how to edit nav600/900 theme files and start up animation.
........... PART ONE .... HOW TO EDIT THEME FILES NAV 600 .... astra j / insignia ..............
You do This at Your own Risk if you Follow the How to Correctly
There Should be no Problems Thank You.
This how to will help you use the GM_RES_ PACKER/UNPACKER
and edit theme files on the Nav600 display
this will only work on a hacked Nav 600
