to files up animation 900 and nav600 how edit start theme
how to edit nav600/900 theme files and start up animation.
........... PART ONE .... HOW TO EDIT THEME FILES NAV 600 .... astra j / insignia ..............
You do This at Your own Risk if you Follow the How to Correctly
There Should be no Problems Thank You.
This how to will help you use the GM_RES_ PACKER/UNPACKER
and edit theme files on the Nav600 display
this will only work on a hacked Nav 600 after the Nav600/900 upgrade has been done for 3D maps.
this will not work on a standard Nav600 or Nav900 that has not had the upgrade done.
I hold no responsibility for anything that may go wrong it is up to yourself to do this correctly
and follow the instructions.
For the NAV600/900 upgrade see this link.
.... LINK ....
https://www.vxoc.org.uk/forum/Thread-how...o-a-NAV900
After you have done the download for the Nav600/900 upgraded 3d maps
you can download the GM_ RES_PACKER/UNPACKER.exe. here open it with winzip extract the files and save it to your documents.
...... LINK ......
 http://www.astra-faq.ru/download/GM_Res.zip
You will need a USB stick formated to fat32
And you will be editing the nav600/900iso files you downloaded to do the nav600/900 upgrade.
editing or adding a new theme will delte any POI.S you have added speedcams etc
so they will need to be added again after each theme change also check map mode and fav settings again.
image.22.uli. is the day theme.
image.11.uli. is the night theme.
image.14.uli. is start up animation.
I will show you how to edit the background color on the screen in this how to
this is just to show you how to do it
the same process will apply to any other thing you edit nav bars icons etc
you can use whatever you like to make an image paint, photo shop, etc.
Go to your documents and open the files MIGRATE_600to900 and click the DNL file till you come to g-mpeu10 and click on that
then you see a list of image files select the one you want i have selected images.22.uli. the day theme.
When you click the images.22.uli in the nav600/900 files
the gm_ res_ unpacker.exe will open then click the open file icon
then keep clicking the DNL files till it opens the images files list
and then select images.22.uli.
and then press open.
Next press the pack icon on the gm_ res_unpacker.exe
then close the gm_ res_unpacker.exe this will make a temp file to edit
in the nav600/900 files.
Next open the new temp file you have made
and keep pressing the dnl, dev files till it opens the images.22.uli. file images
you will now see the images that you can edit.
For the background image i have selected bg_without_anberbar.bng
i will just change the color to blue in paint and press save in paint
this will alter the image in the image files to a blue background.
Then close the Nav600/900 files and go back to your documents or wherever you have saved the gm_ res_packer.exe.
and open the file then select the gm_ res_packer.exe
press the open file icon and press the DNL DEV files till you see DEV/ images22.uli.spisok.hz then press save.
Next click the pack icon on the gm_res_packer.exe
and edit the file name images22.uli.new so it now says images22.uli.
and then press save and after that close the gm_res_packer.exe
Now go back to the Nav600/900 files
and press the DNL files again till you get back to the UIL list
then look for images.22.uli. and delete this file from the list.
Next go to the top of the list and click the temp file
and click it till you see the DEV file with the new images.22.uli you have made
then right click and copy the new images.22.uli.
then close the nav 600/900 files.
Open the Nav600/900 files again and click the DNL files
till you see the uil image file list and look for 21.uli and 23.uil
and right click and paste images.22.uli. into its correct position.
And the last thing to do is go to the top of the uil. list and delete the temp file from the nav600/900 files.
the files are now edited and repacked ready to load to a USB stick
and upload to the nav 600 and you can enjoy your new theme.
............................WARNINGS AND RECOVERY..............................
Remember the day theme has a black font and the night theme has a white font
so choose your background color carefully if it is too dark you will not see the fonts in day mode
and if you use white fonts for night mode the same thing will happen to the white fonts and that will not be good
and will make the words on the nav display disappear.
You can not add a night theme images.11.uli. to the day theme position image.22.uli
in the nav600/900 image file list this will make the navi display go blank
the same will happen if you try and add two night theme fonts to make the day and night letters go white
you can not just delte font_new.uli and replace it with font.uli. so you have two font.uli locations
this will make the display go blank and it must be recovered using the original nav600/900 usb stick and disc
you have to load the usb again push the center confirm knob then click left once and then press confirm again
this will be done when the screen has no image then waite 15mins and then load the disc
and wait till the nav display kicks back into life then the images on the display will then come back.
then load the usb again follow onscreen directions.
Examples of what is possible by editing the themes
can be found in the post below thanks.
.....Please read this.....
Remove any poi,s before doing an updated or new theme.
If you are doing a theme update and have upgraded the nav SD card to a newer version
than you used for the original nav 600/900 update
then you must remove the newer SD card
and then reinstall the SD card you first used before doing any new theme update etc
after the theme update has been done and the system has rebooted
then you can put your newer SD card back in and it will update the card again
then put any POI,S back on.
Anyone who has a nav 900 SD card will need a theme that runs with v200 or v208
the card will bring up all the files for voice recognition on the nav, usb, etc
and the nav will speak to you but you still can not talk to it.
Pressing the phone button on the nav unit first before pressing the steering wheel button
is a normal function of a nav900 the same would apply if you wanted to talk to the nav usb etc on a nav900.
The original nav600/900 update is a v181 file
most themes are v200 when you update a theme in full it will become a v200 file
you can swap or copy and paste a image file say uli.14. uli.22. and uli.11. from another v200 theme
but do not try and copy and paste any other resbin.file or system file or font.uli etc from a v208 or v181 file into a v200
as mixing system files will brick the nav unit.
best thing to do is just alter the uli.image files only and do not attempt to alter any system files at all
the gm-respacker will not repack any system batch files ,resbin etc it will only pack the image.uli.files.
some v200 theme files have had there poi icons set up with speed icons 30, 40, 50, etc
these have been edited and will show on the nav map and pop up speed camera icon
and the poi list in the nav settings as 40mph symbol etc
this type of theme files are best avoided as they look crap
you can not edit the resbin. to remove these symbols from the nav map so there best avoided.
what you want is the v200 files that have the poi icons for the speedcams image
they look much better and have the starry night sky in the night theme sat nav
to check you have the correct ones before you upload it to the car
look in image.20.uli with the gm-res unpacker and check the images for the speedcam image
if it has the 30, 40, 50, 60, etc look for a different theme.
Do not try and add two night themes or two day themes to a v181 v200 v208 file
same with fonts you need to have night and day or the text color will vanish.
there are v208 files out there there the latest files but they're no different to the v200 files
the problem will come when say if you made a mistake on the update of a theme with v208
and you have already used v208 before and the nav unit goes into bootloader mode
then you need a v208 res disc to recover the nav unit like you did when you first installed the original v181 3d map update
if you were to add the v181 disc if your v208 usb did crash then it could brick the nav
so if you are using v208 then stick with the v208 files and only update the images.uli.1 to 24 and you should have no problems.
if you have v208 and uploaded a v200 or v181 theme in full to the nav unit you risk going into bootloader mode and risk brick without the v208 res disk.
If you are unsure about doing any editing or updating don't be afraid to ask on here
beware also there are bad links out there as well as good ones on the interweb so we only recommend
you use links to themes that have been proven to work again we hold no responsibility
for anything that goes wrong doing this type of update is purely at your own risk.
......... PART TWO THEME OPTIONS AND START UP ANIMATION FILES NAV 600 ... astra j / insignia ........
Again this must be done after the nav600/900 3d map upgrade has been done first
this will delete any poi,speedcams fav settings etc so they will have to be re added after theme change.
Please read this thread for more info how to load to the car etc in post 36.
... LINK ....
There are ready made themes out there on the old interweb that you can just add to your nav600
if you are not that confident in making a theme yourself
but beware most are ok but some are missing info or corrupted or old dead links
so check them out and find if they are ok first.
More info can be found in this thread..in post number 36.
this will tell you how to download and use the files correctly so please read that post in full.
.... LINK ....
Here are the theme options i have at the moment for you to share
if you wish to add any of your own themes to the list then please do by all means.
no1 ..... WHITE DAY THEME WITH NIGHT CARBON THEME v208 files ......
All thanks goes to raimon.
Theme has insignia start up logo and animation this can be edited by yourself to what you like.
.... waiting for permission from raimon to use his link ....
..... NO2 .... WHITE DAY THEME WITH CARBON BARS AND RED NIGHT THEME ... v208 files
..... The theme comes with the standard vauxhall griffin logos .....
.............. Download link ...............
https://www.dropbox.com/s/0waly26327ze6c...s.zip?dl=0
NO3 .......... BLUE DAY THEME WITH RED NIGHT THEME ........ v208 files.
.. The theme comes with vauxhall griffin startup and standby logos .....
http://www.danrazor.net/Opel/NAVI900/Red..._DanRZ.rar
............... GRAY DAY AND RED NIGHT THEME v208 FILES .............
This theme comes with griffin startup and insignia standby logo.
you can edit the insignia bit out if you want.
..... DOWNLOAD LINK .....
https://www.dropbox.com/s/sfxsqjtvk6uocg...9.zip?dl=0
.............. START UP ANIMATION AND STANDBY LOGO NAV600 ..... astra j / insignia ........................
If you are are good at making start up animation you can make your own
Start up animation can be found and edited in images14.uli.
in the nav600/900 res files and will be edited the same way as in the above thread
using the gm_res_packer/unpacker the start up image is in images22.uli main image files
Standby logo is in the main nav600/900 files images22,uil, main image files
shutdown004_vauxall.png.
If anyone would like to add anything to this please feel free to do so thanks.
Here are some other theme links and startup animation
blue carbon tiger, red, gray.adam red etc.
i can not vouch for all of them working download at your own risk as always.
i know most of them do and most are v200 files
you will need google translate.
http://www.astra-faq.ru/tuning/tsvet-dis...0-900.html
...... Plus a few more start up animations if you have any to add please feel free to do so ......
Insignia startup animation option one.
https://drive.google.com/file/d/0B8c5T48...sp=sharing
insignia start up animation option 2.
http://yadi.sk/d/Lu3UiQB5KwLBF
Astra j .... startup animation option 1.
http://yadi.sk/d/TuHw2gpUJdWqz
astra j ... startup animation option 2.
http://yadi.sk/d/zYkqhmepKzjUS
astra j .... start up animation option 3.
http://yadi.sk/d/VgtuvZUvKzn6T
astra j ..... startup animation option 4.
http://yadi.sk/d/icSakXvgL25KL
astra GTC ... startup animation option 1.
http://yadi.sk/d/_GLBQzcfKwHpd
Astra GTC .... startup animation option 2.
.... Downloadlink ....
http://yadi.sk/d/NBVnqNO9KwzQ6
Astra GTC .... option 3.
http://yadi.sk/d/T9F_qhIvLDTFM
astra GTC ..... option 4.
http://yadi.sk/d/Lu6KYJYgLfwtt
Sports tourer .... option 1.
http://yadi.sk/d/4Y0smQA5KzeAo
Sports tourer .... option 2.
http://www.astra-faq.ru/download/themes/...TOURER.rar
Sports tourer .... option 3.
http://yadi.sk/d/bN6J0B5DLYwxM
OPEL .... startup animation option 1.
http://1drv.ms/1kk5MoP
OPEL .... startup animation option 2.
http://yadi.sk/d/k-hRnfR7Li3wk
I will show how to add one of the following start up animation logos from here for example
to your nav600/900 upgrade files or you chosen theme files.
First thing to do is go to your nav600/900 files
and click the dnl till you open the image file list
go to image.14.uli. and right click and delete this image from the list of image files.
Then go to your chosen start up theme and download the link
extract the file with winzip and save it to your documents
open the file and you will the images and a file called images.14.uli.
right click and copy this file.
Now go back to the nav600/900 files
and open the image list again
and right click and paste images.14.uil. back into its position.
And that's it now you can load it up to a USB stick
and upload it to your car happy days.
For how to load themes and startup animation to a usb and the nav unit etc please see the below link in post 36.
.....warnings Please read this.....
AS WITH ALL ELECTRICAL HOW TO,S
............ START UP ANIMATION NAV600 .... astra j / insignia .... PART 2 ............
This part will help us here in the uk or who have the griffin start up logo
and who want to use the downloaded startup links in the above post
as they are all set up for the opel badge start up theme files
so these files will need to be edited so they work in the correct file location for the nav units with the griffin logos.
Download your chosen startup animation and follow the above post and copy and paste the file image.uli.14. into its correct location
now after that go back to the nav600/900 file and again click the dnl until you open the list of image files
click on images.uli.14. and then open the temp file with the gm_res_umpacker.exe.
Next click the temp file at the top of the image file and click it until you come to the start up image files
and you will see all the standard start up image files for opel, vauxhall, vxr, etc.
You will also see the new image files that you have chosen but there is a problem
they have been replaced in the location of the ople files
so we need to swap the images we want to the griffin file location.
To swap the image we simply need to click the first griffin image and open it with paint
at the top left of the screen you will see a paste button click it and select paste from
then go to your documents and open the nav600/900 files and again click the dnl till you see the image file list
select the temp file and click it till you open the start up image files
and then select the first image from the start up theme you want and press save and then close paint.
You have now changed the first image location of the start up theme that you want
repeat the process until all 16 images have been changed
then repack the image.14.uli. with the gm-res-packer
and delte the image.14.uli. from the nav600/900 imagefile list and copy and paste the images.14.uli
back into location and delte the temp file and then upload to your car
and you will now have the new startup animation you wanted.
....................................................................... SHUTDOWN IMAGE LOGO CHANGE NAV600 ..... astra j / insignia ....................................................................
The same process can be used to change the standby logo on the shutdown screen
image file is in image.22.uli. on the main file list in the nav600/900 files
you need to edit the image shutdown.004_vauxhall.png for nav units with griffin logo.
and shutdown_003.png for cars with the ople logo.
You should now have all the now how on how to download a theme
download a start up animation theme and make a shutdown logo
and edit any image file icons etc that you like
this information has all been put together as there is a real lack of how to do this out there on the internet
so i really hope this helps you all out
if you have done a theme and would like to share it etc or just show what you have done
or if you have any other info you would like to add then please do so thank you.
So here are my current nav600 day and night themes, startup and standby themes
that i have done after playing about with the nav600 image files.
....... Start up animation .....
It starts off with the insignia car and then it starts to fade up into the insignia logo.
......... The day theme is gray with carbon bars .......
....... The night theme is red with carbon bars .........
........ The standby screen is the insignia siluet .........
I love that theme mate!
thanks mate took me a fair few themes etc to find the ones i am now happy with.
Are they actual themes or just wallpapers?
found another theme if anyone wants to try it out
black carbon knight theme with carbon strip for night theme
and it has the white standard day theme.
..... LINK .....
https://disk.yandex.ru/public/?hash=WvpG...hjaDiGI%3D
(28:th-May-2016, 12:04:41)sheppy1 Wrote: Are they actual themes or just wallpapers?
they are working themes mate they work just like the nav600/900 etc.
Ahhh right! Was thinking if I could use them on my unit that's all
no mate you need to have the the nav600 head unit for this to work
(28:th-May-2016, 13:49:18)sheppy1 Wrote: Ahhh right! Was thinking if I could use them on my unit that's all
Nothing to stop you using the images tho as a wallpaper
What a post Tupcal!
Thank you very much for all the info, extremely helpful!
Just one question concerning the startup logo. There are two sub folders in the dnl folder, g_eeu10 and g_mpeu10 and both of these have a file named images.14.uli. Do I overwrite the images.14.uli file in both folders or just one?
Only in one folder
Thanks.
Does anyone happen to have the repacked image.22.uil griffin standby logo file they could post as I'm unable to download the unpacker .exe as I only have access to a works laptop and I don't have the permissions to install programs.
so you just want the standard griffin startup and standby logos
on the theme files i sent you i will have a look for you
just checked the theme file i sent you so are you saying you are not getting the griffin but you are getting the ople start up
and you want the griffin is that correct
It's okay now...I think. I've used the GTC custom startup animation file and added that to one of the custom themes. I've also replaced the custom theme Opel standby logo with the griffin one from the 600 to 900 upgrade file. Hopefully that will work.
ok no problem here are the theme files with the griffin if you are not happy with what you have done
new carbon gray and carbon red theme with the griffin startup animation and the griffin standby logo.
https://www.dropbox.com/s/i2c4n7zdgeklzj...0.zip?dl=0
also i have some newer POIS and speedcams here much better.
so put them back on after the theme change
https://www.dropbox.com/sh/4x7fi5xyo5o89...4ZdWa?dl=0
(15:th-Jun-2016, 15:49:30)tucpal Wrote: ok no problem here are the theme files with the griffin if you are not happy with what you have done
Tucpal, you are a star, thank you. I've just updated to this theme and it looks great. I especially like that the top bar seems to be a lighter grey than other versions which means you can actually see the time and temperature. Also, I like that the clock and thermometer icons have gone. I just swapped the images.14.uil for a GTC startup logo so need to see if that works but the rest looks really good. Do you know if there is a version out there with GTC standby and startup images? I can't download the unpacker application due to restrictions on my laptop.
Pop back out to the car again in a minute to install the speed cam poi once I've wiped my usb drive.
Thanks again.
Loving the speedcam poi...no more star icon. Thanks.
For some reason my GTC startup animation didn't work, it's the standard griffin one instead.
I will do you one in a bit or in the morning
what startup animation do you want
with it the white gtc i will have a look about over the weekend for a standby logo
with the gtc or something on it
That would be awesome thank you. Just the GTC text for the startup if you can. I had one that was GTC text over a red map of the world which looked good but I couldn't get it to work. It was the 7th animation down on the link you have toward the top of this thread.
try this one gray carbon and red carbon theme with the white GTC car and GTC logo start up animation
and i have done a GTC standby logo for you also send some pictures to see how they work
the link will work on ople and uk cars if anyone else wants it
sometimes when you do multiple file uploads to the navi it may say it is done at say 13%
this is normal it will still change everything over.
Thanks. I'll try and install tomorrow night and post some pics.
Brilliant how 2 Tucpal.
I have some themes which I also like to share on here. I will put the links on once I got them ready.
I've installed the theme but can't seem to be able to add photos here. Looks good though. Thanks tucpal.
With regard the POI 50 mph zones show a 40mph icon.
Well there are themes that have been played with
glad your happy
Edited. Will try and post pics soon
Standby
Startup Animation 1/2
Startup Animation 2/2
they do look very good
glad i could help you out
Where are the bitmap bmp images held for the speedcam icons? I was wanting to edit them as it looks like the 40mph icon is showing for most speeds and not just 40mph.
Raimon may no that but my ones are ok
(19:th-Jun-2016, 13:32:23)tucpal Wrote: Raimon may no that but my ones are ok
Are you using one of my themes? If so I have replaced the modified resource.bin with the original from a stock theme. This is why you don't have that dark night sky in the navi mode. And also your other poi have got the correct category icon, instead of speed limits 30, 40, 50 etc. Now regards to which version of stock resource.bin, I am not sure without checking. But the themes I provide will be running v208 fw therefore have the resource.bin from stock v208. But I would stick with whatever fw the theme is using.
If you do download any themes from the Russian sites download the file with an st on the end of the file name iirc.
Example
Dark_theme_st.zip (this one)
Dark_theme_ru.zip (NOT this one)
Hope this makes sense.
Example
Not sure if it's one of your themes, it's the one tucpal posted a link for in post #18.
My main issue is the speedcam file
In that link. I've added it to my system but all cams show up with the 40mph icon and not the icon for that speed zone so I was wondering how I can change it.
That will be the problem then i think the theme i gave him was v200
i use v208 myself so i may have linked you the wrong speed cam
try this one instead
https://www.dropbox.com/s/1acgrkxbgwnsp00/myPOIs.zip
(23:rd-Jun-2016, 08:56:20)tucpal Wrote: That will be the problem then i think the theme i gave him was v200
That link is showing as disabled/unavailable
Is not the actual speedcamera poi file the issue. Its the resource.bin file. He needs the original v200 resource.bin That is where some of the poi icons are held.
(23:rd-Jun-2016, 00:42:52)C0ntax Wrote: My main issue is the speedcam file
You need this file to correct the issue you are having. You have to replace the file you have with this one. It is located in dnl\bin\system\adit\g_mpeu10
https://www.dropbox.com/s/qiif4w31dca4f8...0.zip?dl=0
I always say this "DO THIS AT YOUR OWN RISK"
I am currently testing some themes on my car that i am going to upload on here. I like to see if it works correctly on mine before uploading, so it take me a bit of time have a few, i test the navigation mode as well as the audio mode. Only thing i can't do is bluetooth. doh.
Thanks raimon. Problem I have is I can't download or install the unpacker application on my laptop as its s work laptop and I don't have permissions to install anything unfortunately so won't be able to swap that file.
How do you normally download the theme from here and extract the contents to place on the memory stick?
(23:rd-Jun-2016, 20:51:34)raimon Wrote: How do you normally download the theme from here and extract the contents to place on the memory stick?
Ignore me, just reread your instructions and realised I'd misunderstood. All done now. I'll try installing later today and feedback on here
I just tried it out and the icons are still showing incorrect mph. An example below...
(28:th-Jun-2016, 14:19:05)c0ntax Wrote: I just tried it out and the icons are still showing incorrect mph. An example below...
You did put it in to the correct folder right? dnl\bin\system\adit\g_mpeu10.
Can you take a pic of that folder on your computer and upload it.
Yeah it's in the right folder. Is the below what you're after?
I don't think you have replaced it with my version of the resource.bin file. The date modified should be 20/10/2015
Download the zip and extract, then replace the existing resource.bin with this one.
(28:th-Jun-2016, 15:48:44)raimon Wrote: I don't think you have replaced it with my version of the resource.bin file. The date modified should be 20/10/2015
Hi mate. Definitely is the one you posted its just that when I download from Dropbox and save to my laptop it changes the modified date to the date it was saved. It's done the same thing now with the latest one you posted. That had a modified date of 23 Jun but now shows 28 Jun after downloading and saving it.
Ah. Had a another read at your original question. Didn't realise you meant the popup alerts, i thought you meant the map icons. But anyway that resource.bin needed replacing as well to correct your map icons as it will say 40 for speed cameras and 50,60 for other categories. Images20.uli is what you need to edit.
This is what i changed mine to
(28:th-Jun-2016, 17:14:32)raimon Wrote: Ah. Had a another read at your original question. Didn't realise you meant the popup alerts, i thought you meant the map icons. But anyway that resource.bin needed replacing as well to correct your map icons as it will say 40 for speed cameras and 50,60 for other categories. Images20.uli is what you need to edit.
Ok. How do I edit images20.uli? If it requires using the unpacker I can't due to my laptop restrictions.
Ah yes forgot you are doing it on a work laptop. Any editing of uli files requires unpacking and repacking. It is worth investing in your own laptop.
I can upload my version of images20 later.
Thanks. Defo have to get my own laptop but if you could let me have the images20 file in the meantime that'd be great. Thanks for your help.
(28:th-Jun-2016, 21:06:34)C0ntax Wrote: Sent from my iPhone using Tapatalk
No worries pal. Give this a go. Download, extract, replace.
https://www.dropbox.com/s/2aez5bzj1xo4bn...0.zip?dl=0
Worked a treat. Thanks for your time and doing that.
  how to upgrade the NAV600 to a NAV900. tucpal 317 311,360 9:th-Sep-2021, 16:24:59
Last Post: gparini13
4 User(s) read this thread:
Morpheus75 (20:th-Dec-2024, 13:26:52), c4nny (16:th-May-2025, 23:57:23), carl_howells (15:th-Feb-2025, 10:18:49), Jordan_Sparkes (21:st-Jan-2025, 02:28:58)
