wiring info
wiring info
Hi, does anybody know how the electric vacuum pump (for the brakes) is wired?
there are 2 wires (Red and Black) from the pump which go to a large connector block with 3 wires
what does the 3rd wire do?
I'd guess that red and black are live feed and earth, so is the "connector block" actually a relay and the third wire a trigger feed?
a wiring diagram may help if anyone has one.
the parts catalogue I've looked at shows the connector block coming with the pump assy
[Image: 247953.png]
many thanx
I'll see what I can find later on TIS.
Hi thanks to Rusty for the diagrams, a lot to download but it seems that my assumptions were correct, the unit needs a 12v feed and an earth connection, the 3rd wire is a trigger to make the pump work, so I've wired this to a brake light switch so the pump operates when pedal depressed.
Oh it's not being fitted on a J in case you wondered, it's going on an old car without servo brakes, the J vac pump was the cheapest way to get vacuum for the retro fit servo without tapping into the manifold.
  vxdiag info Maniacu 7 10,460 6:th-Jun-2019, 07:23:11
  Technical (electrical?) info needed for the DVD800 radio and HVAC control panel i.rosca 1 12,065 22:nd-Jan-2019, 09:51:25
  Wiring diagram Badenj 1 5,590 19:th-Oct-2018, 11:16:07
  Wiring Diagram [Internal Lights] cubez0 3 7,363 25:th-Jun-2018, 11:28:03
  Caliper Info tommyboy1289 1 7,247 13:th-Apr-2017, 22:15:00
  Need info on bulbs or links please :) Kris 34 32,191 13:th-Jan-2016, 19:38:38
Last Post: cornishtaz
  Door loom pin info req'd cornishtaz 5 8,779 4:th-Apr-2015, 23:07:16
  Torque setting info Cameron UK 3 7,714 24:th-Jul-2014, 16:43:47
