area almost type dry grinding noise discs from front wheels
Dry, almost grinding type noise from front wheels / discs area
I have noticed a strange noise on my astra j. The noise sounds like when a brake disc lip may be slightly rubbing / touching the caliper. However, it is not this making the noise. The noise happens all the time. It doesnt change if i brake, turn left or right and it doesnt change with clutch or gear changes. If i push the car when it is off i can still hear it. Possibly from drive shaft area?? Has anyone else had this?
(1:st-Apr-2017, 17:03:21)rbull51 Wrote: I have noticed a strange noise on my astra j. The noise sounds like when a brake disc lip may be slightly rubbing / touching the caliper. However, it is not this making the noise. The noise happens all the time. It doesnt change if i brake, turn left or right and it doesnt change with clutch or gear changes. If i push the car when it is off i can still hear it. Possibly from drive shaft area?? Has anyone else had this?
Not a clue buddy might be your bearings but that would change when you turn, sounds stupid but you have meat on your brake pads right? Best bet is to go to a garage and make a friend then just ask them, that's what I do, or if you have a service due just go tithe same place and just nip down and ask don't ask you don't get. Good luck
On the edge of the brake pads is what's called a squeal shim. It's an audible warning that the brake pads are getting low and this squeal shim comes into contact with the edge of the brake disc and makes a noise. You need to whip the wheels off and take a very good look at how much meat is remaining on your brake pads. Don't just assume they're ok by looking through the wheel at the outer pads. From experience, it's the ones on the other side of the discs that wear down more than the ones you can see.
  Retrofit front parking sensors (GTC) pedroc1999 4 6,074 8:th-Apr-2025, 22:18:56
Last Post: johnny77
  Lowering springs identify front rear martinpe68 1 3,987 12:th-Sep-2021, 15:22:37
  1.4T Engine noise Nathan191210 1 3,777 29:th-Jun-2021, 09:05:07
Last Post: jay2801
  Wheels 3_crispies 1 3,056 2:nd-Feb-2021, 09:49:07
  Front PDC wiring diagram milozic 1 7,956 2:nd-Feb-2021, 09:33:19
  Front suspension knock????? Sri~mike 10 14,633 22:nd-Dec-2020, 10:21:36
Last Post: M222RJF
  VXR Front Bumper onto a 5dr Bear 2 6,343 3:rd-Oct-2020, 11:48:59
  2017 GTC Limited edition - Front wheel noise Nathan191210 4 6,352 12:th-Jul-2020, 07:37:10
  Gtc 2017 1.4t 120 front brake disc size Nathan191210 2 8,083 25:th-Apr-2020, 07:41:05
Changed my wheels - what you think? Vx-Mad-G 8 8,081 14:th-Apr-2020, 09:07:53
Last Post: Vx-Mad-G
