That looks good to me mate
You need a U4D DAB module.
Thanks Rusty,
- Bracket -> 13263525
thanks!
Bracket yes.
Hi again,
some open questions:
Thanks!
.pdf   dab_sch.pdf (Size: 28.63 KB / Downloads: 32)
.pdf   A11 Radio X1.pdf (Size: 106.77 KB / Downloads: 28)
.pdf   A12 Digital Radio Receiver Control Module X1 (UBT).pdf (Size: 91.44 KB / Downloads: 28)
hoooooray!!
so
so
Please
  DAB retro fit for cars with the CD 400 tucpal 203 200,302 13:th-Mar-2021, 13:20:56
Last Post: Morpheus75
  POWER FOLD MIRRORS retro fit tucpal 121 152,079 19:th-Jan-2020, 09:18:53
  AUTO DIM ANTI DAZZLE REAR VIEW MIRROR retro fit tucpal 72 81,865 4:th-Aug-2019, 18:26:52
Last Post: KKEVANSKK
  USB factory retro fit tucpal 20 37,689 13:th-Jan-2018, 12:12:55
6 User(s) read this thread:
husky (29:th-Mar-2026, 19:28:18), milozic (29:th-Nov-2025, 13:58:44), obsidian (3:rd-Dec-2025, 13:34:44), jas7c5-2008 (1:st-Jan-2026, 18:35:46), Rustic302 (23:rd-Aug-2025, 11:39:07), tanarchy (3:rd-Oct-2025, 15:15:30)
