deadlock working not
Deadlock not working
Hello friends.
My car is not deadlocking. Already changed the drivers door lock and the relay kr97, in the rear fusebox.
Any ideas ? Thank you
i forgot to say that it is a 3 door gtc
found the problem. it can be closed. thank you
Was going to say on one I had it there was corroded pin on the rear fuse board causing the issue.
What was the issue you found?
Hello rusty. The rear fuseboard was not the problem. I have changed it recently.
The problem is that my car hasn't the deadlock door locks. I could sware i have done it already but i have checked the epc with my vin and my door locks don't support it. I will change them for deadlock capable ones.
I assume any programing is required once in gds2 it is possible to simulate deadlock right? Thank you
GDS2 can do the testing testing yes.
But any programming would need SPS. I would have to look into the calibration files to see if there is a difference & also the wiring.
Ok rusty, thank you. Appreciated. I will do some research too..
Enviado do meu SM-T580 através do Tapatalk
  Electronic handbrake not working Euroshopper 3 4,072 29:th-Jul-2021, 15:21:44
  Electric passenger window not working Harposaurus 2 5,711 30:th-Sep-2020, 19:29:35
Last Post: Harposaurus
  Sat nav unit, from insignia? Not fully working? Macauleyh96 10 9,708 18:th-Aug-2020, 14:40:41
Last Post: DNT
  service parking assist and tpms not working kevinmcken1404 3 6,031 18:th-May-2020, 10:09:32
  Cruise control not working raimon 10 29,812 27:th-Nov-2017, 12:33:46
Last Post: AlanMac
  Astra gtc wiper and start stop not working Robbjp 5 9,715 24:th-Sep-2016, 21:09:32
Last Post: J1ODYA
