| sensors oem j parking astra |
ASTRA J OEM PARKING SENSORS
6:th-Feb-2019, 16:49:41
I have retrofitted the rear sensors and will be retrofitting the fronts at some point this year. You might need a VCI to make them work, depending on the year of your car
7:th-Feb-2019, 08:51:45
As Vocky has said.
There is no VCI needed for parking sensors on any any Astra-J just module programming. Astra-J 2.0 CDTI S/S
7:th-Feb-2019, 10:33:19
CAN YOU SAID THE PARTS?
9:th-Feb-2019, 08:20:02
20:th-Feb-2019, 13:46:57
Or New part number 39006734 SENSOR, SIDE RRP £37.25 Astra-J 2.0 CDTI S/S
27:th-Feb-2019, 22:45:54
12:th-Mar-2019, 07:39:06
14:th-Mar-2019, 08:47:31
(12:th-Mar-2019, 07:39:06)blacknik Wrote: Hello.can help somebody with the set of part numbers of parking sensors with bottom in dash? I've given you the parking sensor part number already. For the button in the dash it depends what else you have on that button. Astra-J 2.0 CDTI S/S
14:th-Mar-2019, 10:53:30
16:th-Mar-2019, 09:30:28
(14:th-Mar-2019, 10:53:30)blacknik Wrote: I HAVEN T NOTHING.ITS EMPTY.I WANT TO PUT ALL THE KIT.YOU SAID ONLY FOR THE SENSORS.THE OTHET PARTS?CABLES?MODULE?ETC!!!!@ There is no need to type in full capitals that wont help you get the info you want as it will put peoples backs up as it's considered as shouting on forums. I'm sorry I saw you asked for sensor part numbers. As I said in my last post the button depends on what you have fitted, also looms depend on what you have fitted I'm not going to list every single loom as I doubt you will even know which one you would need from the list. Supply your VIN or Reg number and I can find the correct parts needed for your car (if you a UK car) otherwise you would need to go to your dealership and ask if they could help supply you the part numbers. Astra-J 2.0 CDTI S/S
16:th-Mar-2019, 22:42:27
13306620 rear 13365681front.but the sensors have big holes!!
27:th-Jan-2021, 21:46:54
I need to replace one of my parking sensors its part number is 13368131 am I to get the same sensor or are there any other part numbers I can use sounds a dumb question but looking on ebay there are quite a few for the J but not with that number.
2:nd-Feb-2021, 09:53:51
2:nd-Feb-2021, 21:27:25
3:rd-Feb-2021, 19:58:42
| Who read this thread? |
| husky (Today, 06:53:21), TonyP (7:th-Dec-2025, 21:30:47) |
