coolant level
Coolant level
I have a astra j 2.0 cdti elite does it Come With coolant level sensor as standard?
I 've got an SE version of the same motor and last year a warning came up on the display showing the coolant level was a bit low, so based on that I would assume the Elite spec will probably have one.
OK thanks for that
  Engine oil level low ,Add oil Rocky33 0 3,683 14:th-Apr-2021, 12:56:53
Last Post: Rocky33
  Coolant pump 1.7 96kw? alexandrufalfan 6 8,250 9:th-Mar-2020, 13:30:03
Last Post: alexandrufalfan
