Thanks Received: 8 in 8 posts
73
21:st-Feb-2014, 11:48:56
(This post was last modified: 2:nd-Apr-2022, 08:45:34 by Rusty2009.)
Fault Codes
Diagnostic Trouble Code (DTC) List - Vehicle
This master DTC list includes all applicable (B) DTCs in alphanumeric order with descriptors.
[TR]
[TD]DTC[/TD]
[TD]DTC Descriptor[/TD]
[TD]Diagnostic Procedure[/TD]
[/TR]
[TR]
[TD]B0000[/TD]
[TD]Vehicle Speed Information Circuit Invalid Data.........Vehicle Speed Information Circuit Not Plausible[/TD]
[TD]Headlamp Control Module - DTC B0000, C0055, C0246, C1207-C1210, C1221-C1228,
or C1232-C1235
or Radio - DTC B0000[/TD]
[/TR]
[TR]
[TD]B0012[/TD]
[TD]Driver Frontal Deployment Loop Stage *1[/TD]
[TD]DTC B0012[/TD]
[/TR]
[TR]
[TD]B0013[/TD]
[TD]Driver Frontal Deployment Loop Stage *2[/TD]
[TD]DTC B0013[/TD]
[/TR]
[TR]
[TD] B0014
B0015
B0016
B0019[/TD]
[TD]Driver Side Deployment Loop
Driver Seat Belt Pretensioner Deployment Loop
Left Roof Rail Deployment Loop*1
Passenger Frontal Deployment Loop Stage*1[/TD]
[TD]
DTC B0014-B0045[/TD]
[/TR]
[TR]
[TD]B001A[/TD]
[TD]Driver Seat Belt Pretensioner Deployment Loop[/TD]
[TD]DTC B001A[/TD]
[/TR]
[TR]
[TD]B001B[/TD]
[TD]Passenger Seat Belt Pretensioner Deployment Loop[/TD]
[TD]DTC B001B[/TD]
[/TR]
[TR]
[TD]B0020
B0021
B0022
B0023
B0031
B0038[/TD]
[TD]Passenger Frontal Deployment Loop Stage*2
Passenger Side Deployment Loop
Right Roof Rail Deployment Loop*1
Left Rear Side Deployment Loop
Right Rear Side Deployment Loop[/TD]
[TD]
[/TR]
[TR]
[TD]B0051[/TD]
[TD]Battery Cut-Off Deployment Loop[/TD]
[TD]DTC B0051[/TD]
[/TR]
[TR]
[TD]B0052[/TD]
[TD]Deployment Commanded[/TD]
[TD]DTC B0052[/TD]
[/TR]
[TR]
[TD]B0082[/TD]
[TD]Seat Belt Reminder Sensor[/TD]
[TD]DTC B0082[/TD]
[/TR]
[TR]
[TD]B0083
B0084
B0085
B0086[/TD]
[TD]Left Front Impact Sensor
Right Front Impact Sensor
Left Front Side Impact Sensor
Right Front Side Impact Sensor[/TD]
[TD]
DTC B0083-B0088[/TD]
[/TR]
[TR]
[TD]B0158[/TD]
[TD]Ambient Air Temperature Sensor Circuit[/TD]
[TD]DTC B0158[/TD]
[/TR]
[TR]
[TD]B0163[/TD]
[TD]Passenger Compartment Temperature Sensor Circuit[/TD]
[TD]DTC B0163, B0183 or B1405[/TD]
[/TR]
[TR]
[TD]B0173[/TD]
[TD]Upper Left Duct Air Temperature Sensor Circuit[/TD]
[TD]DTC B0173, B0178, B0509, B0514 or B3933[/TD]
[/TR]
[TR]
[TD]B0178[/TD]
[TD]Lower Left Duct Air Temperature Sensor Circuit[/TD]
[/TR]
[TR]
[TD]B0183[/TD]
[TD]Solar Load Sensor Circuit[/TD]
[/TR]
[TR]
[TD]B018A[/TD]
[TD]Windscreen Temperature Sensor Circuit[/TD]
[TD]DTC B018A, B048C, B048F, or B1395[/TD]
[/TR]
[TR]
[TD]B018B[/TD]
[TD]HVAC Condenser Air Deflector Circuit[/TD]
[TD]HVAC Automatic - DTC B018B
or
HVAC Manual - DTC B018B[/TD]
[/TR]
[TR]
[TD]B0193[/TD]
[TD]Front Blower Motor Speed Circuit[/TD]
[TD]HVAC Automatic - DTC B0193
or
HVAC Manual - DTC B0193[/TD]
[/TR]
[TR]
[TD]B0223[/TD]
[TD]Recirculate Position Command*1 Circuit[/TD]
[TD]HVAC Automatic - DTC B0223, B022A, B0233, B023A, B0408, or B0418
or
HVAC Manual - DTC B0223, B0233, B023A, or B0418[/TD]
[/TR]
[TR]
[TD]B022A[/TD]
[TD]Recirculate Position Command*2 Circuit[/TD]
[TD]DTC B0223, B022A, B0233, B023A, B0408, or B0418[/TD]
[/TR]
[TR]
[TD]B0233
B023A[/TD]
[TD]Air Flow Control Circuit
HVAC Actuators Supply Voltage[/TD]
or
[/TR]
[TR]
[TD]B0283[/TD]
[TD]Electric Rear Defrost Circuit[/TD]
[TD]DTC B0283[/TD]
[/TR]
[TR]
[TD]B0408[/TD]
[TD]Main Temperature Control Circuit[/TD]
[/TR]
[TR]
[TD]B0418[/TD]
[TD]Right Temperature Control Circuit.........Main Temperature Control Circuit[/TD]
or
[/TR]
[TR]
[TD]B0468
B0470
B0471
B0472[/TD]
[TD]Auxiliary Heater Coolant Pump Circuit
Auxiliary Heater Coolant Pump Relay Circuit Low Voltage
Auxiliary Heater Coolant Pump Relay Circuit High Voltage
Auxiliary Heater Coolant Pump Relay Circuit Open[/TD]
[TD]HVAC Automatic - DTC B0468 or B0470-B0472
or
HVAC Manual - DTC B0468 or B0470-B0472[/TD]
[/TR]
[TR]
[TD]B048C[/TD]
[TD]Humidity Sensor Humidity Circuit[/TD]
[/TR]
[TR]
[TD]B048D
B048E[/TD]
[TD]Auxiliary Heater Temperature Command Circuit
Auxiliary Heater System Malfunction[/TD]
[TD]HVAC Automatic - DTC B048D or B048E
or
HVAC Manual - DTC B048D or B048E[/TD]
[/TR]
[TR]
[TD]B048F[/TD]
[TD]Humidity Sensor Temperature Circuit[/TD]
[/TR]
[TR]
[TD]B0509
B0514[/TD]
[TD]Upper Right Duct Air Temperature Sensor Circuit
Lower Right Duct Air Temperature Sensor Circuit[/TD]
[/TR]
[TR]
[TD]B0550[/TD]
[TD]Odometer Circuit[/TD]
[TD]DTC B0550[/TD]
[/TR]
[TR]
[TD]B0655[/TD]
[TD]Brake Lamp Switch Circuit[/TD]
[TD]DTC B0655[/TD]
[/TR]
[TR]
[TD]B0685[/TD]
[TD]Security System Indicator Circuit[/TD]
[TD]DTC B0685[/TD]
[/TR]
[TR]
[TD]B071F[/TD]
[TD]Transmission Range Indicator[/TD]
[TD]DTC B071F[/TD]
[/TR]
[TR]
[TD]B0954
B0955
B0956
B0957[/TD]
[TD]Parking Aid Front Sensor Left Corner Circuit
Parking Aid Front Sensor Left Middle Circuit
Parking Aid Front Sensor Right Middle Circuit
Parking Aid Front Sensor Right Corner Circuit[/TD]
[TD]
DTC B0954, B0955, B0956, or B0957[/TD]
[/TR]
[TR]
[TD]B0958
B0959
B0960
B0961[/TD]
[TD]Parking Aid Rear Sensor Left Corner Circuit
Parking Aid Rear Sensor Left Middle Circuit
Parking Aid Rear Sensor Right Middle Circuit
Parking Aid Rear Sensor Right Corner Circuit[/TD]
[TD]
DTC B0958, B0959, B0960, or B0961[/TD]
[/TR]
[TR]
[TD]B0967
B0968[/TD]
[TD]Parking Aid On/Off Switch Circuit
Parking Aid On/Off Switch Indicator Circuit[/TD]
[TD]DTC B0967 or B0968[/TD]
[/TR]
[TR]
[TD]B096A[/TD]
[TD]Hazard Lamps Switch Backlight Circuit Short to Ground[/TD]
[TD]DTC B096A[/TD]
[/TR]
[TR]
[TD]B097D[/TD]
[TD]Transmission Sport Mode Indicator Circuit[/TD]
[TD]DTC B097D[/TD]
[/TR]
[TR]
[TD]B097F[/TD]
[TD]Transmission Tow Mode Indicator Circuit[/TD]
[TD]DTC B097F[/TD]
[/TR]
[TR]
[TD]B0984
B0985[/TD]
[TD]Left Headlamp Light Distribution Shutter Control Circuit
Right Headlamp Light Distribution Shutter Control Circuit[/TD]
[TD]DTC B0984 or B0985[/TD]
[/TR]
[TR]
[TD]B0987[/TD]
[TD]Vehicle Direction Camera Indicator Circuit[/TD]
[TD]DTC B0987[/TD]
[/TR]
[TR]
[TD]B0988[/TD]
[TD]Vehicle Direction Camera Control Module Malfunction[/TD]
[TD]DTC B0988[/TD]
[/TR]
[TR]
[TD]B1000[/TD]
[TD]Electronic Control Module[/TD]
[TD]DTC B1000[/TD]
[/TR]
[TR]
[TD]B1001[/TD]
[TD]Option Configuration.........SDM Option Configuration Error[/TD]
[TD]DTC B1001
or
Inflatable Restraint Sensing and Diagnostic Module (SDM) - DTC B1001[/TD]
[/TR]
[TR]
[TD]B1015[/TD]
[TD]Vehicle Identification Number Information Malfunction[/TD]
[TD]DTC B1015[/TD]
[/TR]
[TR]
[TD]B1019[/TD]
[TD]System Configuration Error[/TD]
[TD]DTC B1019[/TD]
[/TR]
[TR]
[TD]B101D[/TD]
[TD]Electronic Control Module Hardware[/TD]
[TD]DTC B101D[/TD]
[/TR]
[TR]
[TD]B101E[/TD]
[TD]Electronic Control Module Software[/TD]
[TD]DTC B101E[/TD]
[/TR]
[TR]
[TD]B1020[/TD]
[TD]Auxiliary Electronic Control Module Performance[/TD]
[TD]DTC B1020[/TD]
[/TR]
[TR]
[TD]B1023[/TD]
[TD]Integral Switch Malfunction[/TD]
[TD]NO DTC Info at this time[/TD]
[/TR]
[TR]
[TD]B1025
B1035
B1045
B1055[/TD]
[TD]Left Front Audio Output Circuit
Right Front Audio Output Circuit
Left Rear Audio Output Circuit
Right Rear Audio Output Circuit[/TD]
[TD]
DTC B1025, B1035, B1045, or B1055[/TD]
[/TR]
[TR]
[TD]B1259[/TD]
[TD]Aerial Ground Circuit[/TD]
[TD]DTC B1259[/TD]
[/TR]
[TR]
[TD]B125A[/TD]
[TD]Antenna Signal Circuit Short to Ground
Antenna Signal Circuit Open[/TD]
[TD]DTC B125A[/TD]
[/TR]
[TR]
[TD]B1265[/TD]
[TD]Switched 14V[/TD]
[TD]DTC B1265[/TD]
[/TR]
[TR]
[TD]B1271[/TD]
[TD]Theft Protection Active[/TD]
[TD]DTC B1271[/TD]
[/TR]
[TR]
[TD]B1278
B1279[/TD]
[TD]Left Auxiliary Input Signal Circuit
Right Auxiliary Input Signal Circuit[/TD]
[TD]DTC B1278 or B1279[/TD]
[/TR]
[TR]
[TD]B1287[/TD]
[TD]Amplifier Control Signal Circuit[/TD]
[TD]DTC B1287[/TD]
[/TR]
[TR]
[TD]B1295[/TD]
[TD]Steering Wheel Controls Group 2 Signal Circuit High Voltage[/TD]
[TD]DTC B1295[/TD]
[/TR]
[TR]
[TD]B1325[/TD]
[TD]Device Power Circuit[/TD]
[TD]DTC B1325[/TD]
[/TR]
[TR]
[TD]B1370
B1380[/TD]
[TD]Control Module Ignition On and Start Circuit
Control Module Ignition Accessory Circuit[/TD]
[TD]DTC B1370-B1379, B1380-B1389, or B1440-B1443[/TD]
[/TR]
[TR]
[TD]B1395[/TD]
[TD]Control Module Voltage Reference Output Circuit[/TD]
[/TR]
[TR]
[TD]B1405[/TD]
[TD]Control Module Voltage Reference Output*2 Circuit[/TD]
[TD]HVAC Control Module - DTC B0163, B0183, or B1405
DTC B1405
Parking Assist Control Module - DTC B1405[/TD]
[/TR]
[TR]
[TD]B1441[/TD]
[TD]Control Module Ignition Off, Run and Start Circuit[/TD]
[/TR]
[TR]
[TD]B1445[/TD]
[TD]Control Module Voltage Output Circuit[/TD]
[TD]DTC B1445[/TD]
[/TR]
[TR]
[TD]B144A[/TD]
[TD]RUN Power Relay Circuit[/TD]
[TD]DTC B144A[/TD]
[/TR]
[TR]
[TD]B144B[/TD]
[TD]Run/Crank Power Relay Circuit[/TD]
[TD]DTC B144B[/TD]
[/TR]
[TR]
[TD]B1461
B1462[/TD]
[TD]Left Headlamp Horizontal Motor Circuit
Right Headlamp Horizontal Motor Circuit[/TD]
[TD]DTC B1461 or B1462[/TD]
[/TR]
[TR]
[TD]B1480[/TD]
[TD]Battery Rundown Protection Circuit[/TD]
[TD]DTC B1480[/TD]
[/TR]
[TR]
[TD]B1516[/TD]
[TD]Battery Current Sensor[/TD]
[TD]DTC B1516[/TD]
[/TR]
[TR]
[TD]B1517[/TD]
[TD]Battery Voltage[/TD]
[TD]DTC B1517[/TD]
[/TR]
[TR]
[TD]B151A[/TD]
[TD]Low Battery Capacity Detected[/TD]
[TD]DTC B151A[/TD]
[/TR]
[TR]
[TD]B151D[/TD]
[TD][/TD]
[TD]DTC B151D[/TD]
[/TR]
[TR]
[TD]B1527[/TD]
[TD]High Parasitic Load Detected[/TD]
[TD]DTC B1527[/TD]
[/TR]
[TR]
[TD]B1529[/TD]
[TD]Control Module Voltage Reference Output*5 Circuit[/TD]
[TD]DTC B1529[/TD]
[/TR]
[TR]
[TD]B1925
B2170[/TD]
[TD]Driver Seat Cushion Heater Sensor Circuit
Passenger Seat Cushion Heater Sensor Circuit[/TD]
[TD]DTC B1925 or B2170[/TD]
[/TR]
[TR]
[TD]B2345[/TD]
[TD]Seat Heater Disable Circuit[/TD]
[TD]DTC B2345[/TD]
[/TR]
[TR]
[TD]B2425[/TD]
[TD]Driver Seat Cushion Heater Circuit[/TD]
[TD]DTC B2425 or B2430[/TD]
[/TR]
[TR]
[TD]B242A[/TD]
[TD]Seat Heaters Common Circuit[/TD]
[TD]DTC B242A[/TD]
[/TR]
[TR]
[TD]B2430[/TD]
[TD]Passenger Seat Cushion Heater Circuit[/TD]
[/TR]
[TR]
[TD]B2462[/TD]
[TD]Global Position System Signal[/TD]
[TD]DTC B2462[/TD]
[/TR]
[TR]
[TD]B2470[/TD]
[TD]Mobile Phone Aerial Circuit[/TD]
[TD]DTC B2470[/TD]
[/TR]
[TR]
[TD]B2485[/TD]
[TD]Wireless Communication Aerial[/TD]
[TD]DTC B2485[/TD]
[/TR]
[TR]
[TD]B2501[/TD]
[TD]Horn Switch Stuck[/TD]
[TD]DTC B2501[/TD]
[/TR]
[TR]
[TD]B2515[/TD]
[TD]Steering Column Lock Motor Feedback Circuit[/TD]
[TD]DTC B2515[/TD]
[/TR]
[TR]
[TD]B2530[/TD]
[TD]Front Fog Lamps Control Circuit[/TD]
[TD]DTC B2530[/TD]
[/TR]
[TR]
[TD]B2540[/TD]
[TD]Rear Fog Lamps Control Circuit[/TD]
[TD]DTC B2540[/TD]
[/TR]
[TR]
[TD]B2545[/TD]
[TD]Reverse Lamps Control Circuit[/TD]
[TD]DTC B2545[/TD]
[/TR]
[TR]
[TD]B255F[/TD]
[TD]Interior Door Handle Backlight Circuit[/TD]
[TD]DTC B255F[/TD]
[/TR]
[TR]
[TD]B2570[/TD]
[TD]Trunk Lamp Control Circuit Short to Ground[/TD]
[TD]DTC B2570[/TD]
[/TR]
[TR]
[TD]B2575[/TD]
[TD]Left Headlamp Control Circuit[/TD]
[TD]DTC B2575 or B2699[/TD]
[/TR]
[TR]
[TD]B257A[/TD]
[TD]Headlamp Switch Input Signals[/TD]
[TD]DTC B257A[/TD]
[/TR]
[TR]
[TD]B257B[/TD]
[TD]Lighting Control Switch Signal[/TD]
[TD]DTC B257B[/TD]
[/TR]
[TR]
[TD]B2580[/TD]
[TD]Main Beam Control Circuit[/TD]
[TD]DTC B2580[/TD]
[/TR]
[TR]
[TD]B2585[/TD]
[TD]Park Lamps Control Circuit[/TD]
[TD]DTC B2585 or B3867[/TD]
[/TR]
[TR]
[TD]B258A[/TD]
[TD]Low Beam Control Circuit[/TD]
[TD]DTC B258A[/TD]
[/TR]
[TR]
[TD]B2590
B2595[/TD]
[TD]Low Cornering Lamp Circuit
Right Cornering Lamp Circuit[/TD]
[TD]DTC B2590 or B2595[/TD]
[/TR]
[TR]
[TD]B259A
B259B[/TD]
[TD]Left Cornering Lamp Relay Control Circuit
Right Cornering Lamp Relay Control Circuit[/TD]
[TD]DTC B259A or B259B[/TD]
[/TR]
[TR]
[TD]B260B
B260C[/TD]
[TD]Left Daytime Running Lamp Relay Control Circuit
Right Daytime Running Lamp Relay Control Circuit[/TD]
[TD]DTC B260B or B260C[/TD]
[/TR]
[TR]
[TD]B260D
B260E[/TD]
[TD]Left Daytime Running Lamp and Front Park Lamp Control Circuit Short to Ground
Right Daytime Running Lamp and Front Park Lamp Control Circuit Short to Ground[/TD]
[TD]DTC B260D or B260E[/TD]
[/TR]
[TR]
[TD]B2610[/TD]
[TD]Passenger Compartment Dimming*1 Circuit[/TD]
[TD]DTC B2610[/TD]
[/TR]
[TR]
[TD]B2615[/TD]
[TD]Passenger Compartment Dimming*2 Circuit[/TD]
[TD]DTC B2615[/TD]
[/TR]
[TR]
[TD]B2625[/TD]
[TD]Display Dimming Pulse Width Modulation Output Circuit[/TD]
[TD]DTC B2625[/TD]
[/TR]
[TR]
[TD]B2652[/TD]
[TD]Passenger Compartment Dimming 3 Circuit Short to Ground[/TD]
[TD]DTC B2652[/TD]
[/TR]
[TR]
[TD]B2699[/TD]
[TD]Right Headlamp Control Circuit[/TD]
[/TR]
[TR]
[TD]B270A[/TD]
[TD]Park Lock Solenoid Control Circuit[/TD]
[TD]DTC B270A[/TD]
[/TR]
[TR]
[TD]B2745[/TD]
[TD]Traction Control Switch Circuit[/TD]
[TD]DTC B2745[/TD]
[/TR]
[TR]
[TD]B2897[/TD]
[TD]Steering Column Lock Motor Lock Circuit[/TD]
[TD]DTC B2897[/TD]
[/TR]
[TR]
[TD]B2910[/TD]
[TD]Steering Column Lock Password Incorrect[/TD]
[TD]DTC B2910[/TD]
[/TR]
[TR]
[TD]B291B[/TD]
[TD]Content Theft Deterrent Sensor[/TD]
[TD]DTC B291B[/TD]
[/TR]
[TR]
[TD]B2955[/TD]
[TD]Security Sensor Data Circuit Malfunction[/TD]
[TD]DTC B2955[/TD]
[/TR]
[TR]
[TD]B3006[/TD]
[TD]Bonnet Ajar Circuit[/TD]
[TD]DTC B3006[/TD]
[/TR]
[TR]
[TD]B3031[/TD]
[TD]Security Controller In Learn Mode Malfunction[/TD]
[TD]DTC B3031[/TD]
[/TR]
[TR]
[TD]B3055[/TD]
[TD]No Transponder Modulation or No Transponder Malfunction[/TD]
[TD]DTC B3055[/TD]
[/TR]
[TR]
[TD]B305A[/TD]
[TD]No Response From Steering Column Lock Received[/TD]
[TD]DTC B305A[/TD]
[/TR]
[TR]
[TD]B3060[/TD]
[TD]Unprogrammed Transponder Identification Code Received Malfunction[/TD]
[TD]DTC B3060[/TD]
[/TR]
[TR]
[TD]B3101[/TD]
[TD]Keyless Entry Data Link Circuit[/TD]
[TD]DTC B3101[/TD]
[/TR]
[TR]
[TD]B3105[/TD]
[TD]Keyless Entry System Key Fobs[/TD]
[TD]DTC B3105[/TD]
[/TR]
[TR]
[TD]B3106[/TD]
[TD]Keyless Entry Data Link[/TD]
[TD]DTC B3106[/TD]
[/TR]
[TR]
[TD]B3109[/TD]
[TD]Keyless Entry Transmitter*1 Low Battery[/TD]
[TD]DTC B3109-B3113[/TD]
[/TR]
[TR]
[TD]B310D
B310E
B310F[/TD]
[TD]Keyless Entry Transmitter*6 Low Battery
Keyless Entry Transmitter*7 Low Battery
Keyless Entry Transmitter*8 Low Battery[/TD]
[TD]DTC B310D-B310F[/TD]
[/TR]
[TR]
[TD]B3110
B3111
B3112
B3113[/TD]
[TD]Keyless Entry Transmitter*2 Low Battery
Keyless Entry Transmitter*3 Low Battery
Keyless Entry Transmitter*4 Low Battery
Keyless Entry Transmitter*5 Low Battery[/TD]
[TD]
[/TR]
[TR]
[TD]B3125
B3130
B3135[/TD]
[TD]Driver Door Only Unlock Circuit
All Doors Unlock Circuit
All Doors Lock Circuit[/TD]
[TD]DTC B3125, B3130, or B3135[/TD]
[/TR]
[TR]
[TD]B3140
B3150[/TD]
[TD]Driver Door Unlock Switch Circuit
Left Front Door Lock Switch Circuit[/TD]
[TD]DTC B3140 or B3150[/TD]
[/TR]
[TR]
[TD]B316B
B317A
B318A
B319A[/TD]
[TD]Driver Window Switch
Passenger Window Switch
Left Rear Window Switch
Right Rear Window Switch[/TD]
[TD]
DTC B316B, B317A, B318A, or B319A[/TD]
[/TR]
[TR]
[TD]B3205
B3210
B3215
B3220[/TD]
[TD]Driver Window Motor Circuit
Right Front/Passenger Window Motor Circuit
Left Rear Window Motor Circuit
Right Rear Window Motor Circuit[/TD]
[TD]
DTC B3205, B3210, B3215, or B3220[/TD]
[/TR]
[TR]
[TD]B3265[/TD]
[TD]Boot Lid Unlatch Output Circuit[/TD]
[TD]DTC B3265[/TD]
[/TR]
[TR]
[TD]B3410[/TD]
[TD]Automatic Headlamp Levelling Control Module Front Axle Sensor Signal Circuit[/TD]
[TD]DTC B3410 or B3420[/TD]
[/TR]
[TR]
[TD]B3415[/TD]
[TD]Automatic Headlamp Levelling Control Module Axle Sensor Supply Circuit[/TD]
[TD]DTC B3415[/TD]
[/TR]
[TR]
[TD]B3420[/TD]
[TD]Automatic Headlamp Levelling Control Module Rear Axle Sensor Signal Circuit[/TD]
[/TR]
[TR]
[TD]B3435
B3440[/TD]
[TD]Automatic Headlamp Levelling Control Module Left Servo Driver*1 or*2 Circuit
Automatic Headlamp Levelling Control Module Right Servo Driver*1 or*2 Circuit[/TD]
[TD]DTC B3435 or B3440[/TD]
[/TR]
[TR]
[TD]B3567[/TD]
[TD]Info Display Select Switch Circuit[/TD]
[TD]DTC B3567[/TD]
[/TR]
[TR]
[TD]B356A[/TD]
[TD]Vehicle Direction Warning Switch Circuit[/TD]
[TD]DTC B356A[/TD]
[/TR]
[TR]
[TD]B3588[/TD]
[TD]Rear Fog Lamp Switch Circuit[/TD]
[TD]DTC B3588[/TD]
[/TR]
[TR]
[TD]B3596[/TD]
[TD]Hazard Warning Request Circuit[/TD]
[TD]DTC B3596[/TD]
[/TR]
[TR]
[TD]B3618[/TD]
[TD]Exterior Tailgate Unlatch Switch Circuit[/TD]
[TD]DTC B3618[/TD]
[/TR]
[TR]
[TD]B3622[/TD]
[TD]Steering Wheel Controls Signal Circuit[/TD]
[TD]DTC B3622[/TD]
[/TR]
[TR]
[TD]B3650[/TD]
[TD]Main Beam Request Signal Circuit[/TD]
[TD]DTC B3650[/TD]
[/TR]
[TR]
[TD]B3664[/TD]
[TD]Sunroof Position Select Switch High Signal Circuit[/TD]
[TD]DTC B3664[/TD]
[/TR]
[TR]
[TD]B3697[/TD]
[TD]Sunroof Actuator[/TD]
[TD]DTC B3697[/TD]
[/TR]
[TR]
[TD]B369C[/TD]
[TD]Sunroof Tilt Position Select Switch Circuit[/TD]
[TD]DTC B369C[/TD]
[/TR]
[TR]
[TD]B369D[/TD]
[TD]Sunroof Sunshade Actuator[/TD]
[TD]DTC B369D[/TD]
[/TR]
[TR]
[TD]B370A[/TD]
[TD]Rain Sensor[/TD]
[TD]DTC B370A[/TD]
[/TR]
[TR]
[TD]B370B[/TD]
[TD]Rear Wiper Function Control Circuit[/TD]
[TD]DTC B370B[/TD]
[/TR]
[TR]
[TD]B3715[/TD]
[TD] Windscreen Wiper Relay Circuit[/TD]
[TD]DTC B3715[/TD]
[/TR]
[TR]
[TD]B371A[/TD]
[TD]Windscreen Wiper Motor[/TD]
[TD]DTC B371A[/TD]
[/TR]
[TR]
[TD]B3794[/TD]
[TD]Cruise Control Function Request Circuit[/TD]
[TD]DTC B3794[/TD]
[/TR]
[TR]
[TD]B3797[/TD]
[TD]All Door Dead Lock Circuit[/TD]
[TD]DTC B3797[/TD]
[/TR]
[TR]
[TD]B3806[/TD]
[TD]High Beam and Headlamp Flash Select Circuit[/TD]
[TD]DTC B3806[/TD]
[/TR]
[TR]
[TD]B3810[/TD]
[TD]Headlamp Washer Relay Circuit[/TD]
[TD]DTC B3810[/TD]
[/TR]
[TR]
[TD]B3811[/TD]
[TD]Rear Washer Relay Circuit[/TD]
[TD]DTC B3811[/TD]
[/TR]
[TR]
[TD]B3843[/TD]
[TD]Outside Air Quality Sensor Circuit[/TD]
[TD]DTC B3843[/TD]
[/TR]
[TR]
[TD]B3867[/TD]
[TD]Right Park Lamp Control Circuit[/TD]
[TD]DTC B3867[/TD]
[/TR]
[TR]
[TD]B3873[/TD]
[TD]Front Washer Relay Circuit[/TD]
[TD]DTC B3873[/TD]
[/TR]
[TR]
[TD]B3881
B3882[/TD]
[TD]Tail Lamp Circuit
Right Tail Lamp Circuit[/TD]
[TD]DTC B3881 or B3882[/TD]
[/TR]
[TR]
[TD]B3883[/TD]
[TD]Number Plate Lamp Circuit[/TD]
[TD]DTC B3883[/TD]
[/TR]
[TR]
[TD]B3884[/TD]
[TD]Centre High Mounted Brake Lamp Circuit Short to Ground[/TD]
[TD]DTC B3884[/TD]
[/TR]
[TR]
[TD]B3885
B3886[/TD]
[TD]Trailer Left Tail Lamp Circuit
Trailer Right Tail Lamp Circuit[/TD]
[TD]DTC B3885 or B3886[/TD]
[/TR]
[TR]
[TD]B3887
B3888[/TD]
[TD]Trailer Left Turn Signal Circuit
Trailer Right Turn Signal Circuit[/TD]
[TD]DTC B3887 or B3888[/TD]
[/TR]
[TR]
[TD]B3889[/TD]
[TD]Trailer Brake Lamps Circuit[/TD]
[TD]DTC B3889[/TD]
[/TR]
[TR]
[TD]B388B
B388C[/TD]
[TD]Secondary Left Tail and Brake Lamp Circuit
Secondary Right Tail and Brake Lamp Circuit[/TD]
[TD]DTC B388B or B388C[/TD]
[/TR]
[TR]
[TD]B3890[/TD]
[TD]Trailer Backup Lamps Circuit[/TD]
[TD]DTC B3890[/TD]
[/TR]
[TR]
[TD]B3891[/TD]
[TD]Trailer Fog Lamps Circuit[/TD]
[TD]DTC B3891[/TD]
[/TR]
[TR]
[TD]B389A[/TD]
[TD]Environment Identification Malfunction - Received by BCM[/TD]
[TD]DTC B389A[/TD]
[/TR]
[TR]
[TD]B3902[/TD]
[TD]Incorrect Immobiliser Identifier Received[/TD]
[TD]DTC B3902[/TD]
[/TR]
[TR]
[TD]B3933[/TD]
[TD]Air Conditioning Evaporator Temperature Sensor Circuit[/TD]
[TD]HVAC Automatic - DTC B0173, B0178, B0509, B0514 or B3933
or
HVAC Manual - DTC B3933[/TD]
[/TR]
[TR]
[TD]B3938[/TD]
[TD]Fuel Door Actuator Lock Circuit[/TD]
[TD]DTC B3938[/TD]
[/TR]
[TR]
[TD]B393B[/TD]
[TD]Air Conditioning Compressor Valve Control Circuit[/TD]
[TD]HVAC Automatic - DTC B393B
or
HVAC Manual - DTC B393B[/TD]
[/TR]
[TR]
[TD]B3948
B3949[/TD]
[TD]Left Front Indicator Circuit
Right Front Indicator Circuit[/TD]
[TD]DTC B3948 or B3949[/TD]
[/TR]
[TR]
[TD]B3950
B3951[/TD]
[TD]Left Rear Turn Indicator Circuit
Right Rear Indicator Circuit[/TD]
[TD]DTC B3950 or B3951[/TD]
[/TR]
[TR]
[TD]B3984[/TD]
[TD]Device*1 Environment Identifier Not Programmable[/TD]
[TD]DTC B3984[/TD]
[/TR]
73
10:th-Apr-2014, 09:55:50
(This post was last modified: 2:nd-Apr-2022, 08:46:02 by Rusty2009.)
This master DTC list includes all applicable © DTCs in alphanumeric order with descriptors.
This list going to be updated over time to include the links to more info.
[TR]
[TD]DTC[/TD]
[/TR]
[TR]
[TD]C0000[/TD]
[TD]Vehicle Speed Information Circuit[/TD]
[TD]DTC C0000 or
Electronic Suspension Control Module - DTC C0000[/TD]
[/TR]
[TR]
[TD]C0035
C0040
C0045
C0050[/TD]
[TD]Left Front Wheel Speed Sensor Circuit
Right Front Wheel Speed Sensor Circuit
Left Rear Wheel Speed Sensor Circuit
Right Rear Wheel Speed Sensor Circuit[/TD]
[TD]
DTC C0035, C0040, C0045, or C0050[/TD]
[/TR]
[TR]
[TD]C0055[/TD]
[TD]Invalid Data Received from Electronic Brake Control Module[/TD]
[TD]DTC B0000, C0055, C0246, C1207-C1210, C1221-C1228, or C1232-C1235 or
2.0L Diesel engines - DTC C0055[/TD]
[/TR]
[TR]
[TD]C0110[/TD]
[TD]Pump Motor Circuit[/TD]
[TD]DTC C0110[/TD]
[/TR]
[TR]
[TD]C0131[/TD]
[TD]Traction Control System Pressure Circuit[/TD]
[TD]DTC C0131[/TD]
[/TR]
[TR]
[TD]C0161[/TD]
[TD]Antilock Brake System Brake Switch Circuit[/TD]
[TD]DTC C0161[/TD]
[/TR]
[TR]
[TD]C0176[/TD]
[TD]Control Module Temperature Sensor[/TD]
[TD]DTC C0176[/TD]
[/TR]
[TR]
[TD]C0186[/TD]
[TD]Lateral Acceleration Sensor Circuit[/TD]
[TD]DTC C0186, C018B, C0196, C019B, or C0287[/TD]
[/TR]
[TR]
[TD]C018B[/TD]
[TD]Multi Axis Acceleration Sensor[/TD]
[/TR]
[TR]
[TD]C0196[/TD]
[TD]Yaw Rate Circuit[/TD]
[/TR]
[TR]
[TD]C019B[/TD]
[TD]Yaw Rate Signal[/TD]
[/TR]
[TR]
[TD]C0246[/TD]
2.0L Diesel engines - DTC C0246[/TD]
[/TR]
[TR]
[TD]C0267[/TD]
[TD]Low Brake Fluid Indicated[/TD]
[TD]DTC C0267[/TD]
[/TR]
[TR]
[TD]C0277[/TD]
[TD]Brake Pedal Position Sensor Circuit[/TD]
[TD]DTC C0277 or C0890[/TD]
[/TR]
[TR]
[TD]C0280[/TD]
[TD]Stability System Active Too Long[/TD]
[TD]DTC C0280[/TD]
[/TR]
[TR]
[TD]C0287[/TD]
[TD]Longitudinal Acceleration Sensor Circuit[/TD]
[/TR]
[TR]
[TD]C028A[/TD]
[TD]Park Brake Motor Circuit[/TD]
[TD]DTC C028A[/TD]
[/TR]
[TR]
[TD]C028B[/TD]
[TD]Park Brake Motor Position Sensor Signal[/TD]
[TD]DTC C028B[/TD]
[/TR]
[TR]
[TD]C028D[/TD]
[TD]Replace Park Brake Pad[/TD]
[TD]DTC C028D[/TD]
[/TR]
[TR]
[TD]C028F[/TD]
[TD]Park Brake Solenoid Actuator Circuit[/TD]
[TD]DTC C028F[/TD]
[/TR]
[TR]
[TD]C0293[/TD]
[TD]Park Brake Switch Control[/TD]
[TD]DCT C0293[/TD]
[/TR]
[TR]
[TD]C0297[/TD]
[TD]Park Brake Applied Output Circuit[/TD]
[TD]DCT C0297[/TD]
[/TR]
[TR]
[TD]C0298[/TD]
[TD]Park Brake Unlatch Switch Circuit[/TD]
[TD]DTC C0298[/TD]
[/TR]
[TR]
[TD]C044A[/TD]
[TD]Steering System Engine Speed Signal Circuit[/TD]
[TD]DTC C044A[/TD]
[/TR]
[TR]
[TD]C0450[/TD]
[TD]Steering Assist Control Solenoid Valve Circuit[/TD]
[TD]DTC C0450[/TD]
[/TR]
[TR]
[TD]C0456[/TD]
[TD]Steering Position Sensor Calibration Not Learned[/TD]
[TD]DTC C0456[/TD]
[/TR]
[TR]
[TD]C0460[/TD]
[TD]Steering Wheel Angle Sensor[/TD]
[TD]DTC C0460 or C0710[/TD]
[/TR]
[TR]
[TD]C0475[/TD]
[TD]Electric Steering Motor Position Sensor Circuit[/TD]
[TD]DTC C0475[/TD]
[/TR]
[TR]
[TD]C047A[/TD]
[TD]DTC C047A[/TD]
[/TR]
[TR]
[TD]C0545[/TD]
[TD]Steering Wheel Torque Sensor[/TD]
[TD]DTC C0545[/TD]
[/TR]
[TR]
[TD]C0550[/TD]
[TD]DTC C0550[/TD]
[/TR]
[TR]
[TD]C0558[/TD]
[TD]Calibration Data[/TD]
[TD]DTC C0558[/TD]
[/TR]
[TR]
[TD]C0561[/TD]
[TD]System Disabled Information Stored[/TD]
[TD]DTC C0561[/TD]
[/TR]
[TR]
[TD]C0565[/TD]
[TD]Vehicle Identification Number Not Plausible[/TD]
[TD]DTC C0565[/TD]
[/TR]
[TR]
[TD]C0569[/TD]
[TD]System Configuration[/TD]
[TD]Power Steering Control Module - DTC C0569
or
DTC C0569[/TD]
[/TR]
[TR]
[TD]C056D[/TD]
[TD]DTC C056D
or
Handbrake Control Module - DTC C056D[/TD]
[/TR]
[TR]
[TD]C056E[/TD]
[TD]DTC C056E
or
Handbrake Control Module - DTC C056E[/TD]
[/TR]
[TR]
[TD]C0574[/TD]
[TD]Circuit Board Temperature Sensor[/TD]
[TD]DTC C0574[/TD]
[/TR]
[TR]
[TD]C0575
C0580
C0585
C0590[/TD]
[TD]Left Front Actuator Circuit
Right Front Actuator Circuit
Left Rear Actuator Circuit
Right Rear Actuator Circuit[/TD]
[TD]DTC C0575, C0580, C0585, or C0590[/TD]
[/TR]
[TR]
[TD]C0595
C0600
C0605[/TD]
[TD]Left Front Acceleration Sensor Circuit
Right Front Acceleration Sensor Circuit
Left Rear Acceleration Sensor Circuit[/TD]
[TD]DTC C0595, C0600, or C0605[/TD]
[/TR]
[TR]
[TD]C0670
C0675[/TD]
[TD]Left Front Acceleration or Position Sensor Circuit
Right Front Acceleration or Position Sensor Circuit[/TD]
[TD]DTC C0670 or C0675[/TD]
[/TR]
[TR]
[TD]C0710[/TD]
[TD]Steering Position Signal[/TD]
[TD]Antilock Brake System - DTC C0460 or C0710 or
Power Steering - DTC C0710[/TD]
[/TR]
[TR]
[TD]C0720[/TD]
[TD]Engine Torque Management Feedback Signal[/TD]
[TD]DTC C0720[/TD]
[/TR]
[TR]
[TD]C0750
C0755
C0760
C0765[/TD]
[TD]Left Front Tyre Pressure Sensor
Right Front Tyre Pressure Sensor
Left Rear Tyre Pressure Sensor
Right Rear Tyre Pressure Sensor[/TD]
[TD]DTC C0750, C0755, C0760, or C0765[/TD]
[/TR]
[TR]
[TD]C0775[/TD]
[TD]Tyre Pressure Monitoring System Sensors[/TD]
[TD]DTC C0775[/TD]
[/TR]
[TR]
[TD]C078A[/TD]
[TD]Tire Pressure Indicator Module Internal Malfunction[/TD]
[TD]DTC C078A[/TD]
[/TR]
[TR]
[TD]C0800[/TD]
[TD]Device Power*1 Circuit[/TD]
[TD]DTC C0800[/TD]
[/TR]
[TR]
[TD]C0870[/TD]
[TD]DTC C0870[/TD]
[/TR]
[TR]
[TD]C0890[/TD]
[TD]Control Module Voltage Reference Output*3 Circuit[/TD]
[TD]DTC C0890[/TD]
[/TR]
[TR]
[TD]C1100[/TD]
[TD]Brake Pressure Sensor 2[/TD]
[TD]DTC C1100[/TD]
[/TR]
[TR]
[TD]C1207
C1208
C1209
C1210
C1221
C1222
C1223
C1224
C1225
C1226
C1227
C1228[/TD]
[TD]Left Front Wheel Speed Sensor Circuit High Input Malfunction
Right Front Wheel Speed Sensor Circuit High Input Malfunction
Left Rear Wheel Speed Sensor Circuit High Input Malfunction
Right Rear Wheel Speed Sensor Circuit High Input Malfunction
Left Front Wheel Speed Sensor Circuit Malfunction
Right Front Wheel Speed Sensor Circuit Malfunction
Left Rear Wheel Speed Sensor Circuit Malfunction
Right Rear Wheel Speed Sensor Circuit Malfunction
Left Front Wheel Speed Sensor Circuit Performance Malfunction
Right Front Wheel Speed Sensor Circuit Performance Malfunction
Left Rear Wheel Speed Sensor Circuit Performance Malfunction
Right Rear Wheel Speed Sensor Circuit Performance Malfunction[/TD]
[TD]
DTC B0000, C0055, C0246, C1207-C1210, C1221-C1228, or C1232-C1235[/TD]
[/TR]
[TR]
[TD]C122E[/TD]
[TD]Tyre Size Mismatch Malfunction[/TD]
[TD]DTC C122E[/TD]
[/TR]
[TR]
[TD]C1232
C1233
C1234
C1235[/TD]
[TD]Left Front Wheel Speed Sensor Circuit Low Input Malfunction
Right Front Wheel Speed Sensor Circuit Low Input Malfunction
Left Rear Wheel Speed Sensor Circuit Low Input Malfunction
Right Rear Wheel Speed Sensor Circuit Low Input Malfunction[/TD]
[TD]
[/TR]
![[Image: vx.o.c.jpeg]](http://www.vxoc.org.uk/Images/vxoc%20astra-j-gtc/Logo/vx.o.c.jpeg)
73
10:th-Apr-2014, 10:35:16
(This post was last modified: 2:nd-Apr-2022, 08:46:28 by Rusty2009.)
This master DTC list includes all applicable (P) DTCs in alphanumeric order with descriptors.
[TR]
[TD]DTC[/TD]
[/TR]
[TR]
[TD]P0010[/TD]
[TD]DTC P0010 00: Intake Camshaft Position Actuator Solenoid Valve Control Circuit[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0010 or P0013[/TD]
[/TR]
[TR]
[TD]P0010[/TD]
[TD]DTC P0010 00: Inlet Camshaft Position Actuator Solenoid Valve Control Circuit[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0010 or P0013[/TD]
[/TR]
[TR]
[TD]P0011[/TD]
[TD]DTC P0011 00: Intake Camshaft Position System Performance[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0011 or P0014[/TD]
[/TR]
[TR]
[TD]P0011[/TD]
[TD]DTC P0011 00: Inlet Camshaft Position System Performance[/TD]
[TD]1.6L engines (LDE) - DTC P0011 or P0014[/TD]
[/TR]
[TR]
[TD]P0011[/TD]
[TD]1.6L engines (LLU) - DTC P0011[/TD]
[/TR]
[TR]
[TD]P0013[/TD]
[TD]DTC P0013 00: Exhaust Camshaft Position Actuator Solenoid Valve Control Circuit[/TD]
[/TR]
[TR]
[TD]P0013[/TD]
[/TR]
[TR]
[TD]P0014[/TD]
[TD]DTC P0014 00: Exhaust Camshaft Position System Performance[/TD]
[/TR]
[TR]
[TD]P0014[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0011 or P0014[/TD]
[/TR]
[TR]
[TD]P0016[/TD]
[TD]DTC P0016 00: Crankshaft Position - Camshaft Position Not Plausible[/TD]
[TD] 1.3L (Diesel) engines - DTC P0016, P0340, or P0344[/TD]
[/TR]
[TR]
[TD]P0016[/TD]
[TD]DTC P0016 00: Crankshaft Position - Intake Camshaft Position Not Plausible[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0016 or P0017[/TD]
[/TR]
[TR]
[TD]P0016[/TD]
[TD]1.6L engines (LDE) - DTC P0016 or P0017[/TD]
[/TR]
[TR]
[TD]P0016[/TD]
[TD]1.6L engines (LLU) - DTC P0016[/TD]
[/TR]
[TR]
[TD]P0016[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P0016[/TD]
[/TR]
[TR]
[TD]P0016[/TD]
[TD]2.0L (Diesel) engines - DTC P0016, P0340, or P0344[/TD]
[/TR]
[TR]
[TD]P0017[/TD]
[TD]DTC P0017 00: Crankshaft Position - Exhaust Camshaft Position Not Plausible[/TD]
[/TR]
[TR]
[TD]P0017[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0016 or P0017[/TD]
[/TR]
[TR]
[TD]P0030[/TD]
[TD]DTC P0030 00: HO2S Heater Control Circuit Sensor 1[/TD]
[TD] 1.3L Diesel engines - DTC P0030-P0032[/TD]
[/TR]
[TR]
[TD]P0030[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0030, P0036, P0053, P0054, P0135, or P0141[/TD]
[/TR]
[TR]
[TD]P0030[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0030, P0036, P0053, P0054, P0135, or P0141[/TD]
[/TR]
[TR]
[TD]P0030[/TD]
[TD]2.0L (Diesel) engines - DTC P0030-P0032[/TD]
[/TR]
[TR]
[TD]P0031
P0032[/TD]
[TD]DTC P0031 00: HO2S Heater Control Circuit Low Voltage Sensor 1
DTC P0032 00: HO2S Heater Control Circuit High Voltage Sensor 1[/TD]
[TD]1.3L Diesel engines - DTC P0030-P0032[/TD]
[/TR]
[TR]
[TD]P0031
P0032[/TD]
[TD]2.0L Diesel engines - DTC P0030-P0032[/TD]
[/TR]
[TR]
[TD]P0033
P0034
P0035[/TD]
[TD]DTC P0033 00: Turbocharger Bypass Solenoid Valve Control Circuit
DTC P0034 00: Turbocharger Bypass Solenoid Valve Control Circuit Low Voltage
DTC P0035 00: Turbocharger Bypass Solenoid Valve Control Circuit High Voltage[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0033-P0035[/TD]
[/TR]
[TR]
[TD]P0033
P0034
P0035[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0033-P0035[/TD]
[/TR]
[TR]
[TD]P0036[/TD]
[TD]DTC P0036 00: HO2S Heater Control Circuit Sensor 2[/TD]
[/TR]
[TR]
[TD]P0036[/TD]
or P0141[/TD]
[/TR]
[TR]
[TD]P003A[/TD]
[TD] DTC P003A 00: Turbocharger Vane Position Not Learned[/TD]
[TD]1.3L (Diesel) engines - DTC P003A[/TD]
[/TR]
[TR]
[TD]P003A[/TD]
[TD]DTC P003A 00 Turbocharger Boost System Performance[/TD]
[TD]2.0L (Diesel) engines - DTC P003A[/TD]
[/TR]
[TR]
[TD]P0045
P0046[/TD]
[TD]DTC P0045 00: Turbocharger Boost Control Solenoid Control Malfunction
DTC P0046 54: Turbocharger 1 Wastegate Solenoid Valve Control Circuit High Temperature[/TD]
[TD]1.3L (Diesel) engines - DTC P0045-P0048[/TD]
[/TR]
[TR]
[TD]P0045
P0046[/TD]
[TD]DTC P0045 00: Turbocharger 1 Wastegate Solenoid Valve Control Circuit Malfunction
[TD]2.0L (Diesel) engines - DTC P0045-P0048[/TD]
[/TR]
[TR]
[TD]P0047
P0048[/TD]
[TD]DTC P0047 00: Turbocharger Boost Control Solenoid Control Circuit Low Voltage
DTC P0048 00: Turbocharger Boost Control Solenoid Control Circuit High Voltage[/TD]
[/TR]
[TR]
[TD]P0047
P0048[/TD]
[TD]DTC P0047: Turbocharger Boost Control Solenoid Control Circuit Low Voltage
DTC P0048: Turbocharger Boost Control Solenoid Control Circuit High Voltage[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P0047 or P0048[/TD]
[/TR]
[TR]
[TD]P0047
P0048[/TD]
[TD]DTC P0047 00: Turbocharger 1 Wastegate Solenoid Valve Control Circuit Low Voltage
DTC P0048 00: Turbocharger 1 Wastegate Solenoid Valve Control Circuit High Voltage[/TD]
[/TR]
[TR]
[TD]P004A
P004B
P004C
P004D[/TD]
[TD]DTC P004A 00: Turbocharger 2 Wastegate Solenoid Valve Control Circuit Malfunction
DTC P004B 00: Turbocharger 2 Wastegate Solenoid Valve Control Circuit Malfunction
DTC P004C 54: Turbocharger 2 Wastegate Solenoid Valve Control Circuit Low Voltage
DTC P004D 00: Turbocharger 2 Wastegate Solenoid Valve Control Circuit High Voltage[/TD]
[TD]
DTC P004A-P004D[/TD]
[/TR]
73
10:th-Apr-2014, 10:40:33
(This post was last modified: 2:nd-Apr-2022, 08:46:57 by Rusty2009.)
Codes P continued
[TR]
[TD]DTC[/TD]
[/TR]
[TR]
[TD]P0053
P0054[/TD]
[TD]DTC P0053 00: HO2S Heater Resistance Sensor 1
DTC P0054 00: HO2S Heater Resistance Sensor 2[/TD]
[/TR]
[TR]
[TD]P0053
P0054[/TD]
[/TR]
[TR]
[TD]P0068[/TD]
[TD]DTC P0068 00: Throttle Body Air Flow Performance[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0068 or P1101[/TD]
[/TR]
[TR]
[TD]P0068[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0068 or P1101[/TD]
[/TR]
[TR]
[TD]P0069[/TD]
[TD]DTC P0069: Manifold Absolute Pressure (MAP) – Barometric Pressure (BARO) Not Plausible[/TD]
[TD]1.3L (Diesel) engines - DTC P0069[/TD]
[/TR]
[TR]
[TD]P0069[/TD]
[TD]DTC P0069: Manifold Absolute Pressure (MAP) - Barometric Pressure (BARO) Not Plausible[/TD]
[TD]2.0L (Diesel) engines - DTC P0069[/TD]
[/TR]
[TR]
[TD]P0087[/TD]
[TD]DTC P0087 51: Fuel Rail Low Pressure Malfunction
DTC P0087 53: Fuel Rail Low Pressure Malfunction
DTC P0087 55: Fuel Rail Low Pressure Too Few Transitions[/TD]
[TD]1.3L (Diesel) engines - DTC P0087 or P0088[/TD]
[/TR]
[TR]
[TD]P0087[/TD]
DTC P0087 54: Fuel Rail Low Pressure
DTC P0087 5C: Fuel Rail Low Pressure
DTC P0087 5D: Fuel Rail Low Pressure
DTC P0087 5E: Fuel Rail Low Pressure
DTC P0087 5F: Fuel Rail Low Pressure
DTC P0087 60: Fuel Rail Low Pressure
DTC P0087 61: Fuel Rail Low Pressure
DTC P0087 62: Fuel Rail Low Pressure
DTC P0087 64: Fuel Rail Low Pressure
DTC P0087 65: Fuel Rail Low Pressure
DTC P0087 66: Fuel Rail Low Pressure[/TD]
[TD]2.0L (Diesel) engines - DTC P0087 or P0088[/TD]
[/TR]
[TR]
[TD]P0088[/TD]
[TD]DTC P0088 51: Fuel Rail High Pressure Malfunction
DTC P0088 52: Fuel Rail High Pressure Malfunction
DTC P0088 53: Fuel Rail High Pressure Malfunction
DTC P0088 54: Fuel Rail High Pressure Malfunction
DTC P0088 57: Fuel Rail High Pressure Malfunction
DTC P0088 58: Fuel Rail High Pressure Performance
DTC P0088 59: Fuel Rail High Pressure Protection Time-Out
DTC P0088 5A: Fuel Rail High Pressure Not Plausible
DTC P0088 5D: Fuel Rail High Pressure Malfunction[/TD]
[TD] 1.3L (Diesel) engines - DTC P0087 or P0088[/TD]
[/TR]
[TR]
[TD]P0088[/TD]
[TD]DTC P0088 52: Fuel Rail High Pressure
DTC P0088 5B: Fuel Rail High Pressure[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P0088[/TD]
[/TR]
[TR]
[TD]P0088[/TD]
DTC P0088 5C: Fuel Rail High Pressure
DTC P0088 5E: Fuel Rail High Pressure
DTC P0088 5F: Fuel Rail High Pressure
DTC P0088 60: Fuel Rail High Pressure
DTC P0088 61: Fuel Rail High Pressure
DTC P0088 62: Fuel Rail High Pressure
DTC P0088 63: Fuel Rail High Pressure
DTC P0088 64: Fuel Rail High Pressure
DTC P0088 65: Fuel Rail High Pressure
DTC P0088 66: Fuel Rail High Pressure
DTC P0088 67: Fuel Rail High Pressure[/TD]
[/TR]
[TR]
[TD]P0089[/TD]
[TD]DTC P0089 51: Fuel Pressure Regulator Performance
DTC P0089 52: Fuel Pressure Regulator Performance
DTC P0089 54: Fuel Pressure Regulator Performance
DTC P0089 57: Fuel Pressure Regulator Performance[/TD]
[TD]DTC P0089[/TD]
[/TR]
[TR]
[TD]P0090
P0091
P0092[/TD]
[TD]DTC P0090 00: Fuel Pressure Regulator Control Circuit Malfunction
DTC P0091 00: Fuel Pressure Regulator Control Circuit Low Voltage
DTC P0092 00: Fuel Pressure Regulator Control Circuit High Voltage[/TD]
[TD]1.3L (Diesel) engines - DTC P0090, P0091, or P0092[/TD]
[/TR]
[TR]
[TD]P0090
P0091
P0092[/TD]
DTC P0091 02: Fuel Pressure Regulator 1 Control Circuit Low Voltage
DTC P0092 01: Fuel Pressure Regulator 1 Control Circuit High Voltage[/TD]
[TD]2.0L (Diesel) engines - DTC P0090, P0091, or P0092[/TD]
[/TR]
[TR]
[TD]P0093[/TD]
[TD]DTC P0093 00: Fuel System Large Leak Detected[/TD]
[TD]DTC P0093[/TD]
[/TR]
[TR]
[TD]P0094[/TD]
[TD]DTC P0094 00: Fuel System Small Leak Detected[/TD]
[TD]DTC P0094[/TD]
[/TR]
[TR]
[TD]P0096[/TD]
[TD]DTC P0096 00: Intake Air Temperature (IAT) Sensor 2 Performance[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0096, P0097, or P0098[/TD]
[/TR]
[TR]
[TD]P0096[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0096, P0097, or P0098[/TD]
[/TR]
[TR]
[TD]P0097
P0098[/TD]
[TD]DTC P0097 12: Intake Air Temperature (IAT) Sensor 2 Circuit Low Voltage
DTC P0098 11: Intake Air Temperature (IAT) Sensor 2 Circuit High Voltage[/TD]
[TD]1.3L (Diesel) engines - DTC P0097 or P0098[/TD]
[/TR]
[TR]
[TD]P0097
P0098[/TD]
[TD]DTC P0097 00: Intake Air Temperature (IAT) Sensor 2 Circuit Low Voltage
DTC P0098 00: Intake Air Temperature (IAT) Sensor 2 Circuit High Voltage[/TD]
[/TR]
[TR]
[TD]P0097
P0098[/TD]
[TD]DTC P0097 00: Inlet Air Temperature (IAT) Sensor 2 Circuit Low Voltage
DTC P0098 00: Inlet Air Temperature (IAT) Sensor 2 Circuit High Voltage[/TD]
[/TR]
[TR]
[TD]P0097
P0098[/TD]
[TD]DTC P0097: Intake Air Temperature (IAT) Sensor 2 Circuit Low Voltage
DTC P0098: Intake Air Temperature (IAT) Sensor 2 Circuit High Voltage[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P0097 or P0098[/TD]
[/TR]
[TR]
[TD]P0097
P0098[/TD]
[TD]2.0L (Diesel) engines - DTC P0097 or P0098[/TD]
[/TR]
[TR]
[TD]P00B3
P00B4[/TD]
[TD]DTC P00B3: Radiator Coolant Temperature (RCT) Sensor Circuit Low Voltage
DTC P00B4: Radiator Coolant Temperature (RCT) Sensor Circuit High Voltage[/TD]
[TD]DTC P00B3 or P00B4[/TD]
[/TR]
[TR]
[TD]P00B6[/TD]
[TD]DTC P00B6: Radiator Coolant Temperature (RCT) - Engine Coolant Temperature (ECT) Not Plausible[/TD]
[TD]DTC P00B6[/TD]
[/TR]
[TR]
[TD]P00B7[/TD]
[TD]DTC P00B7 00: Engine Coolant Flow Insufficient[/TD]
[TD]DTC P00B7[/TD]
[/TR]
[TR]
[TD]P00C7[/TD]
[TD]DTC P00C7 00: Inlet Air Pressure Measurement System - Multiple Sensors Not Plausible[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P00C7[/TD]
[/TR]
[TR]
[TD]P00C7[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P00C7[/TD]
[/TR]
[TR]
[TD]P0100[/TD]
[TD]DTC P0100: Mass Air Flow (MAF) Sensor Circuit[/TD]
[TD]DTC P0100, P0101, P0102, or P0103[/TD]
[/TR]
[TR]
[TD]P0101[/TD]
[TD]DTC P0101 64: Mass Air Flow (MAF) Sensor Performance[/TD]
[TD] 1.3L (Diesel) engines - DTC P0101, P0102, or P0103[/TD]
[/TR]
[TR]
[TD]P0101[/TD]
[TD]DTC P0101 00 : Mass Air Flow (MAF) Sensor Performance[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0101[/TD]
[/TR]
[TR]
[TD]P0101[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0101[/TD]
[/TR]
[TR]
[TD]P0101[/TD]
[TD]DTC P0101: Mass Air Flow (MAF) Sensor Performance[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P0100, P0101, P0102, or P0103[/TD]
[/TR]
[TR]
[TD]P0101[/TD]
[TD]2.0L (Diesel) engines - DTC P0101, P0102, or P0103[/TD]
[/TR]
[TR]
[TD]P0102[/TD]
[TD]DTC P0102 00: Mass Air Flow (MAF) Sensor Circuit Low Voltage[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0102 or P0103[/TD]
[/TR]
[TR]
[TD]P0102[/TD]
[TD]DTC P0102: Mass Air Flow (MAF) Sensor Circuit Low Voltage[/TD]
[/TR]
[TR]
[TD]P0102[/TD]
[TD]DTC P0102 12: Mass Air Flow (MAF) Sensor Circuit Low Frequency[/TD]
[TD]1.3L (Diesel) engines - DTC P0101, P0102, or P0103[/TD]
[/TR]
[TR]
[TD]P0102[/TD]
[TD]DTC P0102 00: Mass Air Flow (MAF) Sensor Circuit Low Frequency[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0102 or P0103[/TD]
[/TR]
[TR]
[TD]P0102[/TD]
[/TR]
[TR]
[TD]P0103[/TD]
[TD]DTC P0103: Mass Air Flow (MAF) Sensor Circuit High Voltage[/TD]
[/TR]
[TR]
[TD]P0103[/TD]
[TD]DTC P0103 11: Mass Air Flow (MAF) Sensor Circuit High Frequency[/TD]
[/TR]
[TR]
[TD]P0103[/TD]
[TD]DTC P0103 00: Mass Air Flow (MAF) Sensor Circuit High Frequency[/TD]
[/TR]
[TR]
[TD]P0103[/TD]
[/TR]
[TR]
[TD]P0103[/TD]
[/TR]
[TR]
[TD]P0106[/TD]
[TD]DTC P0106 00: Manifold Absolute Pressure (MAP) Sensor Performance[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0106[/TD]
[/TR]
[TR]
[TD]P0106[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0106[/TD]
[/TR]
[TR]
[TD]P0107
P0108[/TD]
[TD]DTC P0107 00: Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage
DTC P0108 00: Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage[/TD]
[TD]1.3L (Diesel) engines - DTC P0107 or P0108[/TD]
[/TR]
[TR]
[TD]P0107
P0108[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0107 or P0108[/TD]
[/TR]
[TR]
[TD]P0107
P0108[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0107 or P0108[/TD]
[/TR]
[TR]
[TD]P0107
P0108[/TD]
[TD]2.0L (Diesel) engines - DTC P0107 or P0108[/TD]
[/TR]
[TR]
[TD]P0110[/TD]
[TD]DTC P0110 00: Intake Air Temperature (IAT) Sensor 1 Circuit Malfunction[/TD]
[TD]DTC P0110 or P0111[/TD]
[/TR]
[TR]
[TD]P0111[/TD]
[TD]DTC P0111 00: Intake Air Temperature (IAT) Sensor Performance[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0111[/TD]
[/TR]
[TR]
[TD]P0111[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0111[/TD]
[/TR]
[TR]
[TD]P0111[/TD]
[TD]DTC P0111 00: Intake Air Temperature (IAT) Sensor 1 Performance[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P0110 or P0111[/TD]
[/TR]
[TR]
[TD]P0112
P0113[/TD]
[TD]DTC P0112 00: Intake Air Temperature (IAT) Sensor 1 Circuit Low Voltage
DTC P0113 00: Intake Air Temperature (IAT) Sensor 1 Circuit High Voltage[/TD]
[TD]1.3L (Diesel) engines - DTC P0112 or P0113[/TD]
[/TR]
[TR]
[TD]P0112
P0113[/TD]
[TD]DTC P0112 00: Intake Air Temperature (IAT) Sensor Circuit Low Voltage
DTC P0113 00: Intake Air Temperature (IAT) Sensor Circuit High Voltage[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0112, P0113, or P0114[/TD]
[/TR]
[TR]
[TD]P0112
P0113[/TD]
[TD]DTC P0112 00: Inlet Air Temperature (IAT) Sensor Circuit Low Voltage
DTC P0113 00: Inlet Air Temperature (IAT) Sensor Circuit High Voltage[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0112, P0113, or P0114[/TD]
[/TR]
[TR]
[TD]P0112
P0113[/TD]
[TD]2.0L (Diesel) engines - DTC P0112 or P0113[/TD]
[/TR]
[TR]
[TD]P0114[/TD]
[TD]DTC P0114 00: Intake Air Temperature (IAT) Sensor Circuit Intermittent[/TD]
[/TR]
[TR]
[TD]P0114[/TD]
[TD]DTC P0114 00: Inlet Air Temperature (IAT) Sensor Circuit Intermittent[/TD]
[/TR]
[TR]
[TD]P0116[/TD]
[TD]DTC P0116 00: Engine Coolant Temperature (ECT) Sensor Performance[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0116[/TD]
[/TR]
[TR]
[TD]P0116[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0116[/TD]
[/TR]
[TR]
[TD]P0116[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P0116, P0117, or P0118[/TD]
[/TR]
[TR]
[TD]P0117
P0118[/TD]
[TD]DTC P0117: Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage
DTC P0118: Engine Coolant Temperature (ECT) Sensor Circuit High Voltage[/TD]
[TD]1.3L (Diesel) engines - DTC P0117 or P0118[/TD]
[/TR]
[TR]
[TD]P0117
P0118[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0117 or P0118[/TD]
[/TR]
[TR]
[TD]P0117
P0118[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0117 or P0118[/TD]
[/TR]
[TR]
[TD]P0117
P0118[/TD]
[/TR]
[TR]
[TD]P0117
P0118[/TD]
[TD]2.0L (Diesel) engines - DTC P0117 or P0118[/TD]
[/TR]
[TR]
[TD]P0119[/TD]
[TD]DTC P0119: Engine Coolant Temperature (ECT) Sensor Circuit Intermittent[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0119[/TD]
[/TR]
[TR]
[TD]P0119[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0119[/TD]
[/TR]
[TR]
[TD]P0121[/TD]
[TD]DTC P0121 00: Throttle Position Sensor 1 Performance[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0121-P0123, P0222, P0223, or P2135[/TD]
[/TR]
[TR]
[TD]P0121[/TD]
[TD]DTC P0121 00: Throttle Position Sensor Performance[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0121-P0123, P0222, P0223, or P2135[/TD]
[/TR]
[TR]
[TD]P0122
P0123[/TD]
[TD]DTC P0122 00: Throttle Position Sensor 1 Circuit Low Voltage
DTC P0123 00: Throttle Position Sensor 1 Circuit High Voltage[/TD]
[TD]1.3L (Diesel) engines - DTC P0122 or P0123[/TD]
[/TR]
[TR]
[TD]P0122
P0123[/TD]
[/TR]
[TR]
[TD]P0122
P0123[/TD]
[TD]DTC P0122 00: Throttle Position Sensor Circuit Low Voltage
DTC P0123 00: Throttle Position Sensor Circuit High Voltage[/TD]
[/TR]
[TR]
[TD]P0122
P0123[/TD]
[TD]2.0L (Diesel) engines - DTC P0122 or P0123[/TD]
[/TR]
73
10:th-Apr-2014, 10:49:01
(This post was last modified: 2:nd-Apr-2022, 08:47:40 by Rusty2009.)
Codes P continued
[TR]
[TD]DTC[/TD]
[/TR]
[TR]
[TD]P0128[/TD]
[TD]DTC P0128 00: Engine Coolant Temperature (ECT) Below Thermostat Regulating Temperature[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0128[/TD]
[/TR]
[TR]
[TD]P0128[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0128[/TD]
[/TR]
[TR]
[TD]P0130[/TD]
[TD]DTC P0130 00: HO2S Circuit Closed Loop Performance Sensor 1[/TD]
[TD]DTC P0130[/TD]
[/TR]
[TR]
[TD]P0131
P0132[/TD]
[TD]DTC P0131 01: HO2S Circuit Low Voltage Sensor 1
DTC P0132 02: HO2S Circuit High Voltage Sensor 1[/TD]
[TD]1.3L (Diesel) engines - DTC P0131 or P0132[/TD]
[/TR]
[TR]
[TD]P0131
P0132[/TD]
[TD]DTC P0131 00: HO2S Circuit Low Voltage Sensor 1
DTC P0132 00: HO2S Circuit High Voltage Sensor 1[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0131, P0132, P0137, or P0138[/TD]
[/TR]
[TR]
[TD]P0131
P0132[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0131, P0132, P0137, or P0138[/TD]
[/TR]
[TR]
[TD]P0131
P0132[/TD]
[TD]DTC P0131 02: HO2S Circuit Low Voltage Sensor 1
DTC P0132 01: HO2S Circuit High Voltage Sensor 1[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P0131 or P0132[/TD]
[/TR]
[TR]
[TD]P0131
P0132[/TD]
[TD]2.0L (Diesel) engines - DTC P0131 or P0132[/TD]
[/TR]
[TR]
[TD]P0133[/TD]
[TD]DTC P0133: HO2S Slow Response Sensor 1[/TD]
[TD]1.3L (Diesel) engines - DTC P0133[/TD]
[/TR]
[TR]
[TD]P0133[/TD]
[TD]DTC P0133 00: HO2S Slow Response Sensor 1[/TD]
[TD]1.4L (LDD) engines - DTC P0133, P0134, P0140, P1133, P2270, P2271, or P2A00[/TD]
[/TR]
[TR]
[TD]P0133[/TD]
[TD]1.4L (LUJ) engines - DTC P0133, P0134, P013A, P013B, P013E, P013F, P0140, P1133, P2270, P2271, or P2A00[/TD]
[/TR]
[TR]
[TD]P0133[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0133, P0134, P0140, P1133, P2270, P2271, or P2A00[/TD]
[/TR]
[TR]
[TD]P0133[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P0133[/TD]
[/TR]
[TR]
[TD]P0133[/TD]
[TD]2.0L (Diesel) engines - DTC P0133[/TD]
[/TR]
[TR]
[TD]P0134[/TD]
[TD]DTC P0134 00: HO2S Circuit Insufficient Activity Sensor 1[/TD]
[/TR]
[TR]
[TD]P0134[/TD]
[/TR]
[TR]
[TD]P0134[/TD]
[/TR]
[TR]
[TD]P0134[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P0134[/TD]
[/TR]
[TR]
[TD]P0135[/TD]
[TD]DTC P0135 00: HO2S Heater Performance Sensor 1[/TD]
[/TR]
[TR]
[TD]P0135[/TD]
[/TR]
[TR]
[TD]P0135[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P0135[/TD]
[/TR]
[TR]
[TD]P0137
P0138[/TD]
[TD]DTC P0137 00: HO2S Circuit Low Voltage Sensor 2
DTC P0138 00: HO2S Circuit High Voltage Sensor 2[/TD]
[/TR]
[TR]
[TD]P0137
P0138[/TD]
[/TR]
[TR]
[TD]P013A
P013B
P013E
P013F[/TD]
[TD]DTC P013A 00: HO2S Slow Response Rich to Lean Sensor 2
DTC P013B 00: HO2S Slow Response Lean to Rich Sensor 2
DTC P013E 00: HO2S Delayed Response Rich to Lean Sensor 2
DTC P013F 00: HO2S Delayed Response Lean to Rich Sensor 2[/TD]
[TD]DTC P0133, P0134, P013A, P013B, P013E, P013F, P0140, P1133, P2270, P2271, or P2A00[/TD]
[/TR]
[TR]
[TD]P0140[/TD]
[TD]DTC P0140 00: HO2S Circuit Insufficient Activity Sensor 2[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0133, P0134, P0140, P1133, P2270, P2271, or P2A00[/TD]
[/TR]
[TR]
[TD]P0140[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0133, P0134, P013A, P013B, P013E, P013F, P0140, P1133, P2270, P2271, or P2A00[/TD]
[/TR]
[TR]
[TD]P0140[/TD]
[/TR]
[TR]
[TD]P0141[/TD]
[TD]DTC P0141 00: HO2S Heater Performance Sensor 2[/TD]
[/TR]
[TR]
[TD]P0141[/TD]
[/TR]
[TR]
[TD]P0168[/TD]
[TD]DTC P0168 00: Engine Fuel Over temperature[/TD]
[TD]DTC P0168[/TD]
[/TR]
[TR]
[TD]P0171
P0172[/TD]
[TD]DTC P0171 00: Fuel Trim System Lean
DTC P0172 00: Fuel Trim System Rich[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0171 or P0172[/TD]
[/TR]
[TR]
[TD]P0171
P0172[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0171 or P0172[/TD]
[/TR]
[TR]
[TD]P0182
P0183[/TD]
[TD]DTC P0182: Fuel Temperature Sensor Circuit Low Voltage
DTC P0183: Fuel Temperature Sensor Circuit High Voltage[/TD]
[TD]1.3L (Diesel) engines - DTC P0182 or P0183[/TD]
[/TR]
[TR]
[TD]P0182
P0183[/TD]
[TD]DTC P0182: Fuel Temperature Sensor 2 Circuit Low Voltage
DTC P0183: Fuel Temperature Sensor 2 Circuit High Voltage[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P0182 or P0183[/TD]
[/TR]
[TR]
[TD]P0182
P0183[/TD]
[TD]DTC P0182 00: Fuel Temperature Sensor Circuit Low Voltage
DTC P0183 00: Fuel Temperature Sensor Circuit High Voltage[/TD]
[TD]2.0L (Diesel) engines - DTC P0182 or P0183[/TD]
[/TR]
[TR]
[TD]P0187
P0188[/TD]
[TD]DTC P0187 00: Fuel Temperature Sensor 1 Circuit Low Voltage
DTC P0188 00: Fuel Temperature Sensor 1 Circuit High Voltage[/TD]
[TD]DTC P0187 or P0188[/TD]
[/TR]
[TR]
[TD]P018B
P018C
P018D[/TD]
[TD]DTC P018B: Fuel Pressure Sensor Performance
DTC P018C: Fuel Pressure Sensor Circuit Low Voltage
DTC P018D: Fuel Pressure Sensor Circuit High Voltage[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P018B-P018D[/TD]
[/TR]
[TR]
[TD]P018B
P018C
P018D[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P018B-P018D[/TD]
[/TR]
[TR]
[TD]P0191[/TD]
[TD]DTC P0191 00: Fuel Rail Pressure Sensor Performance[/TD]
[TD]DTC P0191, P0192, or P0193[/TD]
[/TR]
[TR]
[TD]P0192
P0193[/TD]
[TD]DTC P0192 12: Fuel Rail Pressure Sensor Circuit Low Voltage
DTC P0192 5A: Fuel Rail Pressure Sensor Circuit Low Voltage
DTC P0193 11: Fuel Rail Pressure Sensor Circuit High Voltage
DTC P0193 5B: Fuel Rail Pressure Sensor Circuit High Voltage[/TD]
[TD]1.3L (Diesel) engines - DTC P0192 or P0193[/TD]
[/TR]
[TR]
[TD]P0192
P0193[/TD]
[TD]DTC P0192 00: Fuel Rail Pressure Sensor Circuit Low Voltage
DTC P0193 00: Fuel Rail Pressure Sensor Circuit High Voltage[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P0191, P0192, or P0193[/TD]
[/TR]
[TR]
[TD]P0192
P0193[/TD]
[TD]2.0L (Diesel) engines - DTC P0192 or P0193[/TD]
[/TR]
[TR]
[TD]P0194[/TD]
[TD]DTC P0194 00: Fuel Rail Pressure Sensor Circuit Erratic[/TD]
[TD]1.3L (Diesel) engines - DTC P0194[/TD]
[/TR]
[TR]
[TD]P0194[/TD]
[TD]2.0L (Diesel) engines - DTC P0194[/TD]
[/TR]
[TR]
[TD]P0201
P0202
P0203
P0204[/TD]
[TD]DTC P0201 00: Cylinder 1 Injector Control Circuit Malfunction
DTC P0202 00: Cylinder 2 Injector Control Circuit Malfunction
DTC P0203 00: Cylinder 3 Injector Control Circuit Malfunction
DTC P0204 00: Cylinder 4 Injector Control Circuit Malfunction[/TD]
[TD]1.3L (Diesel) engines - DTC P0201, P0202, P0203, or P0204[/TD]
[/TR]
[TR]
[TD]P0201
P0202
P0203
P0204[/TD]
DTC P0204 00: Cylinder 4 Injector Control Circuit[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0201, P0202, P0203, or P0204[/TD]
[/TR]
[TR]
[TD]P0201
P0202
P0203
P0204[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0201, P0202, P0203, or P0204[/TD]
[/TR]
[TR]
[TD]P0201
P0202
P0203
P0204[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P0201, P0202, P0203, or P0204[/TD]
[/TR]
[TR]
[TD]P0201
P0202
P0203
P0204[/TD]
[TD]2.0L (Diesel) engines - DTC P0201, P0202, P0203, or P0204[/TD]
[/TR]
[TR]
[TD]P020A
P020B
P020C
P020D[/TD]
[TD]DTC P020A 00: Cylinder 1 Injection Timing Malfunction
DTC P020B 00: Cylinder 2 Injection Timing Malfunction
DTC P020C 00: Cylinder 3 Injection Timing Malfunction
DTC P020D 00: Cylinder 4 Injection Timing Malfunction[/TD]
[TD]DTC P020A-P020D[/TD]
[/TR]
[TR]
[TD]P0217[/TD]
[TD]DTC P0217 00: Engine Over temperature[/TD]
[TD]DTC P0217[/TD]
[/TR]
[TR]
[TD]P0218[/TD]
[TD]DTC P0218: Transmission Fluid Over temperature[/TD]
[TD]Automatic Transmission 6T30/6T40/6T45/6T50 - DTC P0218[/TD]
[/TR]
[TR]
[TD]P0218[/TD]
[TD]Automatic Transmission AF40-6 - DTC P0218[/TD]
[/TR]
[TR]
[TD]P0219[/TD]
[TD]DTC P0219: Engine Overspeed[/TD]
[TD]1.3L (Diesel) engines - DTC P0219[/TD]
[/TR]
[TR]
[TD]P0219[/TD]
[TD]2.0L (Diesel) engines - DTC P0219[/TD]
[/TR]
[TR]
[TD]P0222
P0223[/TD]
[TD]DTC P0222 00: Throttle Position Sensor 2 Circuit Low Voltage
DTC P0223 00: Throttle Position Sensor 2 Circuit High Voltage[/TD]
[/TR]
[TR]
[TD]P0222
P0223[/TD]
[/TR]
[TR]
[TD]P0231
P0232[/TD]
[TD]DTC P0231: Fuel Pump Control Circuit Low Voltage
DTC P0232: Fuel Pump Control Circuit High Voltage[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0231, P0232, or P023F[/TD]
[/TR]
[TR]
[TD]P0231
P0232[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0231, P0232, or P023F[/TD]
[/TR]
[TR]
[TD]P0234[/TD]
[TD]DTC P0234 00: Engine Overboost[/TD]
[TD]1.3L (Diesel) engines - DTC P0234 or P0299[/TD]
[/TR]
[TR]
[TD]P0234[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0234 or P0299[/TD]
[/TR]
[TR]
[TD]P0234[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0234 or P0299[/TD]
[/TR]
[TR]
[TD]P0234[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P0234 or P0299[/TD]
[/TR]
[TR]
[TD]P0234[/TD]
[TD]2.0L (Diesel) engines - DTC P0234 or P0299[/TD]
[/TR]
[TR]
[TD]P0236
P0237
P0238[/TD]
[TD]DTC P0236 00: Turbocharger Boost Sensor Performance
DTC P0237 00: Turbocharger Boost Sensor Circuit Low Voltage
DTC P0238 00: Turbocharger Boost Sensor Circuit High Voltage[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0236, P0237, or P0238[/TD]
[/TR]
[TR]
[TD]P0236
P0237
P0238[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0236, P0237, or P0238[/TD]
[/TR]
[TR]
[TD]P0236
P0237
P0238[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P0236, P0237, or P0238[/TD]
[/TR]
[TR]
[TD]P0243
P0245
P0246[/TD]
[TD]DTC P0243 00: Turbocharger Wastegate Solenoid Valve Control Circuit
DTC P0245 00: Turbocharger Wastegate Solenoid Valve Control Circuit Low Voltage
DTC P0246 00: Turbocharger Wastegate Solenoid Valve Control Circuit High Voltage[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0243, P0245, or P0246[/TD]
[/TR]
[TR]
[TD]P0243
P0245
P0246[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0243, P0245, or P0246[/TD]
[/TR]
[TR]
[TD]P0251[/TD]
[TD]DTC P0251 00: Fuel Pressure Regulator 1 Control Circuit Malfunction[/TD]
[TD]1.3L (Diesel) engines - DTC P0251-P0254[/TD]
[/TR]
[TR]
[TD]P0251[/TD]
[TD]2.0L (Diesel) engines - DTC P0251-P0254[/TD]
[/TR]
[TR]
[TD]P0252
P0253
P0254[/TD]
[TD]DTC P0252 54: Fuel Pressure Regulator 1 Control Circuit High Temperature
DTC P0253 00: Fuel Pressure Regulator 1 Control Circuit Low Voltage
DTC P0254 00: Fuel Pressure Regulator 1 Control Circuit High Voltage[/TD]
[/TR]
[TR]
[TD]P0252
P0253
P0254[/TD]
[TD]DTC P0252 00: Fuel Pressure Regulator Performance
DTC P0253 00: Fuel Pressure Regulator Control Circuit Low Voltage
DTC P0254 00: Fuel Pressure Regulator Control Circuit High Voltage[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P0252-P0254[/TD]
[/TR]
[TR]
[TD]P0252
P0253
P0254[/TD]
[TD]DTC P0252 54: Fuel Pressure Regulator Performance
[/TR]
[TR]
[TD]P025A[/TD]
[TD]DTC P025A: Fuel Pump Control Module Enable Circuit[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P025A[/TD]
[/TR]
[TR]
[TD]P025A[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P025A[/TD]
[/TR]
[TR]
[TD]P0261
P0262
P0264
P0265
P0267
P0268
P0270
P0271[/TD]
[TD]DTC P0261 00: Cylinder 1 Injector Control Circuit Low Voltage
DTC P0262 00: Cylinder 1 Injector Control Circuit High Voltage
DTC P0264 00: Cylinder 2 Injector Control Circuit Low Voltage
DTC P0265 00: Cylinder 2 Injector Control Circuit High Voltage
DTC P0267 00: Cylinder 3 Injector Control Circuit Low Voltage
DTC P0268 00: Cylinder 3 Injector Control Circuit High Voltage
DTC P0270 00: Cylinder 4 Injector Control Circuit Low Voltage
DTC P0271 00: Cylinder 4 Injector Control Circuit High Voltage[/TD]
[TD]1.3L (Diesel) engines - DTC P0261, P0262, P0264, P0265, P0267, P0268, P0270, or P0271[/TD]
[/TR]
[TR]
[TD]P0261
P0262
P0264
P0265
P0267
P0268
P0270
P0271[/TD]
[TD]2.0L (Diesel) engines - DTC P0261, P0262, P0264, P0265, P0267, P0268, P0270, or P0271[/TD]
[/TR]
[TR]
[TD]P0297[/TD]
[TD]DTC P0297 5B: Vehicle Overspeed[/TD]
[TD]1.3L (Diesel) engines - DTC P0297[/TD]
[/TR]
[TR]
[TD]P0297[/TD]
[TD]2.0L (Diesel) engines - DTC P0297[/TD]
[/TR]
[TR]
[TD]P0299[/TD]
[TD]DTC P0299 00: Engine Underboost[/TD]
[/TR]
[TR]
[TD]P0299[/TD]
[/TR]
[TR]
[TD]P0299[/TD]
[/TR]
[TR]
[TD]P0299[/TD]
[/TR]
[TR]
[TD]P0299[/TD]
[/TR]
[TR]
[TD]P0300[/TD]
[TD]DTC P0300 00: Engine Misfire Detected[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0300-P0304[/TD]
[/TR]
[TR]
[TD]P0300[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0300-P0304[/TD]
[/TR]
[TR]
[TD]P0301
P0302
P0303
P0304[/TD]
[TD]DTC P0301 00: Cylinder 1 Misfire Detected
DTC P0302 00: Cylinder 2 Misfire Detected
DTC P0303 00: Cylinder 3 Misfire Detected
DTC P0304 00: Cylinder 4 Misfire Detected[/TD]
[/TR]
[TR]
[TD]P0301
P0302
P0303
P0304[/TD]
[/TR]
[TR]
[TD]P0301
P0302
P0303
P0304[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P0301-P0304[/TD]
[/TR]
[TR]
[TD]P0313[/TD]
[TD]DTC P0313 00: Misfire Detected With Low Fuel Level[/TD]
[TD]1.3L (Diesel) engines - DTC P0313[/TD]
[/TR]
[TR]
[TD]P0313[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P0313[/TD]
[/TR]
[TR]
[TD]P0313[/TD]
[TD]2.0L (Diesel) engines - DTC P0313[/TD]
[/TR]
[TR]
[TD]P0315[/TD]
[TD]DTC P0315 00: Crankshaft Position System Variation Not Learned[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0315[/TD]
[/TR]
[TR]
[TD]P0315[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0315[/TD]
[/TR]
[TR]
[TD]P0324[/TD]
[TD]DTC P0324 00: Knock Sensor Module Performance[/TD]
[TD]1.4L (LDD) engines - DTC P0324 or P06B6[/TD]
[/TR]
[TR]
[TD]P0324[/TD]
[TD]1.4L (LUJ) engines - DTC P0324, P0326, or P06B6[/TD]
[/TR]
[TR]
[TD]P0324[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0324 or P06B6[/TD]
[/TR]
[TR]
[TD]P0324[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0324, P0326, or P06B6[/TD]
[/TR]
[TR]
[TD]P0325[/TD]
[TD]DTC P0325 00: Knock Sensor Circuit[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0325, P0327, or P0328[/TD]
[/TR]
[TR]
[TD]P0325[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0325, P0327, or P0328[/TD]
[/TR]
[TR]
[TD]P0326[/TD]
[TD]DTC P0326 00: Knock Sensor Performance[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0324, P0326, or P06B6[/TD]
[/TR]
[TR]
[TD]P0326[/TD]
[/TR]
[TR]
[TD]P0327
P0328[/TD]
[TD]DTC P0327 00: Knock Sensor Circuit Low Voltage
DTC P0328 00: Knock Sensor Circuit High Voltage[/TD]
[/TR]
[TR]
[TD]P0327
P0328[/TD]
[/TR]
[TR]
[TD]P0335[/TD]
[TD]DTC P0335 00: Crankshaft Position Sensor Circuit[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0335 or P0336[/TD]
[/TR]
[TR]
[TD]P0335[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0335 or P0336[/TD]
[/TR]
[TR]
[TD]P0335[/TD]
[TD]DTC P0335: Crankshaft Position Sensor Circuit[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P0335 or P0336[/TD]
[/TR]
[TR]
[TD]P0336[/TD]
[TD]DTC P0336 00: Crankshaft Position Sensor Performance[/TD]
[TD]1.3L (Diesel) engines - DTC P0336[/TD]
[/TR]
[TR]
[TD]P0336[/TD]
[/TR]
[TR]
[TD]P0336[/TD]
[/TR]
[TR]
[TD]P0336[/TD]
[TD]DTC P0336: Crankshaft Position Sensor Performance[/TD]
[/TR]
[TR]
[TD]P0336[/TD]
[TD]2.0L (Diesel) engines - DTC P0336[/TD]
[/TR]
[TR]
[TD]P0340[/TD]
[TD]DTC P0340 00: Intake Camshaft Position Sensor Circuit[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0340 or P0365[/TD]
[/TR]
[TR]
[TD]P0340[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0340 or P0365[/TD]
[/TR]
[TR]
[TD]P0340[/TD]
[TD]DTC P0340: Intake Camshaft Position Sensor Circuit[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P0340 or P0341[/TD]
[/TR]
[TR]
[TD]P0340[/TD]
[TD]DTC P0340 00: Camshaft Position Sensor Circuit Malfunction[/TD]
[TD]1.3L (Diesel) engines - DTC P0016, P0340, or P0344[/TD]
[/TR]
[TR]
[TD]P0340[/TD]
[TD]DTC P0340 00: Camshaft Position Sensor Circuit[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0340[/TD]
[/TR]
[TR]
[TD]P0340[/TD]
[/TR]
[TR]
[TD]P0341[/TD]
[TD]DTC P0341 00: Intake Camshaft Position Sensor Performance[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0341 or P0366[/TD]
[/TR]
[TR]
[TD]P0341[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0341 or P0366[/TD]
[/TR]
[TR]
[TD]P0341[/TD]
[TD]DTC P0341: Intake Camshaft Position Sensor Performance[/TD]
[/TR]
[TR]
[TD]P0341[/TD]
[TD]DTC P0341 00: Camshaft Position Sensor Performance[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0341[/TD]
[/TR]
[TR]
[TD]P0344[/TD]
[TD]DTC P0344 00: Camshaft Position Sensor Performance[/TD]
[/TR]
[TR]
[TD]P0344[/TD]
[/TR]
[TR]
[TD]P0351
P0352
P0353
P0354[/TD]
[TD]DTC P0351 00: Ignition Coil 1 Control Circuit
DTC P0352 00: Ignition Coil 2 Control Circuit
DTC P0353 00: Ignition Coil 3 Control Circuit
DTC P0354 00: Ignition Coil 4 Control Circuit[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0351-P0354[/TD]
[/TR]
[TR]
[TD]P0351
P0352
P0353
P0354[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0351-P0354[/TD]
[/TR]
[TR]
[TD]P0365[/TD]
[TD]DTC P0365 00: Exhaust Camshaft Position Sensor Circuit[/TD]
[/TR]
[TR]
[TD]P0365[/TD]
[/TR]
[TR]
[TD]P0366[/TD]
[TD]DTC P0366 00: Exhaust Camshaft Position Sensor Performance[/TD]
[/TR]
[TR]
[TD]P0366[/TD]
[/TR]
[TR]
[TD]P037E
P037F[/TD]
[TD]DTC P037E: Glow Plug Control Module Feedback Circuit Low Voltage
DTC P037F: Glow Plug Control Module Feedback Circuit High Voltage[/TD]
[TD]DTC P037E or P037F[/TD]
[/TR]
[TR]
[TD]P0380[/TD]
[TD]DTC P0380 00: Glow Plug Feedback Circuit Malfunction[/TD]
[TD]1.3L (Diesel) engines - DTC P0380, P0383, or P0384[/TD]
[/TR]
[TR]
[TD]P0380[/TD]
[TD]2.0L (Diesel) engines - DTC P0380, P0383, or P0384[/TD]
[/TR]
[TR]
[TD]P0383
P0384[/TD]
[TD]DTC P0383 02: Glow Plug Control Module Control Circuit Short to Ground
DTC P0384 00: Glow Plug Control Module Control Circuit Malfunction[/TD]
[/TR]
[TR]
[TD]P0383
P0384[/TD]
[TD]DTC P0383: Glow Plug Control Module Control Circuit Low Voltage
DTC P0384: Glow Plug Control Module Control Circuit High Voltage[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P0383 or P0384[/TD]
[/TR]
[TR]
[TD]P0383
P0384[/TD]
[/TR]
[TR]
[TD]P0396[/TD]
[TD]DTC P0396 00: Cylinder 1 Pressure Sensor Performance[/TD]
[TD]DTC P0396, P03A0, P03AA, or P03B4[/TD]
[/TR]
[TR]
[TD]P0397
P0398[/TD]
[TD]DTC P0397 00: Cylinder 1 Pressure Sensor Circuit Low Voltage
DTC P0398 00: Cylinder 1 Pressure Sensor Circuit High Voltage[/TD]
[TD]DTC P0397, P0398, P03A1, P03A2, P03AB, P03AC, P03B5, or P03B6[/TD]
[/TR]
[TR]
[TD]P0399
P039C
P039D[/TD]
[TD]DTC P0399 00: Cylinder 1 Pressure Sensor Circuit Erratic
DTC P039C 00: Cylinder 1 Pressure Variation Too Low
DTC P039C 01: Cylinder 1 Pressure Variation Too Low
DTC P039C 02: Cylinder 1 Pressure Variation Too Low
DTC P039D 00: Cylinder 1 Pressure Variation Too High[/TD]
[TD]DTC P0399, P039C, P039D, P03A3, P03A6, P03A7, P03AD, P03B0, P03B1, P03B7, P03BA, or P03BB[/TD]
[/TR]
[TR]
[TD]P03A0[/TD]
[TD]DTC P03A0 00: Cylinder 2 Pressure Sensor Performance[/TD]
[/TR]
[TR]
[TD]P03A1
P03A2[/TD]
[TD]DTC P03A1 00: Cylinder 2 Pressure Sensor Circuit Low Voltage
DTC P03A2 00: Cylinder 2 Pressure Sensor Circuit High Voltage[/TD]
[/TR]
[TR]
[TD]P03A3
P03A6
P03A7[/TD]
[TD]DTC P03A3 00: Cylinder 2 Pressure Sensor Circuit Erratic
DTC P03A6 00: Cylinder 2 Pressure Variation Too Low
DTC P03A6 01: Cylinder 2 Pressure Variation Too Low
DTC P03A6 02: Cylinder 2 Pressure Variation Too Low
DTC P03A7 00: Cylinder 2 Pressure Variation Too High[/TD]
[/TR]
[TR]
[TD]P03AA[/TD]
[TD]DTC P03AA 00: Cylinder 3 Pressure Sensor Performance[/TD]
[/TR]
[TR]
[TD]P03AB
P03AC[/TD]
[TD]DTC P03AB 00: Cylinder 3 Pressure Sensor Circuit Low Voltage
DTC P03AC 00: Cylinder 3 Pressure Sensor Circuit High Voltage[/TD]
[/TR]
[TR]
[TD]P03AD
P03B0
P03B1[/TD]
[TD]DTC P03AD 00: Cylinder 3 Pressure Sensor Circuit Erratic
DTC P03B0 00: Cylinder 3 Pressure Variation Too Low
DTC P03B0 01: Cylinder 3 Pressure Variation Too Low
DTC P03B0 02: Cylinder 3 Pressure Variation Too Low
DTC P03B1 00: Cylinder 3 Pressure Variation Too High[/TD]
[/TR]
[TR]
[TD]P03B4[/TD]
[TD]DTC P03B4 00: Cylinder 4 Pressure Sensor Performance[/TD]
[/TR]
[TR]
[TD]P03B5
P03B6[/TD]
[TD]DTC P03B5 00: Cylinder 4 Pressure Sensor Circuit Low Voltage
DTC P03B6 00: Cylinder 4 Pressure Sensor Circuit High Voltage[/TD]
[/TR]
[TR]
[TD]P03B7
P03BA
P03BB[/TD]
[TD]DTC P03B7 00: Cylinder 4 Pressure Sensor Circuit Erratic
DTC P03BA 00: Cylinder 4 Pressure Variation Too Low
DTC P03BA 01: Cylinder 4 Pressure Variation Too Low
DTC P03BA 02: Cylinder 4 Pressure Variation Too Low
DTC P03BB 00: Cylinder 4 Pressure Variation Too High[/TD]
[/TR]
[TR]
[TD]P0400[/TD]
[TD]DTC P0400 00: Exhaust Gas Recirculation (EGR) Flow Incorrect[/TD]
[TD]DTC P0400-P0402[/TD]
[/TR]
[TR]
[TD]P0401
P0402[/TD]
[TD]DTC P0401 00: Exhaust Gas Recirculation (EGR) Flow Insufficient
DTC P0402 00: Exhaust Gas Recirculation (EGR) Flow Excessive[/TD]
[TD] 1.3L (Diesel) engines - DTC P0401 or P0402[/TD]
[/TR]
Thanks Received: 8 in 8 posts
73
9:th-Apr-2015, 08:56:42
(This post was last modified: 2:nd-Apr-2022, 08:50:15 by Rusty2009.)
Codes P continued
[TR]
[TD]DTC[/TD]
[TD]DTC Descriptor[/TD]
[TD]Diagnostic Procedure[/TD]
[/TR]
[TR]
[TD]P0401
P0402[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P0400-P0402[/TD]
[/TR]
[TR]
[TD]P0401
P0402[/TD]
[TD]2.0L (Diesel) engines - DTC P0401 or P0402[/TD]
[/TR]
[TR]
[TD]P0403[/TD]
[TD]DTC P0403 04: Exhaust Gas Recirculation (EGR) Control Circuit Open[/TD]
[TD]1.3L (Diesel) engines - DTC P0403, P0489, or P0490[/TD]
[/TR]
[TR]
[TD]P0403[/TD]
[TD]DTC P0403 00: Exhaust Gas Recirculation (EGR) Control Circuit Malfunction[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P0403-P0406[/TD]
[/TR]
[TR]
[TD]P0403[/TD]
[TD]2.0L (Diesel) engines - DTC P0403, P0489, or P0490[/TD]
[/TR]
[TR]
[TD]P0404[/TD]
[TD]DTC P0404 00: Exhaust Gas Recirculation (EGR) Open Position Performance[/TD]
[/TR]
[TR]
[TD]P0404[/TD]
[TD]DTC P0404 03: Exhaust Gas Recirculation (EGR) Control Circuit Low Voltage
DTC P0404 0B: Exhaust Gas Recirculation (EGR) Control Circuit High Current
DTC P0404 51: Exhaust Gas Recirculation (EGR) Control Circuit Malfunction
DTC P0404 52: Exhaust Gas Recirculation (EGR) Control Circuit Malfunction
DTC P0404 55: Exhaust Gas Recirculation (EGR) Control Circuit Too Few Transitions
DTC P0404 56: Exhaust Gas Recirculation (EGR) Control Circuit Too Many Transitions
DTC P0404 59: Exhaust Gas Recirculation (EGR) Control Circuit Protection Time-Out
DTC P0404 5A: Exhaust Gas Recirculation (EGR) Control Circuit Not Plausible
DTC P0404 5B: Exhaust Gas Recirculation (EGR) Control Circuit Malfunction[/TD]
[TD]1.3L (Diesel) engines - DTC P0404[/TD]
[/TR]
[TR]
[TD]P0404[/TD]
[TD]2.0L (Diesel) engines - DTC P0404[/TD]
[/TR]
[TR]
[TD]P0405
P0406[/TD]
[TD]DTC P0405 00: Exhaust Gas Recirculation (EGR) Position Sensor Circuit Low Voltage
DTC P0406 00: Exhaust Gas Recirculation (EGR) Position Sensor Circuit High Voltage[/TD]
[TD]1.3L (Diesel) engines - DTC P0405 or P0406[/TD]
[/TR]
[TR]
[TD]P0405
P0406[/TD]
[/TR]
[TR]
[TD]P0405
P0406[/TD]
[TD]2.0L (Diesel) engines - DTC P0405 or P0406[/TD]
[/TR]
[TR]
[TD]P0409[/TD]
[TD]DTC P0409: Exhaust Gas Recirculation (EGR) Position Sensor Performance[/TD]
[TD]DTC P0409[/TD]
[/TR]
[TR]
[TD]P0420[/TD]
[TD]DTC P0420 00: Catalyst System Low Efficiency[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0420[/TD]
[/TR]
[TR]
[TD]P0420[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0420[/TD]
[/TR]
[TR]
[TD]P0442[/TD]
[TD]DTC P0442 00: Evaporative Emission (EVAP) System Small Leak Detected[/TD]
[TD]DTC P0442[/TD]
[/TR]
[TR]
[TD]P0443[/TD]
[TD]DTC P0443 00: Evaporative Emission (EVAP) Purge Solenoid Valve Control Circuit[/TD]
[TD]1.4L (LDD) engines - DTC P0443[/TD]
[/TR]
[TR]
[TD]P0443[/TD]
[TD]1.4L (LUJ) engines - DTC P0443 or P0449[/TD]
[/TR]
[TR]
[TD]P0443[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0443[/TD]
[/TR]
[TR]
[TD]P0446[/TD]
[TD]DTC P0446 00: Evaporative Emission (EVAP) Vent System Performance[/TD]
[TD]DTC P0446[/TD]
[/TR]
[TR]
[TD]P0449[/TD]
[TD]DTC P0449 00: Evaporative Emission (EVAP) Vent Solenoid Valve Control Circuit[/TD]
[TD]DTC P0443 or P0449[/TD]
[/TR]
[TR]
[TD]P0451
P0452
P0453
P0454[/TD]
[TD]DTC P0451 00: Fuel Tank Pressure Sensor Performance
DTC P0452 00: Fuel Tank Pressure Sensor Circuit Low Voltage
DTC P0453 00: Fuel Tank Pressure Sensor Circuit High Voltage
DTC P0454 00: Fuel Tank Pressure Sensor Circuit Intermittent[/TD]
[TD]DTC P0451-P0454[/TD]
[/TR]
[TR]
[TD]P0455[/TD]
[TD]DTC P0455 00: Evaporative Emission (EVAP) System Large Leak Detected[/TD]
[TD]DTC P0455[/TD]
[/TR]
[TR]
[TD]P0461
P0462
P0463
P0464[/TD]
[TD]DTC P0461 00: Fuel Level Sensor 1 Performance
DTC P0461 00: Fuel Level Sensor Performance
DTC P0462 00: Fuel Level Sensor 1 Circuit Low Voltage
DTC P0462 00: Fuel Level Sensor Circuit Low Voltage
DTC P0463 00: Fuel Level Sensor 1 Circuit High Voltage
DTC P0463 00: Fuel Level Sensor Circuit High Voltage
DTC P0464 00: Fuel Level Sensor Circuit Intermittent[/TD]
[TD]DTC P0461-P0464[/TD]
[/TR]
[TR]
[TD]P0480[/TD]
[TD]DTC P0480: Cooling Fan Relay 1 Control Circuit[/TD]
[TD]DTC P0480-P0482 or P0691-P0696[/TD]
[/TR]
[TR]
[TD]P0480[/TD]
[TD]DTC P0480: Cooling Fan Relay 1 Control Circuit Malfunction[/TD]
[TD]2.0L Diesel engines with M36 - DTC P0480, P0691, or P0692[/TD]
[/TR]
[TR]
[TD]P0480[/TD]
[TD]DTC P0480 00: Cooling Fan Relay 1 Control Circuit Malfunction[/TD]
[TD]1.4L, 1.6L, and 1.8L engines - DTC P0480 or P0481[/TD]
[/TR]
[TR]
[TD]P0481[/TD]
[TD]DTC P0481: Cooling Fan Relay 2 Control Circuit[/TD]
[/TR]
[TR]
[TD][/TD]
[TD]DTC P0481 00: Cooling Fan Relay 2 Control Circuit Malfunction[/TD]
[/TR]
[TR]
[TD]P0482[/TD]
[TD]DTC P0482: Cooling Fan Relay 3 Control Circuit[/TD]
[/TR]
[TR]
[TD]P0489
P0490[/TD]
[TD]DTC P0489 02: Exhaust Gas Recirculation (EGR) Motor Control Circuit Short to Ground
DTC P0489 12: Exhaust Gas Recirculation (EGR) Motor Control Circuit Low Input
DTC P0490 01: Exhaust Gas Recirculation (EGR) Motor Control Circuit Short to Battery
DTC P0490 11: Exhaust Gas Recirculation (EGR) Motor Control Circuit High Input[/TD]
[/TR]
[TR]
[TD]P0489
P0490[/TD]
[/TR]
[TR]
[TD]P0496[/TD]
[TD]DTC P0496 00: Evaporative Emission (EVAP) System Flow During Non-Purge[/TD]
[TD]DTC P0496[/TD]
[/TR]
[TR]
[TD]P0500
P0501
P0502
P0503[/TD]
[TD]DTC P0500: Vehicle Speed Sensor Circuit
DTC P0501: Vehicle Speed Sensor Performance
DTC P0502: Vehicle Speed Sensor Circuit Low Voltage
DTC P0503: Vehicle Speed Sensor Circuit Intermittent[/TD]
[TD]DTC P0500-P0503[/TD]
[/TR]
[TR]
[TD]P0504[/TD]
[TD]DTC P0504: Brake Switch Circuits 1-2 Not Plausible[/TD]
[TD]DTC P0504, P0571, or P0703[/TD]
[/TR]
[TR]
[TD]P0506
P0507[/TD]
[TD]DTC P0506 00: Idle Speed Low
DTC P0507 00: Idle Speed High[/TD]
[TD]DTC P0506 or P0507[/TD]
[/TR]
[TR]
[TD]P050A[/TD]
[TD]DTC P050A 00: Cold Start Idle Air Control System Performance[/TD]
[TD]DTC P050A[/TD]
[/TR]
[TR]
[TD]P050B[/TD]
[TD]DTC P050B 00: Cold Start Ignition Timing Performance[/TD]
[TD]DTC P050B[/TD]
[/TR]
[TR]
[TD]P050D[/TD]
[TD]DTC P050D: Cold Start Rough Idle[/TD]
[TD]DTC P050D[/TD]
[/TR]
[TR]
[TD]P050E[/TD]
[TD]DTC P050E 00: Cold Start Exhaust Low Temperature[/TD]
[TD]DTC P050E[/TD]
[/TR]
[TR]
[TD]P0513[/TD]
[TD]DTC P0513: Immobilizer Key Incorrect[/TD]
[TD]DTC P0513[/TD]
[/TR]
[TR]
[TD]P0520[/TD]
[TD]DTC P0520 00: Engine Oil Pressure Switch Circuit Malfunction[/TD]
[TD]DTC P0520[/TD]
[/TR]
[TR]
[TD]P0521
P0522
P0523[/TD]
[TD]DTC P0521: Engine Oil Pressure Sensor Performance
DTC P0522: Engine Oil Pressure Sensor Circuit Low Voltage
DTC P0523: Engine Oil Pressure Sensor Circuit High Voltage[/TD]
[TD]DTC P0521, P0522, or P0523[/TD]
[/TR]
[TR]
[TD]P052E[/TD]
[TD]DTC P052E 00: Positive Crankcase Ventilation Heater Performance[/TD]
[TD]1.3L (Diesel) engines - DTC P052E or P053A-P053C[/TD]
[/TR]
[TR]
[TD]P052E[/TD]
[TD]2.0L (Diesel) engines - DTC P052E or P053A-P053C[/TD]
[/TR]
[TR]
[TD]P0532
P0533[/TD]
[TD]DTC P0532: Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit Low Voltage
DTC P0533: Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit High Voltage[/TD]
[TD]HVAC Automatic - DTC P0532 or P0533[/TD]
[/TR]
[TR]
[TD]P0532
P0533[/TD]
[TD]HVAC Manual - DTC P0532 or P0533[/TD]
[/TR]
[TR]
[TD]P053A
P053B
P053C[/TD]
[TD]DTC P053A 00: Positive Crankcase Ventilation Heater Control Circuit Malfunction
DTC P053B 00: Positive Crankcase Ventilation Heater Control Circuit Low Voltage
DTC P053C 00: Positive Crankcase Ventilation Heater Control Circuit High Voltage[/TD]
[/TR]
[TR]
[TD]P053A
P053B
P053C[/TD]
[/TR]
[TR]
[TD]P0545
P0546[/TD]
[TD]DTC P0545 12: Exhaust Gas Temperature Sensor 1 Circuit Low Voltage
DTC P0546 11: Exhaust Gas Temperature Sensor 1 Circuit High Voltage[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P0545 or P0546[/TD]
[/TR]
[TR]
[TD]P0545
P0546[/TD]
[TD]DTC P0545: Exhaust Gas Temperature Sensor 1 Circuit Low Voltage
DTC P0546: Exhaust Gas Temperature Sensor 1 Circuit High Voltage[/TD]
[TD]2.0L (Diesel) engines - DTC P0545 or P0546[/TD]
[/TR]
[TR]
[TD]P0557
P0558[/TD]
[TD]DTC P0557 00: Brake Servo Pressure Sensor Circuit Low Voltage
DTC P0558 00: Brake Servo Pressure Sensor Circuit High Voltage[/TD]
[TD]DTC P0557 or P0558[/TD]
[/TR]
[TR]
[TD]P0560[/TD]
[TD]DTC P0560: System Voltage - ECM[/TD]
[TD]DTC P0560[/TD]
[/TR]
[TR]
[TD]P0562[/TD]
[TD]DTC P0562: System Voltage Low Voltage[/TD]
[TD]DTC P0562
or
Transmission Control Module (TCM) - DTC P0562 or P0563[/TD]
[/TR]
[TR]
[TD]P0563[/TD]
[TD]DTC P0563: System Voltage High Voltage[/TD]
[TD]DTC P0563
or
TCM - DTC P0562 or P0563[/TD]
[/TR]
[TR]
[TD]P0564[/TD]
[TD]DTC P0564 00: Cruise Control Multifunction Switch Circuit Malfunction[/TD]
[TD]DTC P0564[/TD]
[/TR]
[TR]
[TD]P0565[/TD]
[TD]DTC P0565 00: Cruise Control Switch Circuit Malfunction[/TD]
[TD]DTC P0565[/TD]
[/TR]
[TR]
[TD]P0567[/TD]
[TD]DTC P0567 00: Cruise Control Resume Switch Circuit Malfunction[/TD]
[TD]DTC P0567[/TD]
[/TR]
[TR]
[TD]P0568[/TD]
[TD]DTC P0568 00: Cruise Control Set Switch Circuit Malfunction[/TD]
[TD]DTC P0568[/TD]
[/TR]
[TR]
[TD]P056C[/TD]
[TD]DTC P056C 00: Cruise Control Cancel Switch Circuit Malfunction[/TD]
[TD]DTC P056C[/TD]
[/TR]
[TR]
[TD]P0571[/TD]
[TD]DTC P0571: Brake Switch Circuit 1[/TD]
[/TR]
[TR]
[TD]P0572
P0573[/TD]
[TD]DTC P0572: Brake Switch Circuit 1 Low Voltage
DTC P0573: Brake Switch Circuit 1 High Voltage[/TD]
[TD]DTC P0572 or P0573[/TD]
[/TR]
[TR]
[TD]P0575[/TD]
[TD]DTC P0575: Cruise Control Switch Signal Message Counter Incorrect[/TD]
[TD]DTC P0575[/TD]
[/TR]
[TR]
[TD]P057B
P057C
P057D
P057E[/TD]
[TD]DTC P057B 00: Brake Pedal Position Sensor Performance
DTC P057C 00: Brake Pedal Position Sensor Circuit Low Voltage
DTC P057D 00: Brake Pedal Position Sensor Circuit High Voltage
DTC P057E 00: Brake Pedal Position Sensor Circuit Erratic[/TD]
[TD]DTC P057B-P057E[/TD]
[/TR]
[TR]
[TD]P0580
P0581[/TD]
[TD]DTC P0580 00: Cruise Control Multifunction Switch Circuit Low Voltage
DTC P0581 00: Cruise Control Multifunction Switch Circuit High Voltage[/TD]
[TD]DTC P0580 or P0581[/TD]
[/TR]
[TR]
[TD]P0597
P0598
P0599[/TD]
[TD]DTC P0597 00: Engine Coolant Thermostat Heater Control Circuit
DTC P0598 00: Engine Coolant Thermostat Heater Control Circuit Low Voltage
DTC P0599 00: Engine Coolant Thermostat Heater Control Circuit High Voltage[/TD]
[TD]DTC P0597-P0599[/TD]
[/TR]
73
9:th-Apr-2015, 09:02:11
(This post was last modified: 2:nd-Apr-2022, 08:50:55 by Rusty2009.)
Codes P continued
[TR]
[TD]DTC[/TD]
[/TR]
[TR]
[TD]P0601[/TD]
[TD]DTC P0601 00: Control Module Read Only Memory Performance[/TD]
[TD]1.4L (LDD) engines - DTC P0601-P0604, P0606, P0607, P16F3, or P2610[/TD]
[/TR]
[TR]
[TD]P0601[/TD]
[TD]1.4L (LUJ) engines - DTC P0601-P0604, P0606, P062F, P16F3, or P2610[/TD]
[/TR]
[TR]
[TD]P0601[/TD]
[TD]1.6L (LLU) engines - DTC P0601-P0604, P0606, P0607, P16F3, or P2610[/TD]
[/TR]
[TR]
[TD]P0601[/TD]
[TD]DTC P0601: Control Module Read Only Memory (ROM)[/TD]
[TD]Fuel pump control module 1.4L (LDD, LUH, or LUJ) engines - DTC P0601-P0604, P0606, or P062F[/TD]
[/TR]
[TR]
[TD]P0601[/TD]
[TD]Fuel pump control module 1.6L (LDE, LLU, or LXV)
1.8L (2H0) engines - DTC P0601-P0604, P0606, or P062F[/TD]
[/TR]
[TR]
[TD]P0601[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P0601, P0606, P060A, P060E, P0610, P061A, P062A, P062B, or P062F[/TD]
[/TR]
[TR]
[TD]P0601[/TD]
[TD]DTC P0601: Control Module Read Only Memory Performance[/TD]
[TD]Automatic Transmission AF40-6 - DTC P0601, P0602, P0603, or P0604[/TD]
[/TR]
[TR]
[TD]P0601[/TD]
[TD]Automatic Transmission 6T30/6T40/6T45/6T50 - DTC P0601-P0604 or P062F[/TD]
[/TR]
[TR]
[TD]P0602[/TD]
[TD]DTC P0602 00: Control Module Not Programmed[/TD]
[TD]1.3L (Diesel) engines - DTC P0602, P0605-P0607, P060A, P060B, P0610, P061A, P061C, P062B, or P062F[/TD]
[/TR]
[TR]
[TD]P0602[/TD]
[/TR]
[TR]
[TD]P0602[/TD]
[/TR]
[TR]
[TD]P0602[/TD]
[/TR]
[TR]
[TD]P0602[/TD]
[TD]2.0L (Diesel) engines - DTC P0602, P0605-P0607, P060A, P060B, P0610, P061A, P061C, P062B, or P062F[/TD]
[/TR]
[TR]
[TD]P0602[/TD]
[TD]DTC P0602: Control Module Not Programmed[/TD]
[/TR]
[TR]
[TD]P0602[/TD]
[TD]Fuel pump control module 1.6L (LDE, LLU, or LXV) 1.8L (2H0) engines - DTC P0601-P0604, P0606, or P062F[/TD]
[/TR]
[TR]
[TD]P0602[/TD]
[/TR]
[TR]
[TD]P0602[/TD]
[/TR]
[TR]
[TD]P0603[/TD]
[TD]DTC P0603 00: Control Module Long Term Memory Reset[/TD]
[/TR]
[TR]
[TD]P0603[/TD]
[/TR]
[TR]
[TD]P0603[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0601-P0604, P0606, P0607, P16F3, or P2610[/TD]
[/TR]
[TR]
[TD]P0603[/TD]
[TD]DTC P0603: Control Module Long Term Memory Reset[/TD]
[/TR]
[TR]
[TD]P0603[/TD]
[/TR]
[TR]
[TD]P0603[/TD]
[/TR]
[TR]
[TD]P0603[/TD]
[/TR]
[TR]
[TD]P0604[/TD]
[TD]DTC P0604 00: Control Module Random Access Memory Performance[/TD]
[/TR]
[TR]
[TD]P0604[/TD]
[/TR]
[TR]
[TD]P0604[/TD]
[/TR]
[TR]
[TD]P0604[/TD]
[TD]DTC P0604: Control Module Random Access Memory (RAM)[/TD]
[/TR]
[TR]
[TD]P0604[/TD]
[/TR]
[TR]
[TD]P0604[/TD]
[TD]DTC P0604: Control Module Random Access Memory Performance[/TD]
[/TR]
[TR]
[TD]P0604[/TD]
[/TR]
[TR]
[TD]P0605[/TD]
[TD]DTC P0605 00: Control Module Programming Read Only Memory Performance[/TD]
[/TR]
[TR]
[TD]P0605[/TD]
[/TR]
[TR]
[TD]P0606[/TD]
[TD]DTC P0606 38: Control Module Processor Performance Supervision Software Malfunction
DTC P0606 3A: Control Module Processor Performance Incorrect Component Installed
DTC P0606 3C: Control Module Processor Performance Internal Communication Malfunction[/TD]
[/TR]
[TR]
[TD]P0606[/TD]
[TD]DTC P0606 00: Control Module Processor Performance[/TD]
[/TR]
[TR]
[TD]P0606[/TD]
[/TR]
[TR]
[TD]P0606[/TD]
[/TR]
[TR]
[TD]P0606[/TD]
[/TR]
[TR]
[TD]P0606[/TD]
[/TR]
[TR]
[TD]P0606[/TD]
[TD]DTC P0606: Control Module Internal Performance[/TD]
[/TR]
[TR]
[TD]P0606[/TD]
[/TR]
[TR]
[TD]P0607[/TD]
[TD]DTC P0607 03: Control Module Performance
DTC P0607 07: Control Module Performance
DTC P0607 39: Control Module Performance
DTC P0607 3B: Control Module Performance
DTC P0607 3D: Control Module Performance
DTC P0607 3E: Control Module Performance
DTC P0607 58: Control Module Performance[/TD]
[/TR]
[TR]
[TD]P0607[/TD]
[TD]DTC P0607 00: Control Module Performance[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0601-P0604, P0606, P0607, P16F3, or P2610[/TD]
[/TR]
[TR]
[TD]P0607[/TD]
[/TR]
[TR]
[TD]P0607[/TD]
[TD]DTC P0607 03: Control Module Performance Malfunction
DTC P0607 07: Control Module Performance Malfunction
DTC P0607 39: Control Module Performance Internal Malfunction
DTC P0607 3B: Control Module Performance Self-Test Malfunction
DTC P0607 3D: Control Module Performance Malfunction
DTC P0607 3E: Control Module Performance Malfunction
[/TR]
[TR]
[TD]P060A[/TD]
[TD]DTC P060A 3B: Control Module Monitoring Processor Performance Self-Test Malfunction
DTC P060A 3C: Control Module Monitoring Processor Performance Internal Communication Malfunction[/TD]
[/TR]
[TR]
[TD]P060A[/TD]
[TD]DTC P060A 00: Control Module Monitoring Processor Performance[/TD]
[/TR]
[TR]
[TD]P060A[/TD]
[/TR]
[TR]
[TD]P060B[/TD]
[TD]DTC P060B 38: Control Module Analog to Digital Converter Performance Supervision Software Malfunction
DTC P060B 39: Control Module Analog to Digital Converter Performance Internal Malfunction
DTC P060B 3B: Control Module Analogue to Digital Converter Performance Self-Test Malfunction
DTC P060B 55: Control Module Analog to Digital Converter Performance Too Few Transitions
DTC P060B 56: Control Module Analog to Digital Converter Performance Too Many Transitions[/TD]
[/TR]
[TR]
[TD]P060B[/TD]
DTC P060B 3B: Control Module Analog to Digital Converter Performance Self-Test Malfunction
DTC P060B 57: Control Module Analog to Digital Converter Performance Malfunction
DTC P060B 58: Control Module Analog to Digital Converter Performance[/TD]
[/TR]
[TR]
[TD]P060E[/TD]
[TD]DTC P060E 00: Control Module Throttle Position System Circuitry Performance[/TD]
[TD]DTC P0601, P0606, P060A, P060E, P0610, P061A, P062A, P062B, or P062F[/TD]
[/TR]
[TR]
[TD]P0610[/TD]
[TD]DTC P0610 00: Control Module Vehicle Options Incorrect[/TD]
[/TR]
[TR]
[TD]P0610[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0610[/TD]
[/TR]
[TR]
[TD]P0610[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0610[/TD]
[/TR]
[TR]
[TD]P0610[/TD]
[/TR]
[TR]
[TD]P0610[/TD]
[/TR]
[TR]
[TD]P0611[/TD]
[TD]DTC P0611 09: Control Module Performance
DTC P0611 0A: Control Module Performance[/TD]
[TD]1.3L (Diesel) engines - DTC P0611[/TD]
[/TR]
[TR]
[TD]P0611[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P0611[/TD]
[/TR]
[TR]
[TD]P0611[/TD]
[TD]2.0L (Diesel) engines - DTC P0611[/TD]
[/TR]
[TR]
[TD]P0615
P0616
P0617[/TD]
[TD]DTC P0615: Starter Relay Control Circuit
DTC P0616: Starter Relay Control Circuit Low Voltage
DTC P0617: Starter relay Control Circuit High Voltage[/TD]
[TD]DTC P0615, P0616, or P0617[/TD]
[/TR]
[TR]
[TD]P061A[/TD]
[TD]DTC P061A 51: Control Module Torque System Circuitry Performance[/TD]
[/TR]
[TR]
[TD]P061A[/TD]
[TD]DTC P061A 00: Control Module Torque System Circuitry Performance[/TD]
[/TR]
[TR]
[TD]P061A[/TD]
[TD]DTC P061A 51: Control Module Torque System Circuitry Performance Malfunction[/TD]
[/TR]
[TR]
[TD]P061C[/TD]
[TD]DTC P061C 00: Control Module Engine Speed System Circuitry Performance Malfunction[/TD]
[/TR]
[TR]
[TD]P061C[/TD]
[/TR]
[TR]
[TD]P0621[/TD]
[TD]DTC P0621: Generator L-Terminal Circuit[/TD]
[TD]DTC P0621[/TD]
[/TR]
[TR]
[TD]P0622[/TD]
[TD]DTC P0622: Generator F-Terminal Circuit Malfunction[/TD]
[TD]DTC P0622[/TD]
[/TR]
[TR]
[TD]P0625
P0626[/TD]
[TD]DTC P0625: Generator F-Terminal Circuit Low Voltage
DTC P0626: Generator F-Terminal Circuit High Voltage[/TD]
[TD]DTC P0625 or P0626[/TD]
[/TR]
[TR]
[TD]P0627
P0628
P0629[/TD]
[TD]DTC P0627 00: Fuel Pump Relay Control Circuit Open
DTC P0628 00: Fuel Pump Relay Control Circuit Low Voltage
DTC P0629 00: Fuel Pump Relay Control Circuit High Voltage[/TD]
[TD]1.3L (Diesel) engines - DTC P0627-P0629[/TD]
[/TR]
[TR]
[TD]P0627
P0628
P0629[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0627-P0629[/TD]
[/TR]
[TR]
[TD]P0627
P0628
P0629[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0627-P0629[/TD]
[/TR]
[TR]
[TD]P0627
P0628
P0629[/TD]
[TD]2.0L (Diesel) engines - DTC P0627-P0629[/TD]
[/TR]
[TR]
[TD]P062A[/TD]
[TD]DTC P062A 00: Fuel Pressure Regulator Not Learned[/TD]
[/TR]
[TR]
[TD]P062A[/TD]
[TD]DTC P062A 00: Fuel Pump Relay Control Circuit Open[/TD]
[TD]1.3L (Diesel) engines - DTC P062A[/TD]
[/TR]
[TR]
[TD]P062A[/TD]
[TD]2.0L (Diesel) engines - DTC P062A[/TD]
[/TR]
[TR]
[TD]P062B[/TD]
[TD]DTC P062B 41: Fuel Injection Small Quantity Not Learned[/TD]
[/TR]
[TR]
[TD]P062B[/TD]
[TD]DTC P062B 31: Control Module Fuel Injector Control Performance
DTC P062B 32: Control Module Fuel Injector Control Performance
DTC P062B 33: Control Module Fuel Injector Control Performance
DTC P062B 34: Control Module Fuel Injector Control Performance
DTC P062B 35: Control Module Fuel Injector Control Performance
DTC P062B 36: Control Module Fuel Injector Control Performance
DTC P062B 38: Control Module Fuel Injector Control Performance
DTC P062B 39: Control Module Fuel Injector Control Performance
DTC P062B 3A: Control Module Fuel Injector Control Performance
DTC P062B 3B: Control Module Fuel Injector Control Performance
DTC P062B 3C: Control Module Fuel Injector Control Performance
DTC P062B 3D: Control Module Fuel Injector Control Performance
DTC P062B 3E: Control Module Fuel Injector Control Performance
DTC P062B 3F: Control Module Fuel Injector Control Performance
DTC P062B 40: Control Module Fuel Injector Control Performance
DTC P062B 57: Control Module Fuel Injector Control Performance
DTC P062B 58: Control Module Fuel Injector Control Performance
DTC P062B 59: Control Module Fuel Injector Control Performance
DTC P062B 5A: Control Module Fuel Injector Control Performance
DTC P062B 5B: Control Module Fuel Injector Control Performance[/TD]
[/TR]
[TR]
[TD]P062B[/TD]
[TD]DTC P062B 31: Control Module Fuel Injector Control Performance Internal Checksum Error
DTC P062B 32: Control Module Fuel Injector Control Performance General Memory Malfunction
DTC P062B 33: Control Module Fuel Injector Control Performance Special Memory Malfunction
DTC P062B 34: Control Module Fuel Injector Control Performance RAM Malfunction
DTC P062B 35: Control Module Fuel Injector Control Performance ROM Malfunction
DTC P062B 36: Control Module Fuel Injector Control Performance EEPROM Performance/Malfunction
DTC P062B 38: Control Module Fuel Injector Control Performance Supervision Software Malfunction
DTC P062B 39: Control Module Fuel Injector Control Performance Internal Malfunction
DTC P062B 3A: Control Module Fuel Injector Control Performance Incorrect Component Installed
DTC P062B 3B: Control Module Fuel Injector Control Performance Self-Test Malfunction
DTC P062B 3C: Control Module Fuel Injector Control Performance Internal Communication Malfunction
DTC P062B 3D: Control Module Fuel Injector Control Performance Malfunction
DTC P062B 3E: Control Module Fuel Injector Control Performance Malfunction
DTC P062B 3F: Control Module Fuel Injector Control Performance Malfunction
DTC P062B 40: Control Module Fuel Injector Control Performance Malfunction
DTC P062B 57: Control Module Fuel Injector Control Performance Malfunction
DTC P062B 59: Control Module Fuel Injector Control Performance Protection Time-Out
DTC P062B 5A: Control Module Fuel Injector Control Performance Not Plausible
DTC P062B 5B: Control Module Fuel Injector Control Performance Malfunction[/TD]
[/TR]
[TR]
[TD]P062D
P062E[/TD]
[TD]DTC P062D 00: Injector High Control Circuit Group 1 Malfunction
DTC P062E 00: Injector High Control Circuit Group 2 Malfunction[/TD]
[TD]1.3L (Diesel) engines - DTC P062D or P062E[/TD]
[/TR]
[TR]
[TD]P062D
P062E[/TD]
[TD]2.0L (Diesel) engines - DTC P062D or P062E[/TD]
[/TR]
[TR]
[TD]P062F[/TD]
[TD]DTC P062F 00: Control Module Long Term Memory Performance[/TD]
[/TR]
[TR]
[TD]P062F[/TD]
[TD]DTC P062F 31: Control Module Long Term Memory Performance Internal Checksum Error
DTC P062F 32: Control Module Long Term Memory Performance General Memory Malfunction
DTC P062F 33: Control Module Long Term Memory Performance Special Memory Malfunction
DTC P062F 34: Control Module Long Term Memory Performance RAM Malfunction
DTC P062F 35: Control Module Long Term Memory Performance ROM Malfunction
DTC P062F 36: Control Module Long Term Memory Performance EEPROM Performance/Malfunction
DTC P062F 37: Control Module Long Term Memory Performance Software Malfunction[/TD]
[/TR]
[TR]
[TD]P062F[/TD]
[TD]DTC P062F: Control Module Long Term Memory Performance[/TD]
[/TR]
[TR]
[TD]P062F[/TD]
[TD]Fuel pump control module 1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0601-P0604, P0606, or P062F[/TD]
[/TR]
[TR]
[TD]P062F[/TD]
[/TR]
[TR]
[TD]P062F[/TD]
[/TR]
[TR]
[TD]P062F[/TD]
[/TR]
[TR]
[TD]P0630[/TD]
[TD]DTC P0630 00: VIN Not Programmed or Mismatched - Engine Control Module (ECM)[/TD]
[TD]1.3L (Diesel) engines - DTC P0630[/TD]
[/TR]
[TR]
[TD]P0630[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0630[/TD]
[/TR]
[TR]
[TD]P0630[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0630[/TD]
[/TR]
[TR]
[TD]P0630[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P0630[/TD]
[/TR]
[TR]
[TD]P0630[/TD]
[TD]2.0L (Diesel) engines - DTC P0630[/TD]
[/TR]
[TR]
[TD]P0633[/TD]
[TD]DTC P0633: Immobilizer Key Not Programmed[/TD]
[TD]1.7L Diesel engines - DTC P0633
or
DTC P0633[/TD]
[/TR]
[TR]
[TD]P0634[/TD]
[TD]DTC P0634: Control Module Over-Temperature[/TD]
[TD]DTC P0634[/TD]
[/TR]
[TR]
[TD]P0641[/TD]
[TD]DTC P0641 00: 5V Reference 1 Circuit Malfunction[/TD]
[TD]1.3L (Diesel) engines - DTC P0641[/TD]
[/TR]
[TR]
[TD]P0641[/TD]
[TD]DTC P0641 00: 5V Reference 1 Circuit[/TD]
[TD]1.4L (LDD) engines - DTC P0641, P0651, P0697, or P06A3[/TD]
[/TR]
[TR]
[TD]P0641[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0641, P0651, P0697, or P06A3[/TD]
[/TR]
[TR]
[TD]P0641[/TD]
[TD]2.0L (Diesel) engines - DTC P0641[/TD]
[/TR]
[TR]
[TD]P0641[/TD]
[TD]DTC P0641: 5 V Reference Circuit[/TD]
[TD]Fuel pump control module 1.4L (LDD, LUH, or LUJ) engines - DTC P0641 or P06A6[/TD]
[/TR]
[TR]
[TD]P0641[/TD]
[TD]Fuel pump control module 1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0641 or P06A6[/TD]
[/TR]
[TR]
[TD]P0642
P0643[/TD]
[TD]DTC P0642: 5V Reference 1 Circuit Low Voltage
DTC P0643: 5V Reference 1 Circuit High Voltage[/TD]
[TD]DTC P0642 or P0643[/TD]
[/TR]
[TR]
[TD]P0645
P0646
P0647[/TD]
[TD]DTC P0645 00: Air Conditioning (A/C) Compressor Clutch Relay Control Circuit Malfunction
DTC P0646 00: Air Conditioning (A/C) Compressor Clutch Relay Control Circuit Low Voltage
DTC P0647 00: Air Conditioning (A/C) Compressor Clutch Relay Control Circuit High Voltage[/TD]
[TD]HVAC Automatic - DTC P0645, P0646, or P0647[/TD]
[/TR]
[TR]
[TD]P0645
P0646
P0647[/TD]
[TD]HVAC Manual - DTC P0645, P0646, or P0647[/TD]
[/TR]
[TR]
[TD]P064A[/TD]
[TD]DTC P064A: Fuel Pump Control Module Performance[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P1255 or P064A[/TD]
[/TR]
[TR]
[TD]P064A[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P1255 or P064A[/TD]
[/TR]
[TR]
[TD]P064C[/TD]
[TD]DTC P064C 00: Glow Plug Control Module Performance
DTC P064C 04: Glow Plug Control Module Performance
DTC P064C 54: Glow Plug Control Module Performance[/TD]
[TD]1.3L (Diesel) engines - DTC P064C[/TD]
[/TR]
[TR]
[TD]P064C[/TD]
[TD]2.0L (Diesel) engines - DTC P064C[/TD]
[/TR]
[TR]
[TD]P064D[/TD]
[TD]DTC P064D 39: Control Module HO2S 1 System Circuitry Performance
DTC P064D 3B: Control Module HO2S 1 System Circuitry Performance
DTC P064D 54: Control Module HO2S 1 System Circuitry Performance[/TD]
[TD]1.3L (Diesel) engines - DTC P064D[/TD]
[/TR]
[TR]
[TD]P064D[/TD]
[TD]2.0L (Diesel) engines - DTC P064D[/TD]
[/TR]
[TR]
[TD]P0650[/TD]
[TD]DTC P0650 00: Malfunction Indicator Lamp (MIL) Control Circuit[/TD]
[TD]DTC P0650[/TD]
[/TR]
[TR]
[TD]P0651[/TD]
[TD]DTC P0651 00: 5V Reference 2 Circuit Malfunction[/TD]
[TD]1.3L (Diesel) engines - DTC P0651[/TD]
[/TR]
[TR]
[TD]P0651[/TD]
[TD]DTC P0651 00: 5V Reference 2 Circuit[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0641, P0651, P0697, or P06A3[/TD]
[/TR]
[TR]
[TD]P0651[/TD]
[/TR]
[TR]
[TD]P0651[/TD]
[TD]2.0L (Diesel) engines - DTC P0651[/TD]
[/TR]
[TR]
[TD]P0652
P0653[/TD]
[TD]DTC P0652: 5V Reference 2 Circuit Low Voltage
DTC P0653: 5V Reference 2 Circuit High Voltage[/TD]
[TD]DTC P0652 or P0653[/TD]
[/TR]
[TR]
[TD]P0657[/TD]
[TD]DTC P0657 00: Actuator High Control Circuit Group Malfunction[/TD]
[TD]DTC P0657[/TD]
[/TR]
[TR]
[TD]P0658
P0659[/TD]
[TD]DTC P0658 00: Actuator High Control Circuit Group 1 Low Voltage
DTC P0659 00: Actuator High Control Circuit Group 1 High Voltage[/TD]
[TD]1.3L (Diesel) engines - DTC P0658 or P0659[/TD]
[/TR]
[TR]
[TD]P0658
P0659[/TD]
[TD]2.0L (Diesel) engines - DTC P0658 or P0659[/TD]
[/TR]
[TR]
[TD]P0658
P0659[/TD]
[TD]DTC P0658: Actuator High Control Circuit Group 1 Low Voltage
DTC P0659: Actuator High Control Circuit Group 1 High Voltage[/TD]
[TD]Automatic Transmission 6T30/6T40/6T45/6T50 - DTC P0658 or P0659[/TD]
[/TR]
[TR]
[TD]P0660[/TD]
[TD]DTC P0660 00: Intake Manifold Tuning Control Valve Control Circuit[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0660[/TD]
[/TR]
[TR]
[TD]P0660[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0660[/TD]
[/TR]
[TR]
[TD]P0667
P0668
P0669[/TD]
[TD]DTC P0667: Control Module Temperature Sensor Performance
DTC P0668: Control Module Temperature Sensor Circuit Low Voltage
DTC P0669: Control Module Temperature Sensor Circuit High Voltage[/TD]
[TD]DTC P0667, P0668, or P0669[/TD]
[/TR]
[TR]
[TD]P066A
P066C
P066E[/TD]
[TD]DTC P066A 00: Cylinder 1 Glow Plug Control Circuit Low Voltage
DTC P066C 00: Cylinder 2 Glow Plug Control Circuit Low Voltage
DTC P066E 00: Cylinder 3 Glow Plug Control Circuit Low Voltage[/TD]
[TD]1.3L (Diesel) engines - DTC P066A, P066C, P066E, or P067A[/TD]
[/TR]
[TR]
[TD]P066A
P066C
P066E[/TD]
[TD]2.0L (Diesel) engines - DTC P066A, P066C, P066E, or P067A[/TD]
[/TR]
[TR]
[TD]P0671
P0672
P0673
P0674[/TD]
[TD]DTC P0671 00: Cylinder 1 Glow Plug Control Circuit Malfunction
DTC P0672 00: Cylinder 2 Glow Plug Control Circuit Malfunction
DTC P0673 00: Cylinder 3 Glow Plug Control Circuit Malfunction
DTC P0674 00: Cylinder 4 Glow Plug Control Circuit Malfunction[/TD]
[TD]1.3L (Diesel) engines - DTC P0671, P0672, P0673, or P0674[/TD]
[/TR]
[TR]
[TD]P0671
P0672
P0673
P0674[/TD]
[TD]2.0L (Diesel) engines - DTC P0671, P0672, P0673, or P0674[/TD]
[/TR]
[TR]
[TD]P067A[/TD]
[TD]DTC P067A 00: Cylinder 4 Glow Plug Control Circuit Low Voltage[/TD]
[/TR]
[TR]
[TD]P067A[/TD]
[/TR]
[TR]
[TD]P0685[/TD]
[TD]DTC P0685 00: Engine Controls Ignition Relay Control Circuit[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0685, P0689, or P0690[/TD]
[/TR]
[TR]
[TD]P0685[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0685, P0689, or P0690[/TD]
[/TR]
[TR]
[TD]P0686
P0687[/TD]
[TD]DTC P0686 00: Engine Controls Ignition Relay Control Circuit Low Voltage
DTC P0687 00: Engine Controls Ignition Relay Control Circuit High Voltage[/TD]
[TD]DTC P0686, P0687, P0689, or P0690[/TD]
[/TR]
[TR]
[TD]P0689[/TD]
[TD]DTC P0689 00: Engine Controls Ignition Relay Feedback Circuit Low Voltage[/TD]
[/TR]
[TR]
[TD]P0689[/TD]
[/TR]
[TR]
[TD]P0689[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P0686, P0687, P0689, or P0690[/TD]
[/TR]
[TR]
[TD]P068A
P068B[/TD]
[TD]DTC P068A 00: Engine Controls Ignition Relay De-Energized Too Early
DTC P068B 00: Engine Controls Ignition Relay De-Energized Too Late[/TD]
[TD]1.3L (Diesel) engines - DTC P068A or P068B[/TD]
[/TR]
[TR]
[TD]P068A
P068B[/TD]
[TD]2.0L (Diesel) engines - DTC P068A or P068B[/TD]
[/TR]
[TR]
[TD]P0690[/TD]
[TD]DTC P0690 00: Engine Controls Ignition Relay Feedback Circuit High Voltage[/TD]
[/TR]
[TR]
[TD]P0690[/TD]
[/TR]
[TR]
[TD]P0690[/TD]
[/TR]
![[Image: vx.o.c.jpeg]](http://www.vxoc.org.uk/Images/vxoc%20astra-j-gtc/Logo/vx.o.c.jpeg)
73
9:th-Apr-2015, 09:18:18
(This post was last modified: 2:nd-Apr-2022, 08:51:29 by Rusty2009.)
Codes P continued
[TR]
[TD]DTC[/TD]
[/TR]
[TR]
[TD]P0691
P0692[/TD]
[TD]DTC P0691: Cooling Fan Relay 1 Control Circuit Low Voltage
DTC P0692: Cooling Fan Relay 1 Control Circuit High Voltage[/TD]
[TD]2.0L Diesel - DTC P0480-P0482 or P0691-P0696[/TD]
[/TR]
[TR]
[TD]P0691
P0692[/TD]
[TD]1.7L Diesel - DTC P0691-P0696[/TD]
[/TR]
[TR]
[TD]P0691
P0692[/TD]
[TD]2.0L Diesel with M36 - DTC P0480, P0691, or P0692[/TD]
[/TR]
[TR]
[TD]P0693
P0694
P0695
P0696[/TD]
[TD]DTC P0693: Cooling Fan Relay 2 Control Circuit Low Voltage
DTC P0694: Cooling Fan Relay 2 Control Circuit High Voltage
DTC P0695: Cooling Fan Relay 3 Control Circuit Low Voltage
DTC P0696: Cooling Fan Relay 3 Control Circuit High Voltage[/TD]
[/TR]
[TR]
[TD]P0693
P0694
P0695
P0696[/TD]
[/TR]
[TR]
[TD]P0697[/TD]
[TD]DTC P0697 00: 5V Reference 3 Circuit Malfunction[/TD]
[TD]1.3L (Diesel) engines - DTC P0697[/TD]
[/TR]
[TR]
[TD]P0697[/TD]
[TD]DTC P0697 00: 5V Reference 3 Circuit[/TD]
[/TR]
[TR]
[TD]P0697[/TD]
[/TR]
[TR]
[TD]P0697[/TD]
[TD]2.0L (Diesel) engines - DTC P0697[/TD]
[/TR]
[TR]
[TD]P069E[/TD]
[TD]DTC P069E: Fuel Pump Control Module Requested MIL Illumination[/TD]
[TD]DTC P069E[/TD]
[/TR]
[TR]
[TD]P06A3[/TD]
[TD]DTC P06A3 00: 5V Reference 4 Circuit[/TD]
[/TR]
[TR]
[TD]P06A3[/TD]
[/TR]
[TR]
[TD]P06A6[/TD]
[TD]DTC P06A6: 5 V Reference Performance[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0641 or P06A6[/TD]
[/TR]
[TR]
[TD]P06A6[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0641 or P06A6[/TD]
[/TR]
[TR]
[TD]P06AC
P06AD
P06AE[/TD]
[TD]DTC P06AC: Transmission Control Module Power Up Temperature Sensor Performance
DTC P06AD: Transmission Control Module Power Up Temperature Sensor Circuit Low Voltage
DTC P06AE: Transmission Control Module Power Up Temperature Sensor Circuit High Voltage[/TD]
[TD]DTC P06AC, P06AD, or P06AE[/TD]
[/TR]
[TR]
[TD]P06B6[/TD]
[TD]DTC P06B6 00: Control Module Knock Sensor Processor 1 Performance[/TD]
[/TR]
[TR]
[TD]P06B6[/TD]
[/TR]
[TR]
[TD]P06B6[/TD]
[TD]1.6L (LDE) engines - DTC P0324 or P06B6[/TD]
[/TR]
[TR]
[TD]P06B6[/TD]
[TD]1.6L (LLU) engines - DTC P0324, P0326, or P06B6[/TD]
[/TR]
[TR]
[TD]P0700[/TD]
[TD]DTC P0700 00: Transmission Control Module Requested MIL Illumination[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0700[/TD]
[/TR]
[TR]
[TD]P0700[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0700[/TD]
[/TR]
[TR]
[TD]P0703[/TD]
[TD]DTC P0703: Brake Switch Circuit 2[/TD]
[TD]Cruise Control - DTC P0703
or
Lighting - DTC P0504, P0571, or P0703[/TD]
[/TR]
[TR]
[TD]P0706
P0707
P0708[/TD]
[TD]DTC P0706: Park/Neutral Position Switch Circuit
DTC P0707: Park/Neutral Position Switch Circuit Low Voltage
DTC P0708: Park/Neutral Position Switch Circuit High Voltage[/TD]
[TD]DTC P0706-P0708[/TD]
[/TR]
[TR]
[TD]P0711
P0712
P0713[/TD]
[TD]DTC P0711: Transmission Fluid Temperature Sensor Performance
DTC P0712: Transmission Fluid Temperature Sensor Circuit Low Voltage
DTC P0713: Transmission Fluid Temperature Sensor Circuit High Voltage[/TD]
[TD]Automatic Transmission 6T30/6T40/6T45/6T50 - DTC P0711, P0712, or P0713[/TD]
[/TR]
[TR]
[TD]P0711
P0712
P0713[/TD]
[TD]Automatic Transmission AF40-6 - DTC P0711, P0712, or P0713[/TD]
[/TR]
[TR]
[TD]P0715[/TD]
[TD]DTC P0715: Input Speed Sensor Circuit[/TD]
[TD]Automatic Transmission AF40-6 - DTC P0715[/TD]
[/TR]
[TR]
[TD]P0716
P0717
P07BF
P07C0[/TD]
[TD]DTC P0716: Input Speed Sensor Performance
DTC P0717: Input Speed Sensor Circuit No Signal
DTC P07BF: Input Speed Sensor Circuit Low Voltage
DTC P07C0: Input Speed Sensor Circuit High Voltage[/TD]
[TD]DTC P0716, DTC P0717, DTC P07BF, or DTC P07C0[/TD]
[/TR]
[TR]
[TD]P071A[/TD]
[TD]Transmission Tow Mode Switch Circuit[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]P071D[/TD]
[TD]DTC P071D: Transmission Sport Mode Switch circuit[/TD]
[TD]DTC P071D[/TD]
[/TR]
[TR]
[TD]P0720
P0722[/TD]
[TD]DTC P0720: Output Speed Sensor Circuit Performance
DTC P0722: Output Speed Sensor Circuit No Signal[/TD]
[TD]Automatic Transmission AF40-6 - DTC P0720 or P0722[/TD]
[/TR]
[TR]
[TD]P0723
P077C
P077D[/TD]
[TD]DTC P0723: Output Speed Sensor Intermittent
DTC P077C: Output Speed Sensor Circuit Low Voltage
DTC P077D: Output Speed Sensor Circuit High Voltage[/TD]
[TD]DTC P0722, P0723, P077C, or P077D[/TD]
[/TR]
[TR]
[TD]P0729[/TD]
[TD]DTC P0729: 6th Gear Ratio Incorrect[/TD]
[TD]DTC P0729[/TD]
[/TR]
[TR]
[TD]P0731[/TD]
[TD]DTC P0731: 1st Gear Ratio Incorrect[/TD]
[TD]DTC P0731[/TD]
[/TR]
[TR]
[TD]P0732[/TD]
[TD]DTC P0732: 2nd Gear Ratio Incorrect[/TD]
[TD]DTC P0732[/TD]
[/TR]
[TR]
[TD]P0733[/TD]
[TD]DTC P0733: 3rd Gear Ratio Incorrect[/TD]
[TD]DTC P0733[/TD]
[/TR]
[TR]
[TD]P0734[/TD]
[TD]DTC P0734: 4th Gear Ratio Incorrect[/TD]
[TD]DTC P0734[/TD]
[/TR]
[TR]
[TD]P0735[/TD]
[TD]DTC P0735: 5th Gear Ratio Incorrect[/TD]
[TD]DTC P0735[/TD]
[/TR]
[TR]
[TD]P0736[/TD]
[TD]DTC P0731[/TD]
[/TR]
[TR]
[TD]P0741
P0742[/TD]
[TD]DTC P0741: Torque Converter Clutch (TCC) System Stuck Off
DTC P0742: Torque Converter Clutch (TCC) System Stuck On[/TD]
[TD]Automatic Transmission 6T30/6T40/6T45/6T50 - DTC P0741 or P0742[/TD]
[/TR]
[TR]
[TD]P0741
P0742[/TD]
[TD]Automatic Transmission AF40-6 - DTC P0741 or P0742[/TD]
[/TR]
[TR]
[TD]P0748[/TD]
[TD]DTC P0748: Line Pressure Control Solenoid Valve System Performance[/TD]
[TD]DTC P0748, P0962, or P0963[/TD]
[/TR]
[TR]
[TD]P0751
P0752[/TD]
[TD]DTC P0751: Shift Solenoid 1 Valve Performance - Stuck Off
DTC P0752: Shift Solenoid 1 Valve Performance - Stuck On[/TD]
[TD]DTC P0751 or P0752[/TD]
[/TR]
[TR]
[TD]P0776
P0777[/TD]
[TD]DTC P0776: Pressure Control Solenoid Valve 2 Stuck Off
DTC P0777: Pressure Control Solenoid Valve 2 Stuck On[/TD]
[TD]DTC P0776 or P0777[/TD]
[/TR]
[TR]
[TD]P0778[/TD]
[TD]DTC P0778: Pressure Control Solenoid Valve 1 System Performance[/TD]
[TD]DTC P0778 or P0965-P0967[/TD]
[/TR]
[TR]
[TD]P0796
P0797[/TD]
[TD]DTC P0796: Pressure Control Solenoid Valve 3 Stuck Off
DTC P0797: Pressure Control Solenoid Valve 3 Stuck On[/TD]
[TD]DTC P0796 or P0797[/TD]
[/TR]
[TR]
[TD]P0798[/TD]
[TD]DTC P0798: Pressure Control Solenoid Valve 2 System Performance[/TD]
[TD]DTC P0798, P0970, or P0971[/TD]
[/TR]
[TR]
[TD]P0806
P0807
P0808[/TD]
[TD]DTC P0806: Clutch Pedal Position (CPP) Sensor Performance
DTC P0807: Clutch Pedal Position (CPP) Sensor Circuit Low Voltage
DTC P0808: Clutch Pedal Position (CPP) Sensor Circuit High Voltage[/TD]
[TD]Manual Gearbox F17-5 - DTC P0806-P0808[/TD]
[/TR]
[TR]
[TD]P0806
P0807
P0808[/TD]
[TD]Manual Gearbox F40 - DTC P0806-P0808[/TD]
[/TR]
[TR]
[TD]P080A[/TD]
[TD]DTC P080A: Clutch Pedal Position (CPP) Not Learned[/TD]
[TD]Manual Gearbox F17-5 - DTC P080A[/TD]
[/TR]
[TR]
[TD]P080A[/TD]
[TD]Manual Gearbox F40 - DTC P080A[/TD]
[/TR]
[TR]
[TD]P0815
P0816[/TD]
[TD]DTC P0815: Upshift Switch Circuit
DTC P0816: Downshift Switch Circuit[/TD]
[TD]DTC P0815, P0816, or P0826[/TD]
[/TR]
[TR]
[TD]P081A
P081B[/TD]
[TD]DTC P081A: Brake Transmission Shift Interlock Solenoid Actuator - Short to Ground/Open
DTC P081B: Brake Transmission Shift Interlock Solenoid Actuator - Short to Voltage[/TD]
[TD]DTC P081A or P081B[/TD]
[/TR]
[TR]
[TD]P0826[/TD]
[TD]DTC P0826: Up and Down Shift Switch Circuit[/TD]
[/TR]
[TR]
[TD]P0830[/TD]
[TD]DTC P0830: Clutch Pedal Position (CPP) Sensor Performance[/TD]
[TD]Manual Gearbox F17-5 - DTC P0830[/TD]
[/TR]
[TR]
[TD]P0830[/TD]
[TD]Manual Gearbox F40 - DTC P0830[/TD]
[/TR]
[TR]
[TD]P0833[/TD]
[TD]DTC P0833 00: Clutch Pedal Position (CPP) Sensor Circuit Malfunction[/TD]
[TD]Manual Gearbox F17-5 - DTC P0833[/TD]
[/TR]
[TR]
[TD]P0833[/TD]
[TD]Manual Gearbox F40 - DTC P0833[/TD]
[/TR]
[TR]
[TD]P0842
P0843[/TD]
[TD]DTC P0842: Transmission Fluid Pressure Switch 1 Circuit Low Voltage
DTC P0843: Transmission Fluid Pressure Switch 1 Circuit High Voltage[/TD]
[TD]DTC P0842 or P0843[/TD]
[/TR]
[TR]
[TD]P0850
P0851
P0852[/TD]
[TD]DTC P0850: Park/Neutral Position Switch Circuit
DTC P0851: Park/Neutral Position Switch Circuit Low Voltage
DTC P0852: Park/Neutral Position Switch Circuit High Voltage[/TD]
[TD]DTC P0850-P0852[/TD]
[/TR]
[TR]
[TD]P0856[/TD]
[TD]DTC P0856 00: Traction Control Torque Request Circuit Malfunction[/TD]
[TD]DTC P0856[/TD]
[/TR]
[TR]
[TD]P086B
P086C
P086D[/TD]
[TD]DTC P086B 01: Neutral Position Sensor Performance
DTC P086B 02: Neutral Position Sensor Performance
DTC P086C 00: Neutral Position Sensor Circuit Low Voltage
DTC P086D 00: Neutral Position Sensor Circuit High Voltage[/TD]
[TD]Manual Gearbox F17-5 - DTC P086B-P086D[/TD]
[/TR]
[TR]
[TD]P086B
P086C
P086D[/TD]
[TD]Manual Gearbox F40 - DTC P086B-P086D[/TD]
[/TR]
[TR]
[TD]P0872
P0873[/TD]
[TD]DTC P0872: Transmission Fluid Pressure Switch 3 Circuit Low Voltage
DTC P0873: Transmission Fluid Pressure Switch 3 Circuit High Voltage[/TD]
[TD]DTC P0872 or P0873[/TD]
[/TR]
[TR]
[TD]P0877
P0878[/TD]
[TD]DTC P0877: Transmission Fluid Pressure Switch 4 Circuit Low Voltage
DTC P0878: Transmission Fluid Pressure Switch 4 Circuit High Voltage[/TD]
[TD]DTC P0877 or P0878[/TD]
[/TR]
[TR]
[TD]P0961[/TD]
[TD]DTC P0961: Line Pressure Control Solenoid Valve System Performance[/TD]
[TD]Automatic Transmission 6T30/6T40/6T45/6T50 - DTC P0961-P0963[/TD]
[/TR]
[TR]
[TD]P0962
P0963[/TD]
[TD]DTC P0962: Line Pressure Control Solenoid Valve Control Circuit Low Voltage
DTC P0963: Line Pressure Control Solenoid Valve Control Circuit High Voltage[/TD]
[/TR]
[TR]
[TD]P0962
P0963[/TD]
[TD]Automatic Transmission AF40-6 - DTC P0748, P0962, or P0963[/TD]
[/TR]
[TR]
[TD]P0965
P0966
P0967[/TD]
[TD]DTC P0965: Pressure Control Solenoid Valve 1 System Performance
DTC P0966: Pressure Control Solenoid Valve 1 Control Circuit Low Voltage
DTC P0967: Pressure Control Solenoid Valve 1 Control Circuit High Voltage[/TD]
[TD]Automatic Transmission AF40-6 - DTC P0778 or P0965-P0967[/TD]
[/TR]
[TR]
[TD]P0965
P0966
P0967[/TD]
[TD]DTC P0965: Pressure Control Solenoid Valve 2 Performance
DTC P0966: Pressure Control Solenoid Valve 2 Control Circuit Low Voltage
DTC P0967: Pressure Control Solenoid Valve 2 Control Circuit High Voltage[/TD]
[TD]Automatic Transmission 6T30/6T40/6T45/6T50 - DTC P0965-P0967[/TD]
[/TR]
[TR]
[TD]P0969[/TD]
[TD]DTC P0969: Pressure Control Solenoid Valve 3 Performance[/TD]
[TD]Automatic Transmission 6T30/6T40/6T45/6T50 - DTC P0969-P0971[/TD]
[/TR]
[TR]
[TD]P0970
P0971[/TD]
[TD]DTC P0970: Pressure Control Solenoid Valve 2 Control Circuit Low Voltage
DTC P0971: Pressure Control Solenoid Valve 2 Control Circuit High Voltage[/TD]
[TD]Automatic Transmission AF40-6 - DTC P0798, P0970, or P0971[/TD]
[/TR]
[TR]
[TD]P0970
P0971[/TD]
[TD]DTC P0970: Pressure Control Solenoid Valve 3 Control Circuit Low Voltage
DTC P0971: Pressure Control Solenoid Valve 3 Control Circuit High Voltage[/TD]
[/TR]
[TR]
[TD]P0973
P0974[/TD]
[TD]DTC P0973: Shift Solenoid Valve 1 Control Circuit Low Voltage
DTC P0974: Shift Solenoid Valve 1 Control Circuit High Voltage[/TD]
[TD]Automatic Transmission 6T30/6T40/6T45/6T50 - DTC P0973 or P0974[/TD]
[/TR]
[TR]
[TD]P0973
P0974[/TD]
[TD]Automatic Transmission AF40-6 - DTC P0973 or P0974[/TD]
[/TR]
[TR]
[TD]P0976
P0977[/TD]
[TD]DTC P0976: Shift Solenoid Valve 2 Control Circuit Low Voltage
DTC P0977: Shift Solenoid Valve 2 Control Circuit High Voltage[/TD]
[TD]DTC P0976 or P0977[/TD]
[/TR]
[TR]
[TD]P0989
P0990[/TD]
[TD]DTC P0989: Transmission Fluid Pressure Switch 5 Circuit Low Voltage
DTC P0990: Transmission Fluid Pressure Switch 5 Circuit High Voltage[/TD]
[TD]DTC P0989 or P0990[/TD]
[/TR]
[TR]
[TD]P1101[/TD]
[TD]DTC P1101 00: Intake Air Flow System Performance[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0068 or P1101[/TD]
[/TR]
[TR]
[TD]P1101[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0068 or P1101[/TD]
[/TR]
[TR]
[TD]P1104[/TD]
[TD]DTC P1104 00: Throttle Actuator Control (TAC) Motor Control Circuit Shorted[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P1104[/TD]
[/TR]
[TR]
[TD]P1104[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P1104[/TD]
[/TR]
[TR]
[TD]P1133[/TD]
[TD]DTC P1133 00: HO2S Insufficient Switching Sensor 1[/TD]
[TD]1.4L (LDD) engines - DTC P0133, P0134, P0140, P1133, P2270, P2271, or P2A00
[/TD]
[/TR]
[TR]
[TD]P1133[/TD]
[TD]1.4L (LUJ) engines - DTC P0133, P0134, P013A, P013B, P013E, P013F, P0140, P1133, P2270, P2271, or P2A00[/TD]
[/TR]
[TR]
[TD]P1133[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0133, P0134, P0140, P1133, P2270, P2271, or P2A00[/TD]
[/TR]
[TR]
[TD]P1255[/TD]
[TD]DTC P1255: Fuel Pump Control Module Driver Over-temperature[/TD]
[/TR]
[TR]
[TD]P1255[/TD]
[/TR]
[TR]
[TD]P1258[/TD]
[TD]DTC P1258: Engine Coolant Over temperature - Protection Mode Active[/TD]
[TD]DTC P1258[/TD]
[/TR]
[TR]
[TD]P1259[/TD]
[TD]DTC P1259 11: High Pressure Fuel Pump Performance
DTC P1259 12: High Pressure Fuel Pump Performance[/TD]
[TD]DTC P1259[/TD]
[/TR]
[TR]
[TD]P1325
[/TD]
[TD]DTC P1325 01: Crankshaft Position Reluctor Wheel Performance
DTC P1325 02: Crankshaft Position Reluctor Wheel Performance
DTC P1325 03: Crankshaft Position Reluctor Wheel Performance
DTC P1325 04: Crankshaft Position Reluctor Wheel Performance[/TD]
[TD]1.3L (Diesel) engines - DTC P1325[/TD]
[/TR]
[TR]
[TD]P1325[/TD]
[TD]2.0L (Diesel) engines - DTC P1325[/TD]
[/TR]
[TR]
[TD]P1400[/TD]
[TD]DTC P1400: Cold Start Emission Reduction Control System[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P1400[/TD]
[/TR]
[TR]
[TD]P1407[/TD]
[TD]DTC P1407: Exhaust Gas Recirculation (EGR) Motor Control Circuit Shorted[/TD]
[TD]DTC P1407[/TD]
[/TR]
[TR]
[TD]P1409[/TD]
[TD]DTC P1409 5A: Exhaust Gas Recirculation (EGR) Control Circuit Not Plausible
DTC P1409 5B: Exhaust Gas Recirculation (EGR) Control Circuit Malfunction[/TD]
[TD]1.3L (Diesel) engines - DTC P1409[/TD]
[/TR]
[TR]
[TD]P1409[/TD]
[TD]2.0L (Diesel) engines - DTC P1409[/TD]
[/TR]
[TR]
[TD]P1471[/TD]
[TD]DTC P1471 00: Diesel Particulate Filter (DPF) Regeneration Incomplete[/TD]
[TD]DTC P1471[/TD]
[/TR]
[TR]
[TD]P1484[/TD]
[TD]DTC P1484: Cooling Fan System Performance[/TD]
[TD]DTC P184[/TD]
[/TR]
[TR]
[TD]P150C[/TD]
[TD]DTC P150C: Transmission Control Module Engine Speed Request Signal Message Counter Incorrect[/TD]
[TD]TCM - DTC P150C
or
1.4L (LDD, LUH, or LUJ) engines - DTC P150C[/TD]
[/TR]
[TR]
[TD]P1516[/TD]
[TD]DTC P1516 00: Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P1516, P2100-P2103, P2119, or P2176[/TD]
[/TR]
[TR]
[TD]P1516[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P1516, P2100-P2103, P2119, or P2176[/TD]
[/TR]
[TR]
[TD]P1540[/TD]
[TD]DTC P1540 00: Invalid Data Received From HVAC Control Module[/TD]
[TD]HVAC Automatic - DTC P1540
or
HVAC Manual - DTC P1540[/TD]
[/TR]
[TR]
[TD]P15A3[/TD]
[TD]DTC P15A3 00: Stop/Start Select Switch Circuit Signal Message Counter Incorrect[/TD]
[TD]1.3L (Diesel) engines - DTC P15A3[/TD]
[/TR]
[TR]
[TD]P15A3[/TD]
[TD]2.0L (Diesel) engines - DTC P15A3[/TD]
[/TR]
[TR]
[TD]P160A[/TD]
[TD]DTC P160A 00: Vehicle Speed Limit Not Programmed[/TD]
[TD] 1.3L (Diesel) engines - DTC P160A[/TD]
[/TR]
[TR]
[TD]P160A[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P160A[/TD]
[/TR]
[TR]
[TD]P160A[/TD]
[TD]2.0L (Diesel) engines - DTC P160A[/TD]
[/TR]
[TR]
[TD]P160D[/TD]
[TD]DTC P160D 00: Incorrect Engine Calibration Detected[/TD]
[TD]1.3L (Diesel) engines - DTC P160D[/TD]
[/TR]
[TR]
[TD]P160D[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P160D[/TD]
[/TR]
[TR]
[TD]P160D[/TD]
[TD]DTC P160D 3B: Incorrect Engine Calibration Detected
DTC P160D 42: Incorrect Engine Calibration Detected[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P160D[/TD]
[/TR]
[TR]
[TD]P160D[/TD]
[TD]2.0L (Diesel) engines - DTC P160D[/TD]
[/TR]
[TR]
[TD]P160E[/TD]
[TD]DTC P160E 00: Engine Calibration Monitoring Not Programmed[/TD]
[TD]1.3L (Diesel) engines - DTC P160E[/TD]
[/TR]
[TR]
[TD]P160E[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P160E[/TD]
[/TR]
[TR]
[TD]P160E[/TD]
[TD]DTC P160E 43: Engine Calibration Monitoring Not Programmed
DTC P160E 4C: Engine Calibration Monitoring Not Programmed[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P160E[/TD]
[/TR]
[TR]
[TD]P160E[/TD]
[TD]2.0L (Diesel) engines - DTC P160E[/TD]
[/TR]
[TR]
[TD]P161C[/TD]
[TD]DTC P161C 00: Tire Size Not Programmed[/TD]
[TD]1.3L (Diesel) engines - DTC P161C[/TD]
[/TR]
[TR]
[TD]P161C[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P161C[/TD]
[/TR]
[TR]
[TD]P161C[/TD]
[TD]2.0L (Diesel) engines - DTC P161C[/TD]
[/TR]
[TR]
[TD]P161F[/TD]
[TD]DTC P161F 00: Assembly Plant Mode Counter Not Programmed General Memory Malfunction[/TD]
[TD]1.3L (Diesel) engines - DTC P161F[/TD]
[/TR]
[TR]
[TD]P161F[/TD]
[TD]DTC P161F 00: Assembly Plant Mode Counter Not Programmed[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P161F[/TD]
[/TR]
[TR]
[TD]P161F[/TD]
[TD]2.0L (Diesel) engines - DTC P161F[/TD]
[/TR]
[TR]
[TD]P1629[/TD]
[TD]DTC P1629: Immobilizer Fuel Enable Signal Not Received[/TD]
[TD]DTC P1629[/TD]
[/TR]
[TR]
[TD]P1630[/TD]
[TD]DTC P1630 00: Immobiliser Learn Mode Active Malfunction[/TD]
[TD]DTC P1630[/TD]
[/TR]
[TR]
[TD]P1631[/TD]
[TD]DTC P1631: Immobilizer Fuel Enable Signal Not Correct[/TD]
[TD]DTC P1631[/TD]
[/TR]
[TR]
[TD]P1640[/TD]
[TD]DTC P1640 00: Control Module Power Circuit Malfunction[/TD]
[TD]1.3L (Diesel) engines - DTC P1640[/TD]
[/TR]
[TR]
[TD]P1640[/TD]
[TD]2.0L (Diesel) engines - DTC P1640[/TD]
[/TR]
73
9:th-Apr-2015, 09:35:45
(This post was last modified: 2:nd-Apr-2022, 08:51:52 by Rusty2009.)
Codes P continued
[TR]
[TD]DTC[/TD]
[/TR]
[TR]
[TD]P1649[/TD]
[TD]DTC P1649: Immobilizer Security Code Not Programmed[/TD]
[TD]DTC P1649[/TD]
[/TR]
[TR]
[TD]P1677[/TD]
[TD]DTC P1677: Immobilizer System Disabled[/TD]
[TD]DTC P1677[/TD]
[/TR]
[TR]
[TD]P1682[/TD]
[TD]DTC P1682 00: Ignition 1 Switch Circuit 2[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P1682[/TD]
[/TR]
[TR]
[TD]P1682[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P1682[/TD]
[/TR]
[TR]
[TD]P16F3[/TD]
[TD]DTC P16F3 00: Control Module Redundant Memory Performance[/TD]
[/TR]
[TR]
[TD]P16F3[/TD]
[/TR]
[TR]
[TD]P16F3[/TD]
[/TR]
[TR]
[TD]P1700[/TD]
[TD]DTC P1700: Transmission Control Module (TCM) Requested SVS Illumination[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P1700[/TD]
[/TR]
[TR]
[TD]P1700[/TD]
[TD]1.7L (Diesel) engines - DTC P1700[/TD]
[/TR]
[TR]
[TD]P1731[/TD]
[TD]DTC P1731: 1st Gear Ratio Incorrect - with Engine Brake[/TD]
[TD]DTC P1731[/TD]
[/TR]
[TR]
[TD]P1761[/TD]
[TD]DTC P1761: Up and Down Shift Switch Signal Message Counter Incorrect[/TD]
[TD]DTC P1761[/TD]
[/TR]
[TR]
[TD]P182E[/TD]
[TD]DTC P182E: Internal Mode Switch Indicates Invalid Range[/TD]
[TD]DTC P182E or P1915[/TD]
[/TR]
[TR]
[TD]P1845[/TD]
[TD]DTC P1845 00: Control Module Performance[/TD]
[TD]1.3L (Diesel) engines - DTC P1845[/TD]
[/TR]
[TR]
[TD]P1845[/TD]
[TD]2.0L (Diesel) engines - DTC P1845[/TD]
[/TR]
[TR]
[TD]P1876[/TD]
[TD]DTC P1876: Up and Down Shift Enable Switch Circuit Low Voltage[/TD]
[TD]DTC P1876[/TD]
[/TR]
[TR]
[TD]P1915[/TD]
[TD]DTC P1915: Internal Mode Switch Does Not Indicate Park/Neutral During Start[/TD]
[/TR]
[TR]
[TD]P2002
P2003[/TD]
[TD]DTC P2002 00: Diesel Particulate Filter (DPF) Low Efficiency
DTC P2003 00: Diesel Particulate Filter (DPF) Soot Accumulation[/TD]
[TD]DTC P2002 or P2003[/TD]
[/TR]
[TR]
[TD]P2008[/TD]
[TD]DTC P2008 00: Intake Manifold Runner Control Valve Control Circuit[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P2008, P2009, or P2010[/TD]
[/TR]
[TR]
[TD]P2008[/TD]
[TD]DTC P2008 00: Intake Manifold Runner Control Valve Control Circuit Malfunction[/TD]
[TD]2.0L (Diesel) engines - DTC P2008[/TD]
[/TR]
[TR]
[TD]P2009[/TD]
[TD]DTC P2009 00: Intake Manifold Runner Control Valve Control Circuit Low Voltage[/TD]
[/TR]
[TR]
[TD]P2009[/TD]
[TD]DTC P2009: Intake Manifold Runner Control Valve Control Circuit Low Voltage[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P2009 or P2010[/TD]
[/TR]
[TR]
[TD]P2009[/TD]
[TD]2.0L (Diesel) engines - DTC P2009 or P2010[/TD]
[/TR]
[TR]
[TD]P200A[/TD]
[TD]DTC P200A 00: Intake Manifold Runner Control Valve Control Circuit Performance[/TD]
[TD]2.0L (Diesel) engines - DTC P200A[/TD]
[/TR]
[TR]
[TD]P2010[/TD]
[TD]DTC P2010 00: Intake Manifold Runner Control Valve Control Circuit High Voltage[/TD]
[/TR]
[TR]
[TD]P2010[/TD]
[TD]DTC P2010: Intake Manifold Runner Control Valve Control Circuit High Voltage[/TD]
[/TR]
[TR]
[TD]P2010[/TD]
[/TR]
[TR]
[TD]P2014[/TD]
[TD]DTC P2014 00: Intake Manifold Runner Control Valve Position Not Learned[/TD]
[TD]DTC P2014[/TD]
[/TR]
[TR]
[TD]P2015[/TD]
[TD]DTC P2015: Intake Manifold Runner Control Valve Position Sensor Performance[/TD]
[TD]1.7L Diesel engines - DTC P2015[/TD]
[/TR]
[TR]
[TD]P2015[/TD]
[TD]DTC P2015 20: Intake Manifold Runner Control Valve Actuator Internal Performance Malfunction
DTC P2015 21: Intake Manifold Runner Control Valve Actuator Internal Performance Incorrect Period
DTC P2015 22: Intake Manifold Runner Control Valve Actuator Internal Performance Too Short Low-Time
DTC P2015 23: Intake Manifold Runner Control Valve Actuator Internal Performance Too Long Low-Time
DTC P2015 24: Intake Manifold Runner Control Valve Actuator Internal Performance Too Short High-Time
DTC P2015 25: Intake Manifold Runner Control Valve Actuator Internal Performance Too Long High-Time
DTC P2015 26: Intake Manifold Runner Control Valve Actuator Internal Performance Low Frequency
DTC P2015 27: Intake Manifold Runner Control Valve Actuator Internal Performance High Frequency[/TD]
[TD]2.0L (Diesel) engines - DTC P2015[/TD]
[/TR]
[TR]
[TD]P2016
P2017[/TD]
[TD]DTC P2016: Intake Manifold Runner Control Valve Position Sensor Circuit Low Voltage
DTC P2017: Intake Manifold Runner Control Valve Position Sensor Circuit High Voltage[/TD]
[TD]1.7L Diesel engines - DTC P2016 or P2017[/TD]
[/TR]
[TR]
[TD]P2016
P2017[/TD]
[TD]DTC P2016 08: Intake Manifold Runner Control Valve Feedback Circuit Low Voltage
DTC P2017 08: Intake Manifold Runner Control Valve Feedback Circuit High Voltage[/TD]
[TD]2.0L (Diesel) engines - DTC P2016 or P2017[/TD]
[/TR]
[TR]
[TD]P2032
P2033[/TD]
[TD]DTC P2032: Exhaust Gas Temperature Sensor 2 Circuit Low Voltage
DTC P2033: Exhaust Gas Temperature Sensor 2 Circuit High Voltage[/TD]
[TD]1.7L Diesel engines - DTC P2032 or P2033[/TD]
[/TR]
[TR]
[TD]P2032
P2033[/TD]
[TD]DTC P2032 12: Exhaust Gas Temperature Sensor 1 Circuit Low Voltage
DTC P2033 11: Exhaust Gas Temperature Sensor 1 Circuit High Voltage[/TD]
[TD]1.3L (Diesel) engines - DTC P2032 or P2033[/TD]
[/TR]
[TR]
[TD]P2032
P2033[/TD]
[TD]DTC P2032 12: Exhaust Gas Temperature Sensor 2 Circuit Low Voltage
DTC P2032 5A: Exhaust Gas Temperature Sensor 2 Circuit Low Voltage
DTC P2033 11: Exhaust Gas Temperature Sensor 2 Circuit High Voltage[/TD]
[TD]2.0L (Diesel) engines - DTC P2032 or P2033[/TD]
[/TR]
[TR]
[TD]P2080
P2081[/TD]
[TD]DTC P2080 00: Exhaust Gas Temperature Sensor 1 Performance
DTC P2081 00: Exhaust Gas Temperature Sensor 1 Circuit Intermittent[/TD]
[TD]1.7L (Diesel) engines - DTC P2080 or P2081[/TD]
[/TR]
[TR]
[TD]P2080
P2081[/TD]
[TD]DTC P2080 54: Exhaust Gas Temperature Sensors 1-2 Not Plausible
DTC P2081 55: Exhaust Gas Temperature Sensors 1-2 Not Plausible[/TD]
[TD]2.0L (Diesel) engines - DTC P2080[/TD]
[/TR]
[TR]
[TD]P2084
P2085[/TD]
[TD]DTC P2084 00: Exhaust Gas Temperature Sensor 2 Performance
DTC P2085 00: Exhaust Gas Temperature Sensor 2 Circuit Intermittent[/TD]
[TD]DTC P2084 or P2085[/TD]
[/TR]
[TR]
[TD]P2096
P2097[/TD]
[TD]DTC P2096 00: Post Catalyst Fuel Trim System Low Limit Bank 1
DTC P2097 00: Post Catalyst Fuel Trim System High Limit Bank 1[/TD]
[TD]DTC P2096 or P2097[/TD]
[/TR]
[TR]
[TD]P2100[/TD]
[TD]DTC P2100 00: Throttle Actuator Control (TAC) Motor Control Circuit[/TD]
[/TR]
[TR]
[TD]P2100[/TD]
[/TR]
[TR]
[TD]P2100[/TD]
[TD]DTC P2100 04: Intake Air Flow Valve Control Circuit Open[/TD]
[TD]1.3L (Diesel) engines - DTC P2100, P2102, or P2103[/TD]
[/TR]
[TR]
[TD]P2100[/TD]
[TD]2.0L (Diesel) engines - DTC P2100, P2102, or P2103[/TD]
[/TR]
[TR]
[TD]P2101[/TD]
[TD]DTC P2101 00: Throttle Actuator Position Performance[/TD]
[/TR]
[TR]
[TD]P2101[/TD]
[/TR]
[TR]
[TD]P2101[/TD]
[TD]DTC P2101 03: Intake Air Flow Valve Control Circuit Low Voltage
DTC P2101 39: Intake Air Flow Valve Control Circuit Internal Malfunction
DTC P2101 51: Intake Air Flow Valve Control Circuit Malfunction
DTC P2101 52: Intake Air Flow Valve Control Circuit Malfunction
DTC P2101 54: Intake Air Flow Valve Control Circuit High Temperature
DTC P2101 59: Intake Air Flow Valve Control Circuit Malfunction[/TD]
[TD]1.3L (Diesel) engines - DTC P2101[/TD]
[/TR]
[TR]
[TD]P2101[/TD]
[TD]DTC P2101 03: Inlet Air Flow Valve Control Circuit Low Voltage
DTC P2101 39: Inlet Air Flow Valve Control Circuit Internal Malfunction
DTC P2101 51: Inlet Air Flow Valve Control Circuit Malfunction
DTC P2101 52: Inlet Air Flow Valve Control Circuit Malfunction
DTC P2101 59: Inlet Air Flow Valve Control Circuit Malfunction[/TD]
[TD]2.0L (Diesel) engines - DTC P2101[/TD]
[/TR]
[TR]
[TD]P2102
P2103[/TD]
[TD]DTC P2102 00: Throttle Actuator Control (TAC) Motor Control Circuit Low Voltage
DTC P2103 00: Throttle Actuator Control (TAC) Motor Control Circuit High Voltage[/TD]
[/TR]
[TR]
[TD]P2102
P2103[/TD]
[/TR]
[TR]
[TD]P2102
P2103[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P2102 or P2103[/TD]
[/TR]
[TR]
[TD]P2102
P2103[/TD]
[TD]DTC P2102 02: Intake Air Flow Valve Control Circuit Short to Ground
DTC P2103 01: Intake Air Flow Valve Control Circuit Short to Battery[/TD]
[/TR]
[TR]
[TD]P2102
P2103[/TD]
[/TR]
[TR]
[TD]P2119[/TD]
[TD]DTC P2119 00: Throttle Closed Position Performance[/TD]
[/TR]
[TR]
[TD]P2119[/TD]
[/TR]
[TR]
[TD]P2122
P2123
P2127
P2128[/TD]
[TD]DTC P2122 00: Accelerator Pedal Position (APP) Sensor 1 Circuit Low Voltage
DTC P2123 00: Accelerator Pedal Position (APP) Sensor 1 Circuit High Voltage
DTC P2127 00: Accelerator Pedal Position (APP) Sensor 2 Circuit Low Voltage
DTC P2128 00: Accelerator Pedal Position (APP) Sensor 2 Circuit High Voltage[/TD]
[TD]1.3L (Diesel) engines - DTC P2122, P2123, P2127, P2128, or P2138[/TD]
[/TR]
[TR]
[TD]P2122
P2123
P2127
P2128[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P2122, P2123, P2127, P2128, or P2138[/TD]
[/TR]
[TR]
[TD]P2122
P2123
P2127
P2128[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P2122, P2123, P2127, P2128, or P2138[/TD]
[/TR]
[TR]
[TD]P2122
P2123
P2127
P2128[/TD]
[TD]DTC P2122: Accelerator Pedal Position (APP) Sensor 1 Circuit Low Voltage
DTC P2123: Accelerator Pedal Position (APP) Sensor 1 Circuit High Voltage
DTC P2127: Accelerator Pedal Position (APP) Sensor 2 Circuit Low Voltage
DTC P2128: Accelerator Pedal Position (APP) Sensor 2 Circuit High Voltage[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P2122, P2123, P2127, P2128, or P2138[/TD]
[/TR]
[TR]
[TD]P2122
P2123
P2127
P2128[/TD]
[TD]2.0L (Diesel) engines - DTC P2122, P2123, P2127, P2128, or P2138[/TD]
[/TR]
[TR]
[TD]P2135[/TD]
[TD]DTC P2135 00: Throttle Position Sensors 1-2 Not Plausible[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0121-P0123, P0222, P0223, or P2135[/TD]
[/TR]
[TR]
[TD]P2135[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P0121-P0123, P0222, P0223, or P2135[/TD]
[/TR]
[TR]
[TD]P2138[/TD]
[TD]DTC P2138 00: Accelerator Pedal Position (APP) Sensors 1–2 Not Plausible
DTC P2138 38: Accelerator Pedal Position (APP) Sensors 1–2 Not Plausible[/TD]
[/TR]
[TR]
[TD]P2138[/TD]
[TD]DTC P2138 00: Accelerator Pedal Position (APP) Sensors 1-2 Not Plausible[/TD]
[/TR]
[TR]
[TD]P2138[/TD]
[/TR]
[TR]
[TD]P2138[/TD]
[TD]DTC P2138: Accelerator Pedal Position (APP) Sensors 1-2 Not Plausible[/TD]
[/TR]
[TR]
[TD]P2138[/TD]
DTC P2138 38: Accelerator Pedal Position (APP) Sensors 1-2 Not Plausible[/TD]
[/TR]
[TR]
[TD]P2147
P2148
P2150
P2151[/TD]
[TD]DTC P2147 00: Injector High Control Circuit Group 1 Low Voltage
DTC P2148 00: Injector High Control Circuit Group 1 High Voltage
DTC P2150 00: Injector High Control Circuit Group 2 Low Voltage
DTC P2151 00: Injector High Control Circuit Group 2 High Voltage[/TD]
[TD]DTC P2147, P2148, P2150, or P2151[/TD]
[/TR]
[TR]
[TD]P2176[/TD]
[TD]DTC P2176 00: Minimum Throttle Position Not Learned[/TD]
[/TR]
[TR]
[TD]P2176[/TD]
[/TR]
[TR]
[TD]P2181[/TD]
[TD]DTC P2181: Engine Cooling System Performance[/TD]
[TD]DTC P2181[/TD]
[/TR]
[TR]
[TD]P2227[/TD]
[TD]DTC P2227: Barometric Pressure (BARO) Sensor Performance[/TD]
[TD]DTC P2227-P2230[/TD]
[/TR]
[TR]
[TD]P2228
P2229[/TD]
[TD]DTC P2228 00: Barometric Pressure (BARO) Sensor Circuit Low Voltage
DTC P2229 00: Barometric Pressure (BARO) Sensor Circuit High Voltage[/TD]
[TD]1.3L (Diesel) engines - DTC P2228 or P2229[/TD]
[/TR]
[TR]
[TD]P2228
P2229[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P2227-P2230[/TD]
[/TR]
[TR]
[TD]P2228
P2229[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P2228 or P2229[/TD]
[/TR]
[TR]
[TD]P2228
P2229[/TD]
[TD]DTC P2228: Barometric Pressure (BARO) Sensor Circuit Low Voltage
DTC P2229: Barometric Pressure (BARO) Sensor Circuit High Voltage[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P2228 or P2229[/TD]
[/TR]
[TR]
[TD]P2228
P2229[/TD]
[TD]2.0L (Diesel) engines - DTC P2228 or P2229[/TD]
[/TR]
[TR]
[TD]P2230[/TD]
[TD]DTC P2230: Barometric Pressure (BARO) Sensor Circuit Erratic[/TD]
[/TR]
[TR]
[TD]P2231[/TD]
[TD]DTC P2231 00: HO2S Signal Circuit Shorted to Heater Circuit Sensor 1[/TD]
[TD]1.3L (Diesel) engines - DTC P2231[/TD]
[/TR]
[TR]
[TD]P2231[/TD]
[TD]2.0L (Diesel) engines - DTC P2231[/TD]
[/TR]
[TR]
[TD]P2243[/TD]
[TD]DTC P2243 00: HO2S Reference Voltage Circuit Sensor 1 Malfunction
DTC P2243 04: HO2S Reference Voltage Circuit Sensor 1 Open[/TD]
[TD]1.3L (Diesel) engines - DTC P2243[/TD]
[/TR]
[TR]
[TD]P2243[/TD]
[TD]DTC P2243: HO2S Reference Voltage Circuit Sensor 1[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P2243[/TD]
[/TR]
[TR]
[TD]P2243[/TD]
[TD]2.0L (Diesel) engines - DTC P2243[/TD]
[/TR]
[TR]
[TD]P2261[/TD]
[TD]DTC P2261 00: Turbocharger Bypass Valve Stuck[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P2261[/TD]
[/TR]
[TR]
[TD]P2261[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P2261[/TD]
[/TR]
[TR]
[TD]P2262[/TD]
[TD]DTC P2262 00: Turbocharger Boost System Performance Malfunction[/TD]
[TD]DTC P2262[/TD]
[/TR]
[TR]
[TD]P2263[/TD]
[TD]DTC P2263 5A: Turbocharger Boost System Performance Not Plausible
DTC P2263 5B: Turbocharger Boost System Performance Malfunction
DTC P2263 61: Turbocharger Boost System Performance Stuck[/TD]
[TD]1.3L (Diesel) engines - DTC P2263[/TD]
[/TR]
[TR]
[TD]P2263[/TD]
[TD]DTC P2263 00: Turbocharger Boost System Performance Not Plausible
DTC P2263 5A: Turbocharger Boost System Performance Malfunction
[TD]2.0L (Diesel) engines - DTC P2263[/TD]
[/TR]
[TR]
[TD]P2265[/TD]
[TD]DTC P2265 00: Water in Fuel Sensor Circuit Malfunction[/TD]
[TD]1.3L (Diesel) engines - DTC P2265[/TD]
[/TR]
[TR]
[TD]P2265[/TD]
[TD]DTC P2265: Water in Fuel Sensor Circuit Malfunction[/TD]
[TD]2.0L (Diesel) engines - DTC P2265[/TD]
[/TR]
[TR]
[TD]P2270
P2271[/TD]
[TD]DTC P2270 00: HO2S Signal Stuck Lean Sensor 2
DTC P2271 00: HO2S Signal Stuck Rich Sensor 2[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0133, P0134, P0140, P1133, P2270, P2271, or P2A00[/TD]
[/TR]
[TR]
[TD]P2270
P2271[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P0133, P0134, P013A, P013B, P013E, P013F, P0140, P1133, P2270, P2271, or P2A00[/TD]
[/TR]
[TR]
[TD]P2270
P2271[/TD]
[/TR]
[TR]
[TD]P2282[/TD]
[TD]DTC P2282 51: Mass Air Flow (MAF) Sensor Performance
DTC P2282 52: Mass Air Flow (MAF) Sensor Performance[/TD]
[TD]1.3L (Diesel) engines - DTC P2282[/TD]
[/TR]
[TR]
[TD]P2282[/TD]
[TD]2.0L (Diesel) engines - DTC P2282[/TD]
[/TR]
[TR]
[TD]P2297[/TD]
[TD]DTC P2297 00: HO2S Performance During Deceleration Fuel Cut-Off Sensor 1[/TD]
[TD]DTC P2297[/TD]
[/TR]
[TR]
[TD]P2413[/TD]
[TD]DTC P2413 54: Exhaust Gas Recirculation (EGR) System Performance
DTC P2413 61: Exhaust Gas Recirculation (EGR) System Performance[/TD]
[TD]1.3L (Diesel) engines - DTC P2413[/TD]
[/TR]
[TR]
[TD]P2413[/TD]
[TD]2.0L (Diesel) engines - DTC P2413[/TD]
[/TR]
[TR]
[TD]P2428[/TD]
[TD]DTC P2428 00: Exhaust Gas Temperature Sensor 1 - High Temperature[/TD]
[TD]1.3L (Diesel) engines - DTC P2428[/TD]
[/TR]
[TR]
[TD]P2428[/TD]
[TD]DTC P2428 5B: Exhaust Gas Temperature Out of Range[/TD]
[TD]1.7L (Diesel) engines - DTC P2428[/TD]
[/TR]
[TR]
[TD]P2428[/TD]
DTC P2428 5B: Exhaust Gas Temperature Sensor 1 - High Temperature[/TD]
[TD]2.0L (Diesel) engines - DTC P2428[/TD]
[/TR]
[TR]
[TD]P242F[/TD]
[TD]DTC P242F 00: Diesel Particulate Filter (DPF) Restriction - Not Regenerable[/TD]
[TD]DTC P242F[/TD]
[/TR]
[TR]
[TD]P244A
P244B[/TD]
[TD]DTC P244A 00: Diesel Particulate Filter (DPF) Low Differential Pressure
DTC P244B 00: Diesel Particulate Filter (DPF) High Differential Pressure[/TD]
[TD]DTC P244A or P244B[/TD]
[/TR]
[TR]
[TD]P2452[/TD]
[TD]DTC P2452: Diesel Particulate Filter (DPF) Differential Pressure Sensor Performance[/TD]
[TD]DTC P2452, P2454, or P2455[/TD]
[/TR]
[TR]
[TD]P2453[/TD]
[TD]DTC P2453 00: Diesel Particulate Filter (DPF) Differential Pressure Sensor Performance[/TD]
[TD]1.3L (Diesel) engines - DTC P2453[/TD]
[/TR]
[TR]
[TD]P2453[/TD]
[TD]2.0L (Diesel) engines - DTC P2453[/TD]
[/TR]
[TR]
[TD]P2454
P2455[/TD]
[TD]DTC P2454 00: Diesel Particulate Filter (DPF) Differential Pressure Sensor Circuit Low Voltage
DTC P2455 00: Diesel Particulate Filter (DPF) Differential Pressure Sensor Circuit High Voltage
DTC P2455 01: Diesel Particulate Filter (DPF) Differential Pressure Sensor Circuit Short to Battery
DTC P2455 11: Diesel Particulate Filter (DPF) Differential Pressure Sensor Circuit High Input[/TD]
[TD]1.3L (Diesel) engines - DTC P2454 or P2455[/TD]
[/TR]
[TR]
[TD]P2454
P2455[/TD]
[TD]DTC P2454: Diesel Particulate Filter (DPF) Differential Pressure Sensor Circuit Low Voltage
DTC P2455: Diesel Particulate Filter (DPF) Differential Pressure Sensor Circuit High Voltage[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P2452, P2454, or P2455[/TD]
[/TR]
[TR]
[TD]P2454
P2455[/TD]
[TD]2.0L (Diesel) engines - DTC P2454 or P2455[/TD]
[/TR]
[TR]
[TD]P2458[/TD]
[TD]DTC P2458 56: Diesel Particulate Filter (DPF) Regeneration Time
DTC P2458 57: Diesel Particulate Filter (DPF) Regeneration Time[/TD]
[TD]1.3L (Diesel) engines - DTC P2458[/TD]
[/TR]
[TR]
[TD]P2458[/TD]
[TD]DTC P2458 51: Diesel Particulate Filter (DPF) Regeneration Time
[TD]2.0L (Diesel) engines - DTC P2458[/TD]
[/TR]
[TR]
[TD]P2459[/TD]
[TD]DTC P2459 58: Diesel Particulate Filter (DPF) Regeneration Frequency[/TD]
[TD]1.3L (Diesel) engines - DTC P2459[/TD]
[/TR]
[TR]
[TD]P2459[/TD]
[TD]2.0L (Diesel) engines - DTC P2459[/TD]
[/TR]
[TR]
[TD]P245A
P245B[/TD]
[TD]DTC P245A 00: Exhaust Gas Recirculation (EGR) Cooler Bypass Solenoid Valve Control Circuit Open
DTC P245B 00: Exhaust Gas Recirculation (EGR) Cooler Bypass Solenoid Valve Control Circuit Malfunction[/TD]
[TD]1.3L (Diesel) engines - DTC P245A-P245D[/TD]
[/TR]
[TR]
[TD]P245A
P245B[/TD]
[TD]DTC P245A 00: Exhaust Gas Recirculation (EGR) Cooler Bypass Solenoid Valve Control Circuit Malfunction
[TD]2.0L (Diesel) engines - DTC P245A-P245D[/TD]
[/TR]
[TR]
[TD]P245C
P245D[/TD]
[TD]DTC P245C 02: Exhaust Gas Recirculation (EGR) Cooler Bypass Solenoid Valve Control Circuit Short to Ground
DTC P245D 01: Exhaust Gas Recirculation (EGR) Cooler Bypass Solenoid Valve Control Circuit Short to Battery[/TD]
[/TR]
[TR]
[TD]P245C
P245D[/TD]
[/TR]
[TR]
[TD]P245C
P245D[/TD]
[TD]DTC P245C 00: Exhaust Gas Recirculation (EGR) Cooler Bypass Solenoid Valve Control Circuit Low Voltage
DTC P245D 00: Exhaust Gas Recirculation (EGR) Cooler Bypass Solenoid Valve Control Circuit High Voltage[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P245C or P245D[/TD]
[/TR]
[TR]
[TD]P2500
P2501[/TD]
[TD]DTC P2500: Generator L-Terminal Circuit Low Voltage
DTC P2501: Generator L-Terminal Circuit High Voltage[/TD]
[TD]DTC P2500 or P2501[/TD]
[/TR]
[TR]
[TD]P2534[/TD]
[TD]DTC P2534: Ignition On/Start Switch Circuit Low Voltage[/TD]
[TD]Automatic Transmission 6T30/6T40/6T45/6T50 - DTC P2534[/TD]
[/TR]
[TR]
[TD]P2534[/TD]
[TD]DTC P2534 00: Ignition Voltage Out of Range Malfunction[/TD]
[TD]Automatic Transmission AF40-6 - DTC P2534 or P2537[/TD]
[/TR]
[TR]
[TD]P2534[/TD]
[TD]DTC P2534: Ignition 1 Switch Circuit Low Voltage[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P2534[/TD]
[/TR]
[TR]
[TD]P2534[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P2534[/TD]
[/TR]
[TR]
[TD]P2537[/TD]
[TD]DTC P2537 00: Accessory Power Circuit Malfunction[/TD]
[TD]DTC P2534 or P2537[/TD]
[/TR]
[TR]
[TD]P2544[/TD]
[TD]DTC P2544: Transmission Torque Request Signal Message Counter Incorrect[/TD]
[TD]DTC P2544[/TD]
[/TR]
[TR]
[TD]P253F[/TD]
[TD]DTC P253F 01: Engine Oil Life Exceeded[/TD]
[TD]1.3L (Diesel) engines - DTC P253F[/TD]
[/TR]
[TR]
[TD]P253F[/TD]
[TD]2.0L (Diesel) engines - DTC P253F[/TD]
[/TR]
[TR]
[TD]P2564
P2565[/TD]
[TD]DTC P2564 00: Turbocharger Vane Position Sensor Circuit Low Voltage
DTC P2565 00: Turbocharger Vane Position Sensor Circuit High Voltage[/TD]
[TD]1.3L (Diesel) engines - DTC P2564 or P2565[/TD]
[/TR]
[TR]
[TD]P2564
P2565[/TD]
[TD]2.0L (Diesel) engines - DTC P2564 or P2565[/TD]
[/TR]
[TR]
[TD]P257E
P257F[/TD]
[TD]DTC P257E 00: Engine Bonnet Switch Circuit Low Voltage
DTC P257F 00: Engine Bonnet Switch Circuit High Voltage[/TD]
[TD]1.3L (Diesel) engines - DTC P257E or P257F[/TD]
[/TR]
[TR]
[TD]P257E
P257F[/TD]
[TD]2.0L (Diesel) engines - DTC P257E or P257F[/TD]
[/TR]
[TR]
[TD]P2610[/TD]
[TD]DTC P2610 00: Control Module Ignition Off Timer Performance[/TD]
[TD] 1.4L (LDD) engines - DTC P0601-P0604, P0606, P0607, P16F3, or P2610[/TD]
[/TR]
[TR]
[TD]P2610[/TD]
[/TR]
[TR]
[TD]P2610[/TD]
[TD]DTC P2610 00: Control Module Ignition off Timer Performance[/TD]
[/TR]
[TR]
[TD]P2617[/TD]
[TD]DTC P2617 00: Crankshaft Position Signal Output Circuit[/TD]
[TD]1.3L (Diesel) engines - DTC P2617[/TD]
[/TR]
[TR]
[TD]P2617[/TD]
[TD]2.0L (Diesel) engines - DTC P2617[/TD]
[/TR]
[TR]
[TD]P261A
P261C
P261D[/TD]
[TD]DTC P261A 00: Engine Coolant Pump Control Circuit
DTC P261C 00: Engine Coolant Pump Control Circuit Low Voltage
DTC P261D 00: Engine Coolant Pump Control Circuit High Voltage[/TD]
[TD]DTC P261A, P261C, or P261D[/TD]
[/TR]
[TR]
[TD]P2626[/TD]
[TD]DTC P2626 00: HO2S Pump Current Trim Circuit Sensor 1[/TD]
[TD]1.3L (Diesel) engines - DTC P2626[/TD]
[/TR]
[TR]
[TD]P2626[/TD]
[TD]2.0L (Diesel) engines - DTC P2626[/TD]
[/TR]
[TR]
[TD]P2635[/TD]
[TD]DTC P2635: Fuel Pump Flow Performance[/TD]
[TD]1.4L (LDD, LUH, or LUJ) engines - DTC P2635[/TD]
[/TR]
[TR]
[TD]P2635[/TD]
[TD]1.6L (LDE, LLU, or LXV) or 1.8L (2H0) engines - DTC P2635[/TD]
[/TR]
[TR]
[TD]P2687[/TD]
[TD]DTC P2687 00: Fuel Heater Relay Control Circuit[/TD]
[TD]1.3L (Diesel) engines - DTC P2687-P2689[/TD]
[/TR]
[TR]
[TD]P2687[/TD]
[TD]2.0L (Diesel) engines - DTC P2687-P2689[/TD]
[/TR]
[TR]
[TD]P2688
P2689[/TD]
[TD]DTC P2688 00: Fuel Heater Relay Control Circuit Low Voltage
DTC P2689 00: Fuel Heater Relay Control Circuit High Voltage[/TD]
[/TR]
[TR]
[TD]P2688
P2689[/TD]
[TD]1.7L Diesel (LPL or LPV) engines - DTC P2688 or P2689[/TD]
[/TR]
[TR]
[TD]P2688
P2689[/TD]
[/TR]
[TR]
[TD]P268A[/TD]
[TD]DTC P268A: Fuel Injector Calibration Not Programmed[/TD]
[TD]DTC P268A or P2696[/TD]
[/TR]
[TR]
[TD]P268C
P268D
P268E
P268F[/TD]
[TD]DTC P268C: Cylinder 1 Injector Calibration Incorrect
DTC P268D: Cylinder 2 Injector Calibration Incorrect
DTC P268E: Cylinder 3 Injector Calibration Incorrect
DTC P268F: Cylinder 4 Injector Calibration Incorrect[/TD]
[TD]1.3L (Diesel) engines - DTC P268C-P268F[/TD]
[/TR]
[TR]
[TD]P268C
P268D
P268E
P268F[/TD]
[TD]2.0L (Diesel) engines - DTC P268C-P268F[/TD]
[/TR]
[TR]
[TD]P2696[/TD]
[TD]DTC P2696: Injector Calibration Incorrect[/TD]
[/TR]
[TR]
[TD]P2714
P2715[/TD]
[TD]DTC P2714: Pressure Control Solenoid Valve 4 Stuck Off
DTC P2715: Pressure Control Solenoid Valve 4 Stuck On[/TD]
[TD]DTC P2714 or P2715[/TD]
[/TR]
[TR]
[TD]P2716[/TD]
[TD]DTC P2716: Pressure Control Solenoid Valve 3 System Performance[/TD]
[TD]DTC P2716 or P2719-P2721[/TD]
[/TR]
[TR]
[TD]P2719
P2720
P2721[/TD]
[TD]DTC P2719: Pressure Control Solenoid Valve 3 System Performance
DTC P2720: Pressure Control Solenoid Valve 3 Control Circuit Low Voltage
DTC P2721: Pressure Control Solenoid Valve 3 Control Circuit High Voltage[/TD]
[TD]Automatic Transmission AF40-6 - DTC P2716 or P2719-P2721[/TD]
[/TR]
[TR]
[TD]P2719
P2720
P2721[/TD]
[TD]DTC P2719: Pressure Control Solenoid Valve 4 Performance
DTC P2720: Pressure Control Solenoid Valve 4 Control Circuit Low Voltage
DTC P2721: Pressure Control Solenoid Valve 4 Control Circuit High Voltage[/TD]
[TD]Automatic Transmission 6T30/6T40/6T45/6T50 - DTC P2719-P2721[/TD]
[/TR]
[TR]
[TD]P2723
P2724[/TD]
[TD]DTC P2723: Pressure Control Solenoid Valve 5 Stuck Off
DTC P2724: Pressure Control Solenoid Valve 5 Stuck On[/TD]
[TD]DTC P2723 or P2724[/TD]
[/TR]
[TR]
[TD]P2727[/TD]
[TD]DTC P2727: Brake Band Pressure Control Solenoid Valve Control Circuit Shorted[/TD]
[TD]DTC P2727, P2729, or P2730[/TD]
[/TR]
[TR]
[TD]P2728[/TD]
[TD]DTC P2728: Pressure Control Solenoid Valve 5 System Performance[/TD]
[TD]Automatic Transmission 6T30/6T40/6T45/6T50 - DTC P2728-P2730[/TD]
[/TR]
[TR]
[TD]P2729
P2730[/TD]
[TD]DTC P2729: Brake Band Pressure Control Solenoid Valve Control Circuit Low Voltage
DTC P2730: Brake Band Pressure Control Solenoid Valve Control Circuit High Voltage[/TD]
[TD]Automatic Transmission AF40-6 - DTC P2727, P2729, or P2730[/TD]
[/TR]
[TR]
[TD]P2729
P2730[/TD]
[TD]DTC P2729: Pressure Control Solenoid Valve 5 Control Circuit Low Voltage
DTC P2730: Pressure Control Solenoid Valve 5 Control Circuit High Voltage[/TD]
[/TR]
[TR]
[TD]P2761[/TD]
[TD]DTC P2761: Torque Converter Clutch (TCC) Pressure Control Solenoid Valve Performance[/TD]
[TD]Automatic Transmission AF40-6 - DTC P2761, P2763, or P2764[/TD]
[/TR]
[TR]
[TD]P2762[/TD]
[TD]DTC P2762: Torque Converter Clutch (TCC) Pressure Control Solenoid Valve Performance[/TD]
[TD]Automatic Transmission 6T30/6T40/6T45/6T50 - DTC P2762, P2763, or P2764[/TD]
[/TR]
[TR]
[TD]P2763
P2764[/TD]
[TD]DTC P2763: Torque Converter Clutch (TCC) Pressure Control Solenoid Valve Control Circuit High Voltage
DTC P2764: Torque Converter Clutch (TCC) Pressure Control Solenoid Valve Control Circuit Low Voltage[/TD]
[/TR]
[TR]
[TD]P2763
P2764[/TD]
[/TR]
[TR]
[TD]P2A00[/TD]
[TD]DTC P2A00 00: HO2S Circuit Closed Loop Performance Sensor 1[/TD]
[TD] 1.4L (LDD) engines - DTC P0133, P0134, P0140, P1133, P2270, P2271, or P2A00[/TD]
[/TR]
[TR]
[TD]P2A00[/TD]
[/TR]
[TR]
[TD]P2A00[/TD]
[/TR]
[TR]
[TD]P2A00[/TD]
[TD]DTC P2A00 53: HO2S Circuit Closed Loop Performance Bank 1 Sensor 1 Malfunction
DTC P2A00 54: HO2S Circuit Closed Loop Performance Bank 1 Sensor 1 Malfunction[/TD]
[TD]1.3L (Diesel) engines - DTC P2A00[/TD]
[/TR]
[TR]
[TD]P2A00[/TD]
[TD]DTC P2A00 53: HO2S Circuit Closed Loop Performance Bank 1 Sensor 1 Low Temperature
DTC P2A00 54: HO2S Circuit Closed Loop Performance Bank 1 Sensor 1 High Temperature[/TD]
[TD]2.0L (Diesel) engines - DTC P2A00[/TD]
[/TR]
[TR]
[TD]P3996[/TD]
[TD]DTC P3996 07: Control Module Performance[/TD]
[TD]1.3L (Diesel) engines - DTC P3996[/TD]
[/TR]
[TR]
[TD]P3996[/TD]
[TD]2.0L (Diesel) engines - DTC P3996[/TD]
[/TR]
Thanks Received: 8 in 8 posts
73
9:th-Apr-2015, 09:44:22
(This post was last modified: 2:nd-Apr-2022, 08:52:19 by Rusty2009.)
Control Module U Code List
This list includes all Data Communications related U-code DTCs in alphanumeric order with descriptors for all modules. Not all DTCs listed will be applicable to all vehicles.
This list going to be updated over time to include the links to more info.
[TR]
[TD]DTC[/TD]
[TD]DTC Descriptor[/TD]
[/TR]
[TR]
[TD]U0001 00[/TD]
[TD]High Speed CAN Bus Malfunction[/TD]
[/TR]
[TR]
[TD]U0001 04[/TD]
[TD]High Speed CAN Bus Malfunction Open[/TD]
[/TR]
[TR]
[TD]U0002 00[/TD]
[TD]High Speed CAN Bus[/TD]
[/TR]
[TR]
[TD]U0020 00[/TD]
[TD]Low Speed CAN Bus[/TD]
[/TR]
[TR]
[TD]U0073 00[/TD]
[TD]Control Module Communication Bus A Off[/TD]
[/TR]
[TR]
[TD]U0073 01[/TD]
[TD]Control Module Communication Bus A Off Short to Battery[/TD]
[/TR]
[TR]
[TD]U0073 02[/TD]
[TD]Control Module Communication Bus A Off Short to Ground[/TD]
[/TR]
[TR]
[TD]U0073 04[/TD]
[TD]Control Module Communication Bus A Off Open[/TD]
[/TR]
[TR]
[TD]U0073 71[/TD]
[TD]Control Module Communication Bus A Off Invalid Data[/TD]
[/TR]
[TR]
[TD]U0074 00[/TD]
[TD]Control Module Communication Bus B Off[/TD]
[/TR]
[TR]
[TD]U0077 00[/TD]
[TD]Control Module Chassis Expansion Communication Bus Off[/TD]
[/TR]
[TR]
[TD]U0078 00[/TD]
[TD]Control Module Low Speed Communication Bus Off[/TD]
[/TR]
[TR]
[TD]U007A 00[/TD]
[TD]Control Module High Voltage Energy Management Communication Bus Off[/TD]
[/TR]
[TR]
[TD]U0100 00[/TD]
[TD]Lost Communication With Engine Control Module[/TD]
[/TR]
[TR]
[TD]U0100 71[/TD]
[TD]Lost Communication With Engine Control Module Invalid Data[/TD]
[/TR]
[TR]
[TD]U0100 72[/TD]
[TD]Lost Communication With Engine Control Module Message Counter Incorrect[/TD]
[/TR]
[TR]
[TD]U0100 74[/TD]
[TD]Lost Communication With Engine Control Module Bus Signal Checksum Error[/TD]
[/TR]
[TR]
[TD]U0101 00[/TD]
[TD]Lost Communication With Transmission Control Module[/TD]
[/TR]
[TR]
[TD]U0101 71[/TD]
[TD]Lost Communication With Transmission Control Module Invalid Data[/TD]
[/TR]
[TR]
[TD]U0102 00[/TD]
[TD]Lost Communication with Transfer Case Control Module[/TD]
[/TR]
[TR]
[TD]U0102 71[/TD]
[TD]Lost Communication with Transfer Case Control Module Invalid Data[/TD]
[/TR]
[TR]
[TD]U0104 00[/TD]
[TD]Lost Communication With Cruise Control Module[/TD]
[/TR]
[TR]
[TD]U0104 02[/TD]
[TD]Lost Communication With Cruise Control Module Short to Ground[/TD]
[/TR]
[TR]
[TD]U0104 71[/TD]
[TD]Lost Communication With Cruise Control Module Invalid Data[/TD]
[/TR]
[TR]
[TD]U0104 72[/TD]
[TD]Lost Communication With Cruise Control Module Message Counter Incorrect[/TD]
[/TR]
[TR]
[TD]U0104 74[/TD]
[TD]Lost Communication With Cruise Control Module Bus Signal Checksum Error[/TD]
[/TR]
[TR]
[TD]U0105 00[/TD]
[TD]Lost Communication with Fuel Injector Control Module[/TD]
[/TR]
[TR]
[TD]U0109 00[/TD]
[TD]Lost Communication with Fuel Pump Control Module[/TD]
[/TR]
[TR]
[TD]U010F 00[/TD]
[TD]Lost Communication with Air Conditioning Control Module[/TD]
[/TR]
[TR]
[TD]U0111 00[/TD]
[TD]Lost Communication with Battery Energy Control Module[/TD]
[/TR]
[TR]
[TD]U0112 00[/TD]
[/TR]
[TR]
[TD]U0115 00[/TD]
[TD]Lost Communication with ECM 2[/TD]
[/TR]
[TR]
[TD]U0117 00[/TD]
[TD]Lost Communication With Power Take - Off Control Module[/TD]
[/TR]
[TR]
[TD]U0121 00[/TD]
[TD]Lost Communication With Electronic Brake Control Module[/TD]
[/TR]
[TR]
[TD]U0121 03[/TD]
[TD]Lost Communication With Electronic Brake Control Module Low Voltage[/TD]
[/TR]
[TR]
[TD]U0121 71[/TD]
[TD]Lost Communication With Electronic Brake Control Module Invalid Data[/TD]
[/TR]
[TR]
[TD]U0121 72[/TD]
[TD]Lost Communication With Electronic Brake Control Module Message Counter Incorrect[/TD]
[/TR]
[TR]
[TD]U0121 74[/TD]
[TD]Lost Communication With Electronic Brake Control Module Bus Signal Checksum Error[/TD]
[/TR]
[TR]
[TD]U0122 00[/TD]
[TD]Lost Communication With Vehicle Stability Control Module[/TD]
[/TR]
[TR]
[TD]U0125 00[/TD]
[TD]Lost Communication With Multi-axis Acceleration Sensor Module[/TD]
[/TR]
[TR]
[TD]U0125 71[/TD]
[TD]Lost Communication With Multi-axis Acceleration Sensor Module Invalid Data[/TD]
[/TR]
[TR]
[TD]U0125 72[/TD]
[TD]Lost Communication With Multi-axis Acceleration Sensor Module Message Counter Incorrect[/TD]
[/TR]
[TR]
[TD]U0125 74[/TD]
[TD]Lost Communication With Multi-axis Acceleration Sensor Module Bus Signal Checksum Error[/TD]
[/TR]
[TR]
[TD]U0126 00[/TD]
[TD]Lost Communication With Steering Wheel Angle Sensor Module[/TD]
[/TR]
[TR]
[TD]U0126 71[/TD]
[TD]Lost Communication With Steering Wheel Angle Sensor Module Invalid Data[/TD]
[/TR]
[TR]
[TD]U0126 72[/TD]
[TD]Lost Communication With Steering Wheel Angle Sensor Module Message Counter Incorrect[/TD]
[/TR]
[TR]
[TD]U0126 74[/TD]
[TD]Lost Communication With Steering Wheel Angle Sensor Module Bus Signal Checksum Error[/TD]
[/TR]
[TR]
[TD]U0126 5A[/TD]
[TD]Lost Communication With Steering Wheel Angle Sensor Module Not Plausible[/TD]
[/TR]
[TR]
[TD]U0128 00[/TD]
[TD]Lost Communication With Park Brake Control Module[/TD]
[/TR]
[TR]
[TD]U0128 71[/TD]
[TD]Lost Communication With Park Brake Control Module Invalid Data[/TD]
[/TR]
[TR]
[TD]U0128 72[/TD]
[TD]Lost Communication With Park Brake Control Module Message Counter Incorrect[/TD]
[/TR]
[TR]
[TD]U0128 74[/TD]
[TD]Lost Communication With Park Brake Control Module Bus Signal Checksum Error[/TD]
[/TR]
[TR]
[TD]U0129 00[/TD]
[TD]Lost Communication with Brake System Control Module[/TD]
[/TR]
[TR]
[TD]U0130 00[/TD]
[TD]Lost Communication With Electric Power Steering Control Module[/TD]
[/TR]
[TR]
[TD]U0130 71[/TD]
[TD]Lost Communication With Electric Power Steering Control Module Invalid Data[/TD]
[/TR]
[TR]
[TD]U0130 72[/TD]
[TD]Lost Communication With Electric Power Steering Control Module Message Counter Incorrect[/TD]
[/TR]
[TR]
[TD]U0130 74[/TD]
[TD]Lost Communication With Electric Power Steering Control Module Bus Signal Checksum Error[/TD]
[/TR]
[TR]
[TD]U0131 00[/TD]
[TD]Lost Communication With Power Steering Control Module[/TD]
[/TR]
[TR]
[TD]U0131 71[/TD]
[TD]Lost Communication With Power Steering Control Module Invalid Data[/TD]
[/TR]
[TR]
[TD]U0132 00[/TD]
[TD]Lost Communication With Suspension Control Module[/TD]
[/TR]
[TR]
[TD]U0133 00[/TD]
[TD]Lost Communication With Air Suspension Control Module[/TD]
[/TR]
[TR]
[TD]U0133 71[/TD]
[TD]Lost Communication With Air Suspension Control Module Invalid Data[/TD]
[/TR]
[TR]
[TD]U0136 00[/TD]
[TD]Lost Communication With Differential Control Module - Rear[/TD]
[/TR]
[TR]
[TD]U0136 71[/TD]
[TD]Lost Communication With Differential Control Module - Rear Invalid Data[/TD]
[/TR]
[TR]
[TD]U0139 00[/TD]
[/TR]
[TR]
[TD]U0139 71[/TD]
[TD]Lost Communication With Suspension Control Module Invalid Data[/TD]
[/TR]
[TR]
[TD]U0140 00[/TD]
[TD]Lost Communication With Body Control Module[/TD]
[/TR]
[TR]
[TD]U0140 08[/TD]
[TD]Lost Communication With Body Control Module Performance - Signal Invalid[/TD]
[/TR]
[TR]
[TD]U0140 71[/TD]
[TD]Lost Communication With Body Control Module Invalid Data[/TD]
[/TR]
[TR]
[TD]U0140 72[/TD]
[TD]Lost Communication With Body Control Module Message Counter Incorrect[/TD]
[/TR]
[TR]
[TD]U0140 74[/TD]
[TD]Lost Communication With Body Control Module Bus Signal Checksum Error[/TD]
[/TR]
[TR]
[TD]U0146 00[/TD]
[TD]Lost Communication with Gateway[/TD]
[/TR]
[TR]
[TD]U0151 00[/TD]
[TD]Lost Communication With Inflatable Restraint Sensing and Diagnostic Module[/TD]
[/TR]
[TR]
[TD]U0155 00[/TD]
[TD]Lost Communication With Instrument Cluster[/TD]
[/TR]
[TR]
[TD]U0158 00[/TD]
[TD]Lost Communication With Head-Up Display[/TD]
[/TR]
[TR]
[TD]U0159 00[/TD]
[TD]Lost Communication With Parking Assist Control Module[/TD]
[/TR]
[TR]
[TD]U0160 00[/TD]
[TD]Lost Communication With Chime Alarm Control Module[/TD]
[/TR]
[TR]
[TD]U0164 00[/TD]
[TD]Lost Communication with HVAC Control Module[/TD]
[/TR]
[TR]
[TD]U0166 00[/TD]
[TD]Lost Communication with Auxiliary Heater Control Module[/TD]
[/TR]
[TR]
[TD]U0167 00[/TD]
[TD]Lost Communication with Immobilizer Control Module[/TD]
[/TR]
[TR]
[TD]U0168 00[/TD]
[TD]Lost Communication With Keyless Entry Control Module[/TD]
[/TR]
[TR]
[TD]U016B 00[/TD]
[TD]Lost Communication with Electric A/C Compressor Control Module[/TD]
[/TR]
[TR]
[TD]U0170 00[/TD]
[TD]Lost Communication With Passenger Presence Detection Sensor Module[/TD]
[/TR]
[TR]
[TD]U0181 00[/TD]
[TD]Lost Communication With Headlamp Levelling Control Module[/TD]
[/TR]
[TR]
[TD]U0182 00[/TD]
[TD]Lost Communication With Lighting Control Module - Front[/TD]
[/TR]
[TR]
[TD]U0184 00[/TD]
[TD]Lost Communication With Radio[/TD]
[/TR]
[TR]
[TD]U0186 00[/TD]
[TD]Lost Communication With Speaker Amplifier Module[/TD]
[/TR]
[TR]
[TD]U0196 00[/TD]
[TD]Lost Communication With Rear Audio Control Module[/TD]
[/TR]
[TR]
[TD]U0191 00[/TD]
[TD]Lost Communication With Television[/TD]
[/TR]
[TR]
[TD]U0193 00[/TD]
[TD]Lost Communication With Digital Radio Receiver Control Module[/TD]
[/TR]
[TR]
[TD]U0197 00[/TD]
[TD]Lost Communication With Telephone Control Module[/TD]
[/TR]
[TR]
[TD]U0198 00[/TD]
[TD]Lost Communication With Telematic Control Module[/TD]
[/TR]
[TR]
[TD]U0201 00[/TD]
[TD]Lost Communication With Transfer Case Control Module[/TD]
[/TR]
[TR]
[TD]U0203 00[/TD]
[TD]Lost Communication With Left Rear Door Switch Panel Control Module[/TD]
[/TR]
[TR]
[TD]U0204 00[/TD]
[TD]Lost Communication With Right Rear Door Switch Panel Control Module[/TD]
[/TR]
[TR]
[TD]U0207 00[/TD]
[TD]Lost Communication With Moveable Roof Control Module[/TD]
[/TR]
[TR]
[TD]U0208 00[/TD]
[TD]Lost Communication With Memory Seat Control Module[/TD]
[/TR]
[TR]
[TD]U0209 00[/TD]
[TD]Lost Communication With Front Seat Heating Control Module[/TD]
[/TR]
[TR]
[TD]U0210 00[/TD]
[TD]Lost Communication With Rear Seat Heating Control Module[/TD]
[/TR]
[TR]
[TD]U0230 00[/TD]
[TD]Lost Communication With Liftgate Control Module[/TD]
[/TR]
[TR]
[TD]U0232 00[/TD]
[TD]Lost Communication With Side Object Detection Control Module - Left[/TD]
[/TR]
[TR]
[TD]U0233 00[/TD]
[TD]Lost Communication With Side Object Detection Control Module - Right[/TD]
[/TR]
[TR]
[TD]U0236 00[/TD]
[TD]Lost Communication With Steering Column Lock Module[/TD]
[/TR]
[TR]
[TD]U0237 00[/TD]
[TD]Lost Communication With Multimedia Player Interface Module[/TD]
[/TR]
[TR]
[TD]U023A 00[/TD]
[TD]Lost Communication With Vehicle Direction Camera Control Module[/TD]
[/TR]
[TR]
[TD]U0249 00[/TD]
[TD]Lost Communication With Rear Radio Audio Control Module[/TD]
[/TR]
[TR]
[TD]U0252 00[/TD]
[TD]Lost Communication With Trailer Interface Control Module[/TD]
[/TR]
[TR]
[TD]U0254 00[/TD]
[TD]Lost Communication With Remote Start Module[/TD]
[/TR]
[TR]
[TD]U0255 00[/TD]
[TD]Lost Communication With Info Display Module[/TD]
[/TR]
[TR]
[TD]U0256 00[/TD]
[TD]Lost Communication With Infotainment Faceplate Control Module[/TD]
[/TR]
[TR]
[TD]U0257 00[/TD]
[TD]Lost Communication With Info Display Module/Infotainment Faceplate Control Module[/TD]
[/TR]
[TR]
[TD]U0264 00[/TD]
[TD]Lost Communication With Camera Module - Rear[/TD]
[/TR]
[TR]
[TD]U0284 00[/TD]
[TD]Lost Communication with Active Grille Air Shutter 1 Motor Module[/TD]
[/TR]
[TR]
[TD]U0285 00[/TD]
[TD]Lost Communication with Active Grille Air Shutter 2 Motor Module[/TD]
[/TR]
[TR]
[TD]U0293 00[/TD]
[TD]Lost Communication with Hybrid Powertrain Control Module[/TD]
[/TR]
[TR]
[TD]U0301 00[/TD]
[TD]Software Incompatibility with Engine Control Module[/TD]
[/TR]
[TR]
[TD]U0302 00[/TD]
[TD]Software Incompatibility with Transmission Control Module[/TD]
[/TR]
[TR]
[TD]U0315 00[/TD]
[TD]Software Incompatibility with Electronic Brake Control Module[/TD]
[/TR]
[TR]
[TD]U0401 00[/TD]
[TD]Invalid Data Received from ECM[/TD]
[/TR]
[TR]
[TD]U0401 72[/TD]
[TD]Invalid Data Received from ECM Message Counter Incorrect[/TD]
[/TR]
[TR]
[TD]U0401 74[/TD]
[TD]Invalid Data Received from ECM Bus Signal Checksum Error[/TD]
[/TR]
[TR]
[TD]U0402 72[/TD]
[TD]Invalid Data Received From Transmission Control Module Message Counter Incorrect[/TD]
[/TR]
[TR]
[TD]U0402 73[/TD]
[TD]Invalid Data Received From Transmission Control Module Parity Error[/TD]
[/TR]
[TR]
[TD]U0402 74[/TD]
[TD]Invalid Data Received From Transmission Control Module Bus Signal Checksum Error[/TD]
[/TR]
[TR]
[TD]U0405 00[/TD]
[TD]Invalid Data Received From Cruise Control Module[/TD]
[/TR]
[TR]
[TD]U0405 71[/TD]
[TD]Invalid Data Received From Cruise Control Module Invalid Data[/TD]
[/TR]
[TR]
[TD]U0405 72[/TD]
[TD]Invalid Data Received From Cruise Control Module Message Counter Incorrect[/TD]
[/TR]
[TR]
[TD]U0405 74[/TD]
[TD]Invalid Data Received From Cruise Control Module Bus Signal Checksum Error[/TD]
[/TR]
[TR]
[TD]U0415 00[/TD]
[TD]Invalid Data Received From Electronic Brake Control Module[/TD]
[/TR]
[TR]
[TD]U0415 72[/TD]
[TD]Invalid Data Received From Electronic Brake Control Module Message Counter Incorrect[/TD]
[/TR]
[TR]
[TD]U0415 74[/TD]
[TD]Invalid Data Received From Electronic Brake Control Module Bus Signal Checksum Error[/TD]
[/TR]
[TR]
[TD]U0416 00[/TD]
[TD]Invalid Data Received From Vehicle Dynamics Control Module[/TD]
[/TR]
[TR]
[TD]U0416 72[/TD]
[TD]Invalid Data Received From Vehicle Dynamics Control Module Message Counter Incorrect[/TD]
[/TR]
[TR]
[TD]U0416 74[/TD]
[TD]Invalid Data Received From Vehicle Dynamics Control Module Bus Signal Checksum Error[/TD]
[/TR]
[TR]
[TD]U0418 00[/TD]
[TD]Invalid Data Received From Brake System Control Module[/TD]
[/TR]
[TR]
[TD]U0418 71[/TD]
[TD]Invalid Data Received From Brake System Control Module Invalid Data[/TD]
[/TR]
[TR]
[TD]U0418 72[/TD]
[TD]Invalid Data Received From Brake System Control Module Message Counter Incorrect[/TD]
[/TR]
[TR]
[TD]U0418 74[/TD]
[TD]Invalid Data Received From Brake System Control Module Bus Signal Checksum Error[/TD]
[/TR]
[TR]
[TD]U0422 00[/TD]
[TD]Invalid Data Received From Body Control Module[/TD]
[/TR]
[TR]
[TD]U0422 70[/TD]
[/TR]
[TR]
[TD]U0422 72[/TD]
[TD]Invalid Data Received From Body Control Module Message Counter Incorrect[/TD]
[/TR]
[TR]
[TD]U0422 74[/TD]
[TD]Invalid Data Received From Body Control Module Bus Signal Checksum Error[/TD]
[/TR]
[TR]
[TD]U0424 00[/TD]
[TD]Invalid Data Received From HVAC Control Module[/TD]
[/TR]
[TR]
[TD]U0432 00[/TD]
[TD]Invalid Data Received From Multi-axis Acceleration Sensor Module[/TD]
[/TR]
[TR]
[TD]U0432 72[/TD]
[TD]Invalid Data Received From Multi-axis Acceleration Sensor Module Message Counter Incorrect[/TD]
[/TR]
[TR]
[TD]U0432 74[/TD]
[TD]Invalid Data Received From Multi-axis Acceleration Sensor Module Bus Signal Checksum Error[/TD]
[/TR]
[TR]
[TD]U0438 71[/TD]
[TD]Invalid Data Received From Trailer Brake Control Module[/TD]
[/TR]
[TR]
[TD]U0465 00[/TD]
[TD]Invalid Data Received From Power Take-Off Control Module[/TD]
[/TR]
[TR]
[TD]U1501 00[/TD]
[TD]LIN Bus 1[/TD]
[/TR]
[TR]
[TD]U1502 00[/TD]
[TD]LIN Bus 2[/TD]
[/TR]
[TR]
[TD]U1510 00[/TD]
[TD](K9 Body Control Module) LIN Bus 1 Lost Communication With Device 0 (B67 Ultrasonic Intrusion Sensor)
(K33 HVAC Control Module) LIN Bus 1 Lost Communication With Device 0 (A26 HVAC Control)
(A11 Radio) LIN Bus 1 Lost Communication with Device 0 (A20 Radio/HVAC Control)[/TD]
[/TR]
[TR]
[TD]U1511 00[/TD]
[TD](K26 Headlamp Control Module) LIN Bus 1 Lost Communication With Device 1 (E13L Headlamp Assembly Left)[/TD]
[/TR]
[TR]
[TD]U1512 00[/TD]
[TD](K26 Headlamp Control Module) LIN Bus 1 Lost Communication With Device 2 (E13L Headlamp Assembly Left)[/TD]
[/TR]
[TR]
[TD]U1513 00[/TD]
[TD](K26 Headlamp Control Module) LIN Bus 1 Lost Communication With Device 3 (E13L Headlamp Assembly Left)[/TD]
[/TR]
[TR]
[TD]U1514 00[/TD]
[TD](K26 Headlamp Control Module) LIN Bus 1 Lost Communication With Device 4 (E13L Headlamp Assembly Left)[/TD]
[/TR]
[TR]
[TD]U1515 00[/TD]
[TD](K9 Body Control Module) LIN Bus 1 Lost Communication With Device 5 (M75 Windshield Wiper Motor)[/TD]
[/TR]
[TR]
[TD]U1516 00[/TD]
[TD](K9 Body Control Module) LIN Bus 1 Lost Communication With Device 6 (B110 Battery Sensor Module)[/TD]
[/TR]
[TR]
[TD]U1517 00[/TD]
[TD](K9 Body Control Module) LIN Bus 1 Lost Communication With Device 7 (Sunroof Sunshade Module)[/TD]
[/TR]
[TR]
[TD]U1519 00[/TD]
[TD](K40 Seat Memory Control Module) LIN Bus 1 Lost Communication With Device 9 (S52 Outside Rearview Mirror Switch)
(K40 Seat Memory Control Module) LIN Bus 1 Lost Communication With Device 9 (K96 Mirror Control Module)[/TD]
[/TR]
[TR]
[TD]U151A 00[/TD]
[TD](K9 Body Control Module) LIN Bus 1 Lost Communication With Device 10 (B117 Windshield Outside Moisture Sensor)[/TD]
[/TR]
[TR]
[TD]U151B 00[/TD]
[TD](K9 Body Control Module) LIN Bus 1 Lost Communication With Device 11 (K61 Sunroof Control Module)
(K40 Seat Memory Control Module) LIN Bus 1 Lost Communication With Device 11 (S79P Window Switch - Passenger)[/TD]
[/TR]
[TR]
[TD]U1520 00[/TD]
[TD](K9 Body Control Module) LIN Bus 2 Lost Communication With Device 0 (P25 Power Sounder Content Theft Deterrent Alarm Module)[/TD]
[/TR]
[TR]
[TD]U1521 00[/TD]
[TD](K26 Headlamp Control Module) LIN Bus 2 Lost Communication With Device 1 (E13R Headlamp Assembly Right)[/TD]
[/TR]
[TR]
[TD]U1522 00[/TD]
[TD](K9 Body Control Module) LIN Bus 2 Lost Communication With Device 2 (K65 Tire Pressure Indicator Module)
(K26 Headlamp Control Module) LIN Bus 2 Lost Communication With Device 2 (E13R Headlamp Assembly Right)[/TD]
[/TR]
[TR]
[TD]U1523 00[/TD]
[TD](K26 Headlamp Control Module) LIN Bus 2 Lost Communication With Device 3 (E13R Headlamp Assembly Right)[/TD]
[/TR]
[TR]
[TD]U1524 00[/TD]
[TD](K9 Body Control Module) LIN Bus 2 Lost Communication With Device 4 (Front Seat Heating Control Module)
(K26 Headlamp Control Module) LIN Bus 2 Lost Communication With Device 4 (E13R Headlamp Assembly Right)[/TD]
[/TR]
[TR]
[TD]U1526 00[/TD]
[TD](K9 Body Control Module) LIN Bus 2 Lost Communication With Device 6 (Rear Seat Heating Control Module)[/TD]
[/TR]
[TR]
[TD]U152C 00[/TD]
[TD](K9 Body Control Module) LIN Bus 2 Lost Communication With Device 12 (K18 Electronic Compass Module)[/TD]
[/TR]
[TR]
[TD]U152D 00[/TD]
[TD](K9 Body Control Module) LIN Bus 2 Lost Communication With Device 13 (S3 Automatic Gearbox Change Lever)[/TD]
[/TR]
[TR]
[TD]U1530 00[/TD]
[TD](K9 Body Control Module) LIN Bus 3 Lost Communication With Device 0 (M74P Window Motor - Passenger)
(INSIGNIA only: Left Hand Drive: M74P Window Motor - Passenger, Right Hand Drive: M74D Window Motor - Driver)[/TD]
[/TR]
[TR]
[TD]U1534 00[/TD]
[TD](K9 Body Control Module) LIN Bus 3 Lost Communication With Device 4 (M74D Window Motor - Driver)
(INSIGNIA only: Left Hand Drive: M74D Window Motor - Driver, Right Hand Drive: M74P Window Motor - Passenger)[/TD]
[/TR]
[TR]
[TD]U1538 00[/TD]
[TD](K9 Body Control Module) LIN Bus 3 Lost Communication With Device 8 (S79D Window Switch - Driver)[/TD]
[/TR]
[TR]
[TD]U153A 00[/TD]
[TD](K9 Body Control Module) LIN Bus 3 Lost Communication With Device 10 (S79P Window Switch - Passenger)[/TD]
[/TR]
[TR]
[TD]U1540 00[/TD]
[TD](K9 Body Control Module) LIN Bus 4 Lost Communication With Device 0 (M74RR Window Motor - Right Rear)[/TD]
[/TR]
[TR]
[TD]U1544 00[/TD]
[TD](K9 Body Control Module) LIN Bus 4 Lost Communication With Device 4 (M74LR Window Motor - Left Rear)[/TD]
[/TR]
[TR]
[TD]U1548 00[/TD]
[TD](K9 Body Control Module) LIN Bus 4 Lost Communication With Device 8 (S79LR Window Switch - Left Rear)[/TD]
[/TR]
[TR]
[TD]U154A 00[/TD]
[TD](K9 Body Control Module) LIN Bus 4 Lost Communication With Device 10 (S79RR Window Switch - Right Rear)[/TD]
[/TR]
[TR]
[TD]U154B 00[/TD]
[TD](K9 Body Control Module) LIN Bus 4 Lost Communication With Device 11 (K49 Rear Seat Control Module)[/TD]
[/TR]
[TR]
[TD]U1793 00[/TD]
[TD]14 V Power Module Lost Communication with Hybrid Powertrain Control Module on Powertrain Expansion Communication Bus[/TD]
[/TR]
[TR]
[TD]U1795 00[/TD]
[TD]14 V Power Module Powertrain Expansion Communication Bus Off[/TD]
[/TR]
[TR]
[TD]U179A 00[/TD]
[TD]Lost Communication with Hybrid Powertrain Control Module 2[/TD]
[/TR]
[TR]
[TD]U1803 00[/TD]
[/TR]
[TR]
[TD]U1806 00[/TD]
[TD]Battery Energy Control Module High Voltage Energy Management Communication Bus Off[/TD]
[/TR]
[TR]
[TD]U1807 00[/TD]
[TD]Battery Charger Control Module High Voltage Energy Management Communication Bus Off[/TD]
[/TR]
[TR]
[TD]U180A 00[/TD]
[TD]Electric A/C Compressor Control Module High Speed Communication Bus Off[/TD]
[/TR]
[TR]
[TD]U180B 00[/TD]
[TD]Battery Energy Control Module High Speed Communication Bus Off[/TD]
[/TR]
[TR]
[TD]U180C 00[/TD]
[TD]Battery Charger Control Module High Speed Communication Bus Off[/TD]
[/TR]
[TR]
[TD]U180D 00[/TD]
[TD]Electronic Brake Control Module Chassis Expansion Communication Bus Off[/TD]
[/TR]
[TR]
[TD]U1811 00[/TD]
[TD]Battery Energy Control Module Powertrain Expansion CAN Bus Off[/TD]
[/TR]
[TR]
[TD]U1814 01[/TD]
[TD]Powertrain Wake Up Communication Circuit Short to Battery[/TD]
[/TR]
[TR]
[TD]U1814 02[/TD]
[TD]Powertrain Wake Up Communication Circuit Short to Ground[/TD]
[/TR]
[TR]
[TD]U1814 04[/TD]
[TD]Powertrain Wake Up Communication Circuit Open[/TD]
[/TR]
[TR]
[TD]U1815 00[/TD]
[TD]Lost Communication with Drive Motor Control Module A on Powertrain Expansion Communication Bus[/TD]
[/TR]
[TR]
[TD]U1816 00[/TD]
[TD]Lost Communication with Drive Motor Control Module B on Powertrain Expansion Communication Bus[/TD]
[/TR]
[TR]
[TD]U1817 00[/TD]
[TD]Lost Communication with Hybrid Powertrain Control Module on Powertrain Expansion Communication Bus[/TD]
[/TR]
[TR]
[TD]U1818 00[/TD]
[TD]Lost Communication with Engine Control Module on Powertrain Expansion Communication Bus[/TD]
[/TR]
[TR]
[TD]U1821 00[/TD]
[TD]Lost Communication with 14 V Power Module on Powertrain Expansion Communication Bus[/TD]
[/TR]
[TR]
[TD]U1826 00[/TD]
[TD]Lost Communication With Multi-Axis Acceleration Sensor Module on Bus B (Chassis Expansion Bus)[/TD]
[/TR]
[TR]
[TD]U1827 00[/TD]
[TD]Lost Communication With Steering Angle Sensor Module on Bus B (Chassis Expansion Bus)[/TD]
[/TR]
[TR]
[TD]U182D 00[/TD]
[TD]Lost Communication with Hybrid Powertrain Control Module 2 on Powertrain Expansion Communication Bus[/TD]
[/TR]
[TR]
[TD]U182E 00[/TD]
[TD]Drive Motor Control Module 1 Lost Communication with Hybrid Powertrain Control Module 2 on Powertrain Expansion Communication Bus[/TD]
[/TR]
[TR]
[TD]U182F 00[/TD]
[TD]Drive Motor Control Module 2 Lost Communication with Hybrid Powertrain Control Module 2 on Powertrain Expansion Communication Bus[/TD]
[/TR]
[TR]
[TD]U1831 00[/TD]
[TD]Drive Motor Control Module A Lost Communication with Hybrid Powertrain Control Module on Powertrain Expansion CAN Bus[/TD]
[/TR]
[TR]
[TD]U1833 00[/TD]
[TD]Lost Communication with Electronic Brake Control Module on Chassis Expansion Communication Bus[/TD]
[/TR]
[TR]
[TD]U1838 00[/TD]
[TD]Lost Communication with Battery Charger Control Module on High Voltage Energy Management Communication Bus[/TD]
[/TR]
[TR]
[TD]U1839 00[/TD]
[TD]Auxiliary Transmission Fluid Pump Control Module Lost Communication with Engine Control Module[/TD]
[/TR]
[TR]
[TD]U183A 00[/TD]
[TD]Lost Communication with OnStar Module[/TD]
[/TR]
[TR]
[TD]U183B 00[/TD]
[TD]Auxiliary Transmission Fluid Pump Control Module Lost Communication with Transmission Control Module[/TD]
[/TR]
[TR]
[TD]U183C 00[/TD]
[TD]Auxiliary Transmission Fluid Pump Control Module Lost Communication with Hybrid Powertrain Control Module 2 on Powertrain Expansion Communication Bus[/TD]
[/TR]
[TR]
[TD]U183E 00[/TD]
[TD]Lost Communication with OnStar Module on Low Speed Communication Bus[/TD]
[/TR]
[TR]
[TD]U1844 00[/TD]
[TD]Battery Energy Control Module Lost Communication with Hybrid Powertrain Control Module on Powertrain Expansion Communication Bus[/TD]
[/TR]
[TR]
[TD]U1845 00[/TD]
[TD]Drive Motor Control Module 1 Lost Communication with Hybrid Powertrain Control Module[/TD]
[/TR]
[TR]
[TD]U1846 00[/TD]
[TD]Drive Motor Control Module 2 Lost Communication with Hybrid Powertrain Control Module[/TD]
[/TR]
[TR]
[TD]U1849 00[/TD]
[TD]Drive Motor Control Module 1 Lost Communication with Transmission Control Module[/TD]
[/TR]
[TR]
[TD]U184B 00[/TD]
[TD]Lost Communication with Electronic Climate Control Module on Low Speed Communication Bus[/TD]
[/TR]
[TR]
[TD]U184C 00[/TD]
[TD]Lost Communication with Instrument Cluster on Low Speed Communication Bus[/TD]
[/TR]
[TR]
[TD]U184D 00[/TD]
[TD]Lost Communication with Radio on Low Speed Communication Bus[/TD]
[/TR]
[TR]
[TD]U184E 00[/TD]
[TD]Lost Communication with Inflatable Restraint Sensing and Diagnostic Module on Low Speed Communication Bus[/TD]
[/TR]
[TR]
[TD]U184F 00[/TD]
[TD]Electric A/C Compressor Control Module Lost Communication with Engine Control Module[/TD]
[/TR]
[TR]
[TD]U1850 00[/TD]
[TD]Drive Motor Control Module 2 Lost Communication with Transmission Control Module[/TD]
[/TR]
[TR]
[TD]U1858 00[/TD]
[TD]Electronic Brake Control Module Lost Communication with Hybrid Powertrain Control Module on Chassis Expansion Communication Bus[/TD]
[/TR]
[TR]
[TD]U185A 00[/TD]
[TD]Lost Communication with Battery Energy Control Module on High Voltage Energy Management Communication Bus[/TD]
[/TR]
[TR]
[TD]U185B 00[/TD]
[TD]Battery Energy Control Module Lost Communication with Hybrid Powertrain Control Module 2 on High Voltage Energy Management Communication Bus[/TD]
[/TR]
[TR]
[TD]U185C 00[/TD]
[TD]Battery Charger Control Module Lost Communication with Hybrid Powertrain Control Module 2 on High Voltage Energy Management Communication Bus[/TD]
[/TR]
[TR]
[TD]U185D 00[/TD]
[TD]Fuel Injector Control Module Lost Communication with Engine Control Module[/TD]
[/TR]
[TR]
[TD]U185E 00[/TD]
[TD]Fuel Injector Control Module Lost Communication with Body Control Module[/TD]
[/TR]
[TR]
[TD]U1860 00[/TD]
[TD]Electric A/C Compressor Control Module Lost Communication with Hybrid Powertrain Control Module 2[/TD]
[/TR]
[TR]
[TD]U1861 00[/TD]
[TD]Battery Charger Control Module Lost Communication with Engine Control Module[/TD]
[/TR]
[TR]
[TD]U186A 00[/TD]
[TD]Electronic Brake Control Module Lost Communication with Engine Control Module[/TD]
[/TR]
[TR]
[TD]U186A 00[/TD]
[TD]Electronic Brake Control Module Lost Communication with Transmission Control Module[/TD]
[/TR]
[TR]
[TD]U1876 00[/TD]
[TD]Drive Motor Control Module 1 Lost Communication with Engine Control Module[/TD]
[/TR]
[TR]
[TD]U1879 00[/TD]
[TD]Drive Motor Control Module 2 Lost Communication with Engine Control Module[/TD]
[/TR]
[TR]
[TD]U1885 00[/TD]
[TD]Battery Energy Control Module Lost Communication with Hybrid Powertrain Control Module[/TD]
[/TR]
[TR]
[TD]U1886 00[/TD]
[TD]Battery Energy Control Module Lost Communication with Engine Control Module[/TD]
[/TR]
[TR]
[TD]U1888 00[/TD]
[TD]Hybrid Powertrain Control Module Lost Communication with Battery Energy Control Module[/TD]
[/TR]
[TR]
[TD]U18B9 00[/TD]
[TD]Primary High Speed CAN Bus Subnet Configuration List[/TD]
[/TR]
[TR]
[TD]U18BF 00[/TD]
[TD]Secondary High Speed CAN Bus Subnet Configuration List[/TD]
[/TR]
[TR]
[TD]U1900 00[/TD]
[TD]Lost Communication With Speech to Text Interface Module[/TD]
[/TR]
[TR]
[TD]U1901 00[/TD]
[TD]Lost Communication With Front Controls Multifunction Interface Module[/TD]
[/TR]
[TR]
[TD]U2099 00[/TD]
[TD]High Speed Communication Enable Circuit[/TD]
[/TR]
[TR]
[TD]U2099 01[/TD]
[TD]High Speed Communication Enable Circuit Short to Battery[/TD]
[/TR]
[TR]
[TD]U2099 02[/TD]
[TD]High Speed Communication Enable Circuit Short to Ground[/TD]
[/TR]
[TR]
[TD]U2099 04[/TD]
[TD]High Speed Communication Enable Circuit Open[/TD]
[/TR]
[TR]
[TD]U2099 5A[/TD]
[TD]High Speed Communication Enable Circuit Not Plausible[/TD]
[/TR]
[TR]
[TD]U2100 00[/TD]
[TD]CAN Bus Communication[/TD]
[/TR]
[TR]
[TD]U2101 00[/TD]
[TD]CAN Bus Maximum Configuration List[/TD]
[/TR]
[TR]
[TD]U2103 00[/TD]
[TD]Fewer Controllers On Bus Than Programmed[/TD]
[/TR]
[TR]
[TD]U2105 00[/TD]
[TD]Lost Communication with Engine Control Module[/TD]
[/TR]
[TR]
[TD]U2106 00[/TD]
[TD]Lost Communication with Transmission Control Module[/TD]
[/TR]
[TR]
[TD]U2107 00[/TD]
[TD]Lost Communication with Body Control Module[/TD]
[/TR]
[TR]
[TD]U2108 00[/TD]
[TD]Lost Communication with Electronic Brake Control Module[/TD]
[/TR]
[TR]
[TD]U2127 00[/TD]
[TD]Lost Communication with Front HVAC Control Module[/TD]
[/TR]
[TR]
[TD]U2139 00[/TD]
[TD]Lost Communication with Column Integrated Module[/TD]
[/TR]
[TR]
[TD]U2144 00[/TD]
[TD]Lost Communication with Distance Sensing Cruise Control Module[/TD]
[/TR]
[TR]
[TD]U2176 00[/TD]
[TD]Lost Communication with Power Take-Off Control Module[/TD]
[/TR]
[TR]
[TD]U2178 00[/TD]
[/TR]
[TR]
[TD]U2400 00[/TD]
[TD]Fuel Injector Control Module High Speed CAN Bus Off[/TD]
[/TR]
[TR]
[TD]U2401 00[/TD]
[TD]Battery Energy Control Module Dedicated Bus 1 Off[/TD]
[/TR]
[TR]
[TD]U2602 00[/TD]
[TD]Battery Energy Control Module Lost Communication with Hybrid Powertrain Control Module 2[/TD]
[/TR]
[TR]
[TD]U2603 00[/TD]
[TD]Battery Energy Control Module Lost Communication with Hybrid Battery Interface Control Module 1[/TD]
[/TR]
[TR]
[TD]U2604 00[/TD]
[TD]Battery Energy Control Module Lost Communication with Hybrid Battery Interface Control Module 2[/TD]
[/TR]
[TR]
[TD]U2605 00[/TD]
[TD]Battery Energy Control Module Lost Communication with Hybrid Battery Interface Control Module 3[/TD]
[/TR]
[TR]
[TD]U2606 00[/TD]
[TD]Battery Energy Control Module Lost Communication with Hybrid Battery Interface Control Module 4[/TD]
[/TR]
[TR]
[TD]U2608 00[/TD]
[TD]Electric A/C Compressor Control Module Lost Communication with Hybrid Powertrain Control Module[/TD]
[/TR]
[TR]
[TD]U2609 00[/TD]
[TD]Battery Charger Control Module Lost Communication with Hybrid Powertrain Control Module[/TD]
[/TR]
[TR]
[TD]U2611 00[/TD]
[TD]Auxiliary Transmission Fluid Pump Control Module Lost Communication with Hybrid Powertrain Control Module[/TD]
[/TR]
[TR]
[TD]U2612 00[/TD]
[TD]Battery Charger Control Module Lost Communication with Hybrid Powertrain Control Module 2[/TD]
[/TR]
![[Image: vx.o.c.jpeg]](http://www.vxoc.org.uk/Images/vxoc%20astra-j-gtc/Logo/vx.o.c.jpeg)
Thanks Received: 1 in 1 posts
15
73
Thanks mate had to fix all the tables as they was not showing properly after the move so all done now and had to split the P codes up even more.
