clean o2 dpf sensor location
Clean DPF - O2 sensor location
Is 02 sensor located under the car itself and not located within engine bay on my Vauxhall Astra SE CDTi 108 60 plate.
My car is jerking after a while and goes into limp mode (no engine lights) and have reduced revs.
Its been getting worse progressively car is fine on short trips but any more than say 20 minutes it starts especially when car is going uphill and under pressure.
Code shows dpf partially blocked.
Was gonna try use some cleaner directly into the dpf via the o2 sensor.
Car needs a new shock too and handbrake not holding great, dont want to spend loads on it if I cant fix the engine issue which I presume is a blocked dpf.
Is it easy to take the whole dpf off and soak it or am I best off just trying to clean in situ
Sent from my SM-S918B using Tapatalk
What Engine?
  Brake pedal sensor learn. Richiew1986 0 3,011 22:nd-Jul-2021, 16:53:31
Last Post: Richiew1986
  parking sensor Qaranc 1 3,874 8:th-Feb-2021, 01:33:43
Last Post: loeb
  Coolant light coming on when coolant is full (new sensor and no leaks) baffling me! Brasseyebaby 3 8,125 2:nd-Feb-2021, 21:12:47
  Glowplugs with pressure sensor or not Euroshopper 3 5,735 2:nd-Nov-2020, 16:01:21
  DPF pressure sensor richardhmorgan1 3 7,004 24:th-Sep-2019, 20:08:31
Last Post: Saunter
  Parking sensor Mspencer 2 5,118 19:th-Dec-2017, 17:34:12
  After a clean [emoji3] Jon3sy 1 4,934 13:th-Aug-2017, 07:29:08
  A/C pressure sensor location scotchmist67 0 4,329 2:nd-Aug-2017, 10:04:34
Last Post: scotchmist67
  Climate control sensor SectorOMEGA 4 6,504 22:nd-Jul-2017, 08:35:22
  Pedal box remote location Jon_es 11 11,751 15:th-Jun-2017, 13:25:25
Last Post: Jon_es
Rusty2009 (Yesterday, 17:31:05), Henhead78 (Yesterday, 13:32:18)
