light help engine
Help engine light
Hope i dont need a new cat it do 57k 1.4na [Image: ae75040f6a0750cea3fa226ef4da2455.jpg]
I’d clear the code, run it for a day and then re-scan it to see if it comes back. If so then take it to a garage for further diagnosis. My Torque app was showing an EGR error but when I took it to the garage it didn’t show on there machine so I don’t trust it.
Will do but the engine light is on. On the dash
Will my op-com tell me a better read out
Yeah your op-com should be fine, I’ve just ordered one myself
What did you get back from the op-com?
Same thing mate cat but when i when to the garage the fella told me it could just be the sensor that is at fault witch would be cheaper than a cat and explains why im using alot more fuel
Fingers crossed ?? it’s a cheap fix.
Hope so mate mot due this month
Well car past MOT with no advisories.
Glad its defo not the cat that need changing
(17:th-Mar-2018, 20:09:54)Mspencer Wrote: Well car past MOT with no advisories.
What was causing the engine light to come on?
They took the sensor out and cleaned it up and it been fine ever since so just dirty fuel they think
(18:th-Mar-2018, 16:26:26)Mspencer Wrote: They took the sensor out and cleaned it up and it been fine ever since so just dirty fuel they think
Nice cheap fix then
Yep
  1.4T Engine noise Nathan191210 1 3,552 29:th-Jun-2021, 09:05:07
Last Post: jay2801
  Please advise - Z16LET engine (1.6 turbo, 132 kW) - is it a direct or indirect port? UseThe4s 2 7,454 18:th-Apr-2021, 09:58:47
Last Post: UseThe4s
  Coolant light coming on when coolant is full (new sensor and no leaks) baffling me! Brasseyebaby 3 7,392 2:nd-Feb-2021, 21:12:47
  "Stop Vehicle Immediately Engine Has Overheated" Advice appreciated please Dennis S 25 52,865 30:th-Aug-2020, 13:56:18
Last Post: Rgotts00
  1.6 cdti engine reliability Loddy Jeff 7 19,434 9:th-Jul-2020, 22:04:47
Last Post: Loddy Jeff
  DPF REGEN LIGHT Starie 113 138,819 19:th-Apr-2020, 21:00:20
Last Post: Multiskilled
Shocked Spanner Light illuminated with engine off Wwood1991 2 5,488 11:th-Feb-2020, 13:01:57
  New Engine Needed ? Breengin 19 14,075 14:th-Mar-2019, 08:48:57
  Squeek/Rattle when starting engine Wabe_IV 4 6,194 7:th-Feb-2019, 12:15:33
  Noise when turning engine off Marc_81 6 8,753 30:th-Jan-2019, 20:46:28
Last Post: Marc_81
