade. Hemihunter 1 4,578 20:th-Nov-2019, 18:24:40
  Changed Brake Pads, now feels like fronts are sticking Vx-Mad-G 5 10,921 25:th-Jul-2018, 15:44:04
Last Post: Vx-Mad-G
Brake light bigsadie 4 6,441 7:th-Oct-2017, 14:31:18
Last Post: Iaintruten
  Pedal test help Jordanclark666 5 9,920 8:th-Dec-2016, 11:06:01
Last Post: Boroboy
  Brake squeal bhalay207 1 5,077 9:th-Aug-2016, 19:43:00
