chassis j sport astra lowered standard shock on vs
astra j shock on standard vs lowered sport chassis
hello, im doing a research if shock absorber from astra with lowered chassis would fit the standard chassis.
i understand on lowered chassis a spring is "shorter" but what about shocks? would they fit on standard spring, would the shock act stiffer or same?
The shocks are stiffer on a car with shorter springs.
You can just fit the shorter springs (that's what I did).
  Astra J manual – pedal box gone? pretty expensive! Mr Writer 5 16,776 9:th-Sep-2021, 14:27:28
Last Post: Gav-Astra
  weird motor sound Astra J 1.4 turbo oliv.cleiton 2 4,906 18:th-Jul-2021, 08:17:49
  Astra A17DTF - Timing Belt or Chain? everson38 1 4,094 17:th-Jun-2021, 12:03:07
  Astra j mirrors Kiel0777 2 4,072 15:th-Apr-2021, 20:34:53
Last Post: Kiel0777
  Astra won't start after some sensor cleaning? momoomar 2 6,435 3:rd-Oct-2020, 02:04:44
Last Post: momoomar
  Astra J 1.6 A16XER (115 hp) 2010 Outer Belt (and perhaps Timing Belt, too Acond 1 7,204 14:th-Aug-2020, 14:35:21
  Changing Rear Shock Absorbers. Astra-J Hatch. Replace or reuse bottom bolts? Big Dave2 5 12,037 22:nd-Jun-2020, 11:35:40
  Astra J 2011 1.7Cdti Juddering in higher gears Mark72 6 10,293 10:th-Jun-2020, 10:08:54
Last Post: Mark72
  Astra 2.0cdti dpf regen info? Boroboy 19 34,084 5:th-May-2020, 14:22:14
Last Post: Kiel0777
  2013 Astra J SRI Galway11 2 6,347 29:th-Jun-2019, 20:20:47
3 User(s) read this thread:
Rusty2009 (19:th-Apr-2025, 19:19:09), Big Dave2 (22:nd-Apr-2025, 11:32:26), obsidian (24:th-Jul-2025, 17:51:05)
