sound whirring na 4 1
1.4 na whirring sound
Exclamation
I have a 1.4 na with 40k on the clock, today on the way home it was  making this whirring type sound at a standstill , with a slight rev the sound will go, the sound seems to be coming from the drivers side of the engine bay, belt seems fine, steering is fine. Any ideas?
Vvt pulley?
Water pump?
(31:st-Dec-2020, 08:42:10)Jpbroad1970 Wrote: Vvt pulley?
Water pump?
Its more of a whirring whine, disappears if i give the engine a slight rev.
Surley either of those would get progressively louder while revving?
Tight or worn aux belt, may be worth an audio clip.
I know aux belts can make some strange noises
(31:st-Dec-2020, 14:24:29)Jpbroad1970 Wrote: Tight or worn aux belt, may be worth an audio clip.
Ive dialed  it down to the aux belt, sprayed some water on it andthe sound went, orderd a new belt so ill be changing it soon
  Engine sound Lukedent1234 0 5,269 18:th-Sep-2017, 09:26:28
Last Post: Lukedent1234
  Whirring noise richje100 13 24,141 20:th-Mar-2016, 15:32:00
Last Post: Jj0063
dread123 (4:th-Mar-2026, 20:00:07)
