Thanks Received: 4 in 4 posts
No mate the run won't make a diffrace, I'll look into it more tomorrow when at PC.
Threads: 57
Car: Astra J SRI 2.0 CDTI
Cheers @rusty2009 appreciate that.
Part of me thinks the module could be wrong for the car but that's just a guess
I'm just trying to get the pinout for the DAB module but my offline version has gone haywire and for some reason I can't boot into my XP install, I will get there.
Threads: 57
No worries. Just so you know, the P/N for the module i have is 13410170
Threads: 57
Any joys @rusty2009?
Not yet mate looks like I need to re-install XP.
Threads: 57
What a mission lol.
No worries. I'll hold fire. It's still not burst into life anyway lol
20:th-Jul-2015, 09:53:42
(This post was last modified: 20:th-Jul-2015, 10:50:16 by Rusty2009.)
Right as you can see from the following there is no 12v power for the aerial from the DAB module.
Having a look at the A11 Radio plug Pin 43 has the remote enabled signal wire on it, so I will see if I can find where that is running to for you.
Update on the 7066 Remote enable wire.
I've found where it runs to for the aerial
So there are 2 possbile locations for it It will be Pin12 on both
X403 Tailgate Extension Harness to Body Harness (14 cavities) In the cargo area, near the left tail lamp assembly
Or
X404 Tailgate Extension Harness to Tailgate Harness (14 cavities) In the luggage compartment, in the tailgate
My bet would be X403 is the one to go for as it's the easiest to get to, Now I may even a pin for said plug but we need to know it works first.
I'll grab a pic of the plug for you that would help you find it.
Please see post above updated...
Threads: 57
20:th-Jul-2015, 12:30:38
(This post was last modified: 20:th-Jul-2015, 12:33:43 by bhalay207.)
I'm going to sound really thick now so please forgive that, but.... What does that mean in simple terms?
Also, your pin out screen shots say UBT on them. Does it make a difference that the ident on my module is U4D?
Let me check the sig pin out I totally forgot that
Right I think I know what's going on here looking at the wiring digram of a sig DAB module.
Although they are same there seems to be one small diffrance with the aerial. But I need to get the Pinout for the aerial and it's not on the offline.
I think you may well need this http://www.car-interface.com/vendita/en/...ifier.html
From what I can work out on the Insignia the 12v goes through the aerial port.
Threads: 57
So does that go in between the cable from the car and the module? Does the blue wire go into the plug?
Sorry to be a burden!!
Yes, I would grounding the blue wire.
Threads: 57
Ground it or attach it to a live (ie the red cable from the ariael)
Try grounding it 1st.
Threads: 57
Ok. I can take that off the lighter socket aswell so we'll see what happens.
Threads: 57
22:nd-Jul-2015, 19:29:01
(This post was last modified: 22:nd-Jul-2015, 19:38:17 by bhalay207.)
Back to square one on this unfortunately. The part arrived today (24hrs from Italy via DHL.... Not bad), Test wired it all in with no change and DAB did not come up.
I tried it in the following areas:
1) From car wiring direct to module. Tried both live and ground
2) Inbetween the wire for the aerial and the car (near the bonnet catch) again both live and ground.
I've attached some images of the fault code and the programming info of the module in case it give you guys any further insight
This is the label on the module i have
14
22:nd-Jul-2015, 19:44:39
(This post was last modified: 22:nd-Jul-2015, 19:45:06 by tucpal.)
I think it may well be the module being incorrect
Threads: 57
I'm starting to think this myself. With the help of @rusty2009 I've tried different things but it's not having it. I'm assuming that assuming I find a different module (which is not looking good at the moment) then it'll need to be reprogrammed?
14
if he enabled the option it may well work hopefully
correct part number 13319590 UBT..
I will keep an eye out
Threads: 57
If you can that will be great. Cheers mate.
The module it's self may need to programmed to your car. Really weird this as I've been told the Insigina ones will work.
Threads: 57
Is that not what ***** would have done when I plugged it in?
I wonder if it's because it's not a UBT module.
Yep I tried about 4 times on Lewis and although I could program the DAB module it wouldn't work until we got a VCI code
Threads: 57
There's the issue then. There was no mention of a VCI code when it was 'programmed'. I've emailed Andy and asked him to have a goose at this thread. He said the module should be ok but without a VCI code it won't work.
14
Are right I thought he did the programing already yes a vci would be needed for sure
Threads: 57
Just sent him a message. He's going to request a VCI to finish it off.
I can't really explain what's what as I don't know the system but he said that whilst he's willing to give it a go it doesn't give him an option for a VCI on the retrofit list.
I must admit though, I find him very helpful. I'm sure alot of other people would have not been bothered seeing as they'd already been paid. It's nice to know there's a supportive network in the Astra world.
Iirc it is on the list, if not he just goes to program the DAB module and selects VCI then request which he should know anyway.
14
MY 10.5 did not need a VCI but anything after that would need one
the DAB is not a common retro fit maybe he has not done one yet that needs one
sure he will sort it out
Threads: 57
Well just for home after my third visit to *****. Had the VCI loaded into the car and voila... DAB. To say I'm happy after so long is an understatement.... Rocking down the A38 to Kisstory.... Small things!
Glad your all up and running now ***** will know for next time that a VCI is required if no DAB after programming.
Threads: 57
I think it was a learning curve for both me and him.
Just out if interest, where it normally shows FM radio text on DAB it says either D1 National or the area that it's locked into the station. Is there an option to make it show the radio text. When I press info the text is there but it's not on the main display. From what I can gather the option for RDS text option is for FM not DAB.
Tucpal or Lewis will have to answer that one not have factory dab
14
My shows text etc but not sure there is a setting try config radio settings but I now have nav 500
Threads: 57
8:th-Aug-2015, 18:22:56
(This post was last modified: 8:th-Aug-2015, 18:23:31 by bhalay207.)
Over to you to explain then @Lewis6317
There's only something in RDS for radio text.
14
And well done glad you got it working
Just thought I'd say Vauxhall have a new DAB Plus module out part number 13435756 there is a TSB for this which I've come across today.
#14-E-3054: DAB Radio - No DAB Plus Function - (2014-08-04)
Threads: 57
11:th-Aug-2015, 12:13:37
(This post was last modified: 11:th-Aug-2015, 12:17:50 by bhalay207.)
I've read on a German forum that mine may be a DAB+ module, although there isn't DAB+ in the uk
http://www.motor-talk.de/forum/digitalra...ml?page=14
There's one on ebay at the moment for £10 less than what I paid for mine
http://r.ebay.com/8Y4meC
ah but most DAB products now to be DAB+ ready
Threads: 57
Makes sense. I'm sure we'll get it eventually. By the looks of things, it's been rolled out to some parts of Europe.
Threads: 57
(11:th-Aug-2015, 11:43:06)Rusty2009 Wrote: Just thought I'd say Vauxhall have a new DAB Plus module out part number 13435756 there is a TSB for this which I've come across today.
what is DAB+??
I know my fin is DAB+ but dont think my module is
(12:th-Aug-2015, 08:02:55)Lewis6317 Wrote: (11:th-Aug-2015, 11:43:06)Rusty2009 Wrote: Just thought I'd say Vauxhall have a new DAB Plus module out part number 13435756 there is a TSB for this which I've come across today.
what is DAB+??
http://www.which.co.uk/technology/audio/...explained/
14
Have to say the standard factory DAB does drop out very often in built up areas were I live
that'll be your aerial mate, when I was trying out glass mounted ones every-time the aerial was not facing the signals it would drop out.
14
Factory set up all fitted ok just a crap receiver I think
does it drop out same place in both directions of travel?
14
Yep always same place very built up part or the center of town also car parks it drops out also but FM is perfect
( 1)
Threads: 16
Car: 2.0 CDTi Elite
After many months finally got my DAB sorted thanks to Rusty. Very good upgrade on sound quality for the majority of the major stations, espcially with the sub in the back.
What I am very surprised at is the sound quality on some of the lesser known stations.
Who decided it was ok to do music at 64kbit MONO? (KISSTORY) get better quality with the pirate FM stations round here.
