to buick encore 950 retrofit navi
Navi 950 retrofit to Buick Encore
Hello everybody,
I installed the navi 950 in the Buick encore, reprogrammed the EEPROM with the Buick encore VIN and everything went great (head unit works fine). After leaving the car locked for a while and turning on the head unit again, there is no sound at all even turning signals or open door sounds dissapear.
Can anyone help to solve this problem?
Which pin on navi 950 turns on the factory amplifier?
And how to enable if not activated?
I found a temporary solution, pulled out pin37 (amplifier control) from connector A11 X2 and the sound came on.The question remains how to invert the amplifier control signal in navi950?(Now is when the head unit is on pin37 5v, when off 0v.)
The radio needs to be programmed properly so it knows it has UQA.
  cd 400 upgrade to navi 600 need help goose9029 6 9,936 14:th-Feb-2024, 07:52:16
  Digital cluster (virtual cockpit) retrofit milozic 5 12,644 30:th-Apr-2023, 19:51:49
Last Post: milozic
  Navi950 DAB+ retrofit help milozic 1 8,306 8:th-Sep-2021, 21:22:59
  Steering wheel remote control retrofit EricMod 32 38,923 10:th-Jul-2021, 12:37:38
Last Post: carolef1984
  vin relearn navi 600 geoffp 1 3,932 5:th-Jul-2021, 15:38:22
Last Post: livo
  Navi 650 bluetooth and reverse camera mislav_os 30 36,961 9:th-Jun-2021, 16:08:07
  Lane departure retrofit? toxx 3 8,931 22:nd-Feb-2021, 09:16:29
  Auto Lights and Bluetooth Retrofit kalum0101 5 13,783 2:nd-Aug-2020, 13:48:24
Last Post: kalum0101
  navi 500 programming tzr608 14 21,921 15:th-Mar-2020, 23:15:54
  Retrofit 12v sockets Rusty2009 7 23,268 15:th-Mar-2019, 09:21:09
