24:th-Apr-2026, 13:31:43
Is 02 sensor located under the car itself and not located within engine bay on my Vauxhall Astra SE CDTi 108 60 plate.
My car is jerking after a while and goes into limp mode (no engine lights) and have reduced revs.
Its been getting worse progressively car is fine on short trips but any more than say 20 minutes it starts especially when car is going uphill and under pressure.
Code shows dpf partially blocked.
Was gonna try use some cleaner directly into the dpf via the o2 sensor.
Car needs a new shock too and handbrake not holding great, dont want to spend loads on it if I cant fix the engine issue which I presume is a blocked dpf.
Is it easy to take the whole dpf off and soak it or am I best off just trying to clean in situ
Sent from my SM-S918B using Tapatalk
