battery cdti 2 replacement
2.0 cdti battery replacement
The battery on my 2011 2.0 cdti J needs changing so picked one up from ecp, everywhere I have checked have said it's a 100 type battery it needs, but the one from ECP is too short and doesn't fit in the tray fully. Looking at the dimensions online it is 278x17x17cm, but the one in the car at the minute is 310x17x17cm and has a 108 printed on the top. Ive had a look around and the next one is a 110 model which is the correct size but just wanted to make sure or check if anyone else has had the same problem. When ive done a search for insignia batteries it suggests the 110 type. Any help would be grateful.
All aftermarket batteries are smaller in size for some reason although it will still fit.
I've go for the bigger one if your budget can afford it.
I always get a higher rated battery when I have to buy a new one.
You are aware that the tray is adjustable in size aren't you? The end plate that goes against the battery can slot into different positions. It's actually a good idea from GM
I wasn't aware but thanks. I went for the larger one anyways as it was a higher ampage.
  Dead Radio After New Battery Mr_Blogberry 1 527 26:th-Jan-2026, 08:48:09
  VAUXHALL ASTRA 1.7 CDTI FUEL SENDER UNIT 13272601- FUEL ERRATIC GUAGE BELWO HALF TAN caretaker 3 4,279 21:st-Oct-2024, 18:22:15
  Astra 1.6 CDTi Turbo Issues P2598 shaky411 1 7,408 12:th-Sep-2021, 15:24:05
  2.0 CDTi Auto Gearbox Oil Change Dennis S 0 4,050 13:th-Aug-2021, 14:29:25
Last Post: Dennis S
  New Battery for Astra J 2013 reg 1.7 diesel Galway11 6 8,495 13:th-May-2021, 11:38:55
  replacement key fob Qaranc 3 4,501 26:th-Apr-2021, 10:45:13
Last Post: rlievens
  P0135 after bcm replacement Saif.pro 11 8,714 30:th-Jan-2021, 10:20:19
Last Post: Saif.pro
  Astra J GTC 2.0 CDTI A20 DTH Stage 1 Remap - Wayside Performance M222RJF 8 11,024 11:th-Sep-2020, 20:55:21
Last Post: badger64
Sad Astra 1.7 CDTI fuel quality problem klajdi 0 4,060 10:th-Sep-2020, 12:10:05
Last Post: klajdi
  Caliper slide pins replacement? umognog 1 3,773 21:st-Aug-2020, 17:57:50
obsidian (13:th-Oct-2025, 20:51:52)
