returning shift c knob not zafira
Zafira c - Shift knob not returning
Hello to all.
I have a 2012 Zafira C (Tourer) and started to have a problem in the shift knob.
The shift drives normally for shifting gears, but the gear does not return to its original position by itself.
Same as this video : https://www.youtube.com/watch?v=5Bx6XjWofEw
Can anyone help, or already had this problem?
IS there an "easy" solution for this?
Thank you
Once in while mine does this no idea why lasts for 5mins or so then goes back to normal.
@vocky may have an answer.
Thank for your reply @Rusty.
Well mine has being doing this for a while now .. a few months i guess.
Its just really annoying, and i was wondering if :
1- Is is expensive to resolve
2 - left like this will bring later bigger problems .
J.
Hi have you tried removing the gaitor and greasing the linkage if its like my GTC its a nylon ball and the greese dos dry out used some spray grease on mine not for your problem but just the general rubbish gear change did help a bit like everything Vauxhall they where a bit tight on the lube front
(30:th-Jan-2019, 11:29:05)andyp Wrote: Hi have you tried removing the gaitor and greasing the linkage if its like my GTC its a nylon ball and the greese dos dry out used some spray grease on mine not for your problem but just the general rubbish gear change did help a bit like everything Vauxhall they where a bit tight on the lube front
Thanks for your help.
Unfortunaly i'm not a mechanic, but will bring that information near a known mechanic of mine.
J.
probably needs the gear linkage adjusting, which does not take long to do
(30:th-Jan-2019, 18:01:59)vocky Wrote: probably needs the gear linkage adjusting, which does not take long to do
Hello.
Does that job needs a qualified mechanic to perform? Or is it someone can do with youtube or something?
J
If you have an F40 gearbox: https://r.tapatalk.com/shareLink?share_f...are_type=t
(30:th-Jan-2019, 22:47:06)Telsun Wrote: If you have an F40 gearbox: https://r.tapatalk.com/shareLink?share_f...are_type=t
Hello.
How cna i tell wich is my gearbox?
I have a 2012 Zafira c, 2.0Diesel
Think it says in your handbook
(31:st-Jan-2019, 17:00:22)Telsun Wrote: Think it says in your handbook
Ok.
 Thank you for your help.
Will look into it
Thnkx
J.
What engine do you have?
(1:st-Feb-2019, 08:31:57)Rusty2009 Wrote: What engine do you have?
Hi there.
Its a 2.0 diesel, i think 165 hp
Thanks for any help
J.
Then you should have the F40 gearbox.
(2:nd-Feb-2019, 09:10:28)Rusty2009 Wrote: Then you should have the F40 gearbox.
Thanks.
Going to check the llnk above.
  Navi950 retrofit in Zafira C Happy25 4 2,266 11:th-Aug-2025, 18:41:42
Last Post: Happy25
  zafira gsi alternator zaffydom 0 11,283 27:th-Jul-2016, 15:54:48
Last Post: zaffydom
Happy25 (15:th-Jun-2025, 19:47:42)
