to stuck 900 cd600
cd600 to 900 stuck
HELP has anyone got a working Navi 600 to 900 upgrade CD  they could post to me i am stuck half way through having burned the image iso but cannot find how to copy the dnl file to disc any help would be appreciated as the head unit is useless at the minute i followed the instructions but hasnt worked and its stuck on boot 5 many thanks.
You need to use a good quality CD and also a USB drive.
(22:nd-Oct-2017, 21:09:55)Rusty2009 Wrote: You need to use a good quality CD and also a USB drive.
Hi rusty yes i did the usb bit ok i downloaded the iso file and burned the the entire contents to cd what is the dnl file thats also needed to copy to cd and how do you do it as i couldnt find it and would only allow me to select the entire iso file
Panic over just needed re burning all sorted i knew i had done it right as per the instructions it made me doubt myself thanks for reply.
  Android head unit stuck johnboy999 12 22,676 10:th-Apr-2018, 21:03:11
Last Post: johnboy999
orhunnx (19:th-Feb-2025, 03:23:33)
