in c navi950 retrofit zafira
Navi950 retrofit in Zafira C
Hello everyone,
I’m new to the forum and I’m from the Czech Republic. I drive a 2012 Opel Zafira C and I really like this car.
My original Navi 900 stopped working, so I decided to replace it with the Navi 950. I already have the Navi 950 unit, but I read that it needs different microphone wiring. Is that true? What exactly needs to be changed?
I’m not very experienced with retrofits, so I would really appreciate any help or advice. Has anyone here done this upgrade in a Zafira C? Was it difficult? Any problems with wiring, compatibility, or coding?
Thank you very much in advance!
The microphone is wired into the x4 plug.
You can buy a connector off AliExpress and pin a new cable into that and then into the BT module plug saves running a whole new cable.
In terms of programming for unlocking you need someone that has MDI, MDI2 or VCI and knows how to program them, if you have these I can help remotely.
(5:th-Aug-2025, 18:58:12)Rusty2009 Wrote: The microphone is wired into the x4 plug.
Thanks for the info.
Do you know which pins on the X4 connector are used for the microphone? I found a wiring diagram here on the forum, but on my X4 plug pin 6 is already occupied. Do you know what might be connected there?
Also, could you tell me exactly what type of connector I need to connect to the existing BT module cable?
I have already found someone who can handle the remote programming.
One final (and probably stupid) question: has anyone found a way to install custom apps (Spotify, Sygic, etc.) on the Navi 950?
(10:th-Aug-2025, 21:36:58)Happy25 Wrote: Thanks for the info.
https://www.aliexpress.com/item/1005003012228923.html?spm=a2g0o.order_list.order_list_main.256.44ca1802zcFGU2
18pin male one.
A111x4 pin 6 & 16 for mic
5 & 15 is rear camera.
Only way to add things like that is by adding touch screen and the wiring again needs custom programming to enable touch. Then a GROM Vline unit very expensive.
There is another unit being used which doesn't need a touch screen and is cheaper than the Grom but I don't know what the unit is called.
The following 1 user says Thank You to Rusty2009 for this post:
  • Happy25
18pin male one.
Thanks for the link — this will make my work a lot less messy  .
Do you know what might be connected to pin 6 on the original Navi 900 wiring? I attached a picture to my last post, but it seems it didn’t upload, so I’ll try again. Anyway, there is a yellow/brown wire connected to pin 6.
Regarding apps on the Navi 950 — I meant installed directly on the unit, because I’ve seen pictures of some preloaded apps (can’t remember exactly which ones), so I was wondering if anyone has ever successfully installed a custom app on it. Probably not, though.
I know about those units that connect between the Navi and the display, but the Grom is really expensive and my budget is quite tight :/ I found another unit that is much cheaper and looks promising — the Andream Wireless CarPlay / Android Auto. Is this the cheaper unit you were referring to, or has anyone here had experience with it? From the picture, the module has a different LVDS connector, but Navi 950 is listed as compatible. I’ll probably give it a try, since the latest map for the Navi 950 seems to be from around 2018 (correct me if I’m wrong), and I’ll be travelling more often now.
But first I need to get the Navi 950 itself working. Even though the unit is locked, at least I can now hear the turn signal chime.
Thanks again, and I’ll probably be posting here again soon.
  Zafira c - Shift knob not returning Jaegger 14 18,607 4:th-Feb-2019, 11:14:13
Last Post: Jaegger
  zafira gsi alternator zaffydom 0 11,355 27:th-Jul-2016, 15:54:48
Last Post: zaffydom
  Astra Reverse Camera Kit on Mokka with Navi950 krisbutler 4 14,332 5:th-Apr-2016, 21:43:05
Last Post: krisbutler
7 User(s) read this thread:
Rusty2009 (11:th-Aug-2025, 18:50:09), AlexFitton (24:th-Feb-2026, 00:19:39), Big Dave2 (18:th-Aug-2025, 16:29:03), chitaks (14:th-Aug-2025, 17:33:04), Happy25 (6:th-Oct-2025, 13:46:19), Feigenbaum (4:th-Sep-2025, 07:12:02), tanarchy (3:rd-Oct-2025, 15:15:13)
