dpf sensor pressure
DPF pressure sensor
Hi all, newbe here so apologies if this has been asked before.
Im going to replace my DPF pressure sensor on my 2011 Astra J 2.0cdti  A20DTH engine.
Does the new sensor need to be learned in by the car or is it a straight swap?
Whats the best sensor to get, ie Bosch? or genuine GM etc.  Anyone got link they can reply with?
P.S Is AutoVaux recommended for parts?
Cheers guys
Yes the new sensor needs to learned.
As for parts I would advise genuine. Yes Autovaux is recommend for parts but always check with your local dealer as sometimes they do come in cheaper.
Many Thanks for that.
Hi I just want to know what the small pipe on the bottom of the air box is for?
  Brake pedal sensor learn. Richiew1986 0 2,729 22:nd-Jul-2021, 16:53:31
Last Post: Richiew1986
  coolant pressure tester chuzzle359 0 3,106 14:th-Apr-2021, 18:23:08
Last Post: chuzzle359
  parking sensor Qaranc 1 3,572 8:th-Feb-2021, 01:33:43
Last Post: loeb
  Coolant light coming on when coolant is full (new sensor and no leaks) baffling me! Brasseyebaby 3 7,331 2:nd-Feb-2021, 21:12:47
  Glowplugs with pressure sensor or not Euroshopper 3 5,143 2:nd-Nov-2020, 16:01:21
  Tyre Pressure Warning Niggle phlyer 4 7,414 23:rd-Mar-2019, 11:39:36
Last Post: andyp
  Parking sensor Mspencer 2 4,706 19:th-Dec-2017, 17:34:12
  A/C pressure sensor location scotchmist67 0 4,018 2:nd-Aug-2017, 10:04:34
Last Post: scotchmist67
  Climate control sensor SectorOMEGA 4 6,052 22:nd-Jul-2017, 08:35:22
  Rain Sensor/Light Sensor Rymaan82 10 12,946 1:st-Oct-2016, 18:16:54
Last Post: Rymaan82
Rusty2009 (6:th-Mar-2025, 17:55:41)
