Threads: 2
Car: Astra 2012 Reg
29:th-Jun-2020, 15:22:31
(This post was last modified: 29:th-Jun-2020, 16:17:20 by pawex.)
Hi guys I got 2015 Astra GTC 2.0 ,
I have upgraded my radio to android head unit , originally I had cd400 plus with dab and usb ,
I know would like to use my existing shark fin antenna to plug in the dab in to my headunit ,when I took my old cd400 unit I didn't find any Dab connector there or anything there was is standard FM antenna ? I have searched the forums and found that there should be a seperate box for the dab and usb unit ,could any one confirm they actually exist and where about are they located ?
Wysłane z mojego SM-N976B przy użyciu Tapatalka
Threads: 10
3
the dab unit is located to the right of the steering column (on a UK car)
If i remember correctly there is a little drop down coin tray that you can remove to see the dab unit.
Thanks Received: 5 in 5 posts
70
Your shark-fin isn't DAB it's just a dummy.
You DAB aerial will run from the window, but yes you can use it for you DAB on aftermarket radios.
Most aftermarket radios have an MALE SMB for DAB some are screw type some are just push on link to one (you would have to check the connection on the radio side).
https://www.ebay.co.uk/itm/RG174-Fakra-Z...SwDlda4C4G
Threads: 2
Car: Astra 2012 Reg
Thanks guys for your help I have managed to find all the bits I need yeasterday already ,should be here tomorrow ,
Hopefully if all works good
Threads: 2
Car: Astra 2012 Reg
Do you guys know which one of them its the dab connector from rear window ?
70
Be the blue one.
Threads: 2
Car: Astra 2012 Reg
I tried both and strangely when I stand still signal it's really good but when I start driving it keeps braking and it's basically unusable I was really hoping I will not have to upgrade my antenna ...
70
(3:rd-Jul-2020, 12:38:53)pawex Wrote: I tried both and strangely when I stand still signal it's really good but when I start driving it keeps braking and it's basically unusable I was really hoping I will not have to upgrade my antenna ...
I always go from the point of DAB module, never had a customer complain, even used the cheap windscreen stick on one and fix it passenger side without any issues when I do DAB retrofits.
Threads: 2
Car: Astra 2012 Reg
Thanks rusty for all your help , could you please tell me where did you plug then ? Any pics of anything ?
Would really appreciate that
Bellow picture where I plugged
Threads: 0
Car: Zafira Tourer
Sex: Undisclosed
Sorry to partially hijack your thread but my question on the exact same topic. I'm about to purchase a Sony AX3005DB, the connections for which are shown on the following image...
https://www.compare360.co.uk/wp-content/...3605c.jpeg
Would I be correct in thinking that I can take the DAB aerial connection out of the existing DAB module, and then connect it via some kind of Fakra to SMB adapter into the DAB aerial connection shown hanging out of the back of the Sony? If that is correct, could somebody kindly give me a pointer on the adapter required, and the location of the DAB module on a Zaf Tourer? Thanks so much
70
(3:rd-Jul-2020, 12:58:45)pawex Wrote: Thanks rusty for all your help , could you please tell me where did you plug then ? Any pics of anything ?
Bellow picture where I plugged ![[Image: 6bd263fbce7c1b02caf9fa73f1d17a89.jpg]](https://uploads.tapatalk-cdn.com/20200703/6bd263fbce7c1b02caf9fa73f1d17a89.jpg)
The factory DAB module sits up on the main bar up behind the headlight switch, (remove the pocket under the headlight switch for better view). take the aerial off the DAB module and connect to that Fakra.
70
(3:rd-Jul-2020, 14:53:11)Graeme1978 Wrote: Sorry to partially hijack your thread but my question on the exact same topic. I'm about to purchase a Sony AX3005DB, the connections for which are shown on the following image...
Yes this cable.
Threads: 2
Car: Astra 2012 Reg
Rusty when I unplug the cable from the dab module it was a connector like this ? But you mean there is annother fakra connector yeah ?
Threads: 2
Car: Astra 2012 Reg
Strange as I get good signal when in standing still soon as I start moving it's dropping the way down
70
I'm on about the fakra connection on the DAB module.
Threads: 2
Car: Astra 2012 Reg
I have tried that and nothing helps it's really strange issue I got there as it doesent matter where I I get full signal on most stations if standing still soon as I start driving it drops all the way down ... Any idea what it could be ?
70
Did the factory DAB work ok?
Threads: 2
Car: Astra 2012 Reg
13:th-Jul-2020, 13:31:06
(This post was last modified: 13:th-Jul-2020, 14:49:31 by pawex.)
Hi yes it worked spot on I travel from Peterborough to Southampton , there were some roads clousers etc , so I had to go through small villages etc and literally been spot on all the time never dropped a signal at all , is it possible that the dab antenna it's also amplified when it goes through the dab box ? You said you connected by the dab box ?this is where I plugged ,directly by the box I only found the green connector ,I'm pretty sure it's got to be something with the wiring as it worked really well on cd400.
![[Image: e3686452f55cd8b3c8341756541be7e9.jpg]](https://uploads.tapatalk-cdn.com/20200713/e3686452f55cd8b3c8341756541be7e9.jpg)
70
Out of them 2 the black is AM/AM blue is DAB.
I used the green plug off the dab module in your 2nd pic.
Yes the DAB module does apply some power to amplify it, but most aftermarket DAB units to also sometimes there is a setting.
Threads: 2
Car: Astra 2012 Reg
Thanks Rusty thats good to know I try pluging it directly off the dab module and see if that helps at all  also I don't seen that option in my android headunit .
