cluster j k astra on
astra k cluster on astra j
In the last two days, i was wondering if its any solution to retrofit the cluster and the steering wheel from astra k.
In the picture the cluster connection its the same..but it will work ?
Myself & @Jpbroad1970 have played around with the insignia Custer and the steering wheel controls while it was possible to get the culster working with some tweaks to the wiring it wasn't possible to control it & the radio.
I know some have fitted the new control on the coloum but to me that's not good enough you can't be fumbling around on the side playing guessing games, I do need to re pick up the project but for now I'm busy on other projects.
I have a friend with a astra k maybe one day I will take his cluster to take it and test. Also a saw that his model have the same switch as the j that's why I was curious if they will fit. Maybe I will search for an pin schematic
  TPMS on Astra J GTC milozic 0 1,781 14:th-May-2023, 18:58:09
Last Post: milozic
  Digital cluster (virtual cockpit) retrofit milozic 5 6,328 30:th-Apr-2023, 19:51:49
Last Post: milozic
  insignia cluster into astra? Tylerrattv 48 34,274 30:th-Jul-2021, 18:27:37
Last Post: theendfear
  Rear camera fit on Opel astra sports tourer info ;) Alienbv 24 19,320 26:th-Dec-2019, 13:00:29
  parking and cluster upgrade Maniacu 5 9,432 8:th-Sep-2019, 13:06:46
Last Post: andre_rf
  Astra J Instrument Cluster 32pin wiring diagram Milo629 0 5,467 22:nd-Jan-2019, 14:55:13
Last Post: Milo629
  Astra J Coming Home Module / Key Signal Diagram EricMod 9 9,111 16:th-Jan-2019, 12:20:43
  Options to replace Navi 400 in 62 plate Astra Atarius 7 6,623 12:th-Sep-2018, 07:04:30
6 User(s) read this thread:
milozic (9:th-Sep-2023, 21:35:26), James37518 (15:th-Jan-2024, 01:24:49), greg848484 (11:th-Jun-2023, 15:56:25), ziTneY (16:th-Oct-2023, 21:05:59), meriva_turbo (10:th-Mar-2024, 00:53:32), NRunix (9:th-May-2024, 09:06:39)
