install sub
Sub Install
Recently got a 1.7 CDTi (12 plate, it's my first car!) and just installed a new Android 7.1.2 Head unit from icebox - all good so far apart from AUX and USB not working (no connection provided that will work with factory USB, Rob looking into it for me)
Just a couple of questions, apologies if they are answered somewhere!
Has anyone installed a Sub & Amp and if so, how did you route the wiring?
Also, to anyone who has purchased a DAB module, where did you locate the aerial?
Sub wiring I can help you as my car is in bits as I remove the AMP wiring.
I'll grab some pics for you.
(25:th-Jul-2017, 07:21:43)Rusty2009 Wrote: Sub wiring I can help you as my car is in bits as I remove the AMP wiring.
That would be awesome, thanks.
For anyone interested, the unit I got is this one - heard back from Rob and unfortunately the USB and AUX connections won't work with this model (no biggie, it does have a MicroSD slot). There is also a problem with FM reception, this apparently may be down to a powered FM Amp that's not getting switched on, so could be fixed if needed.
If anyone is an XDA visitor, it's a MTCD MX V2.55_1, can't find much about Android 7.1.2 on there yet, it seems to be pretty new, but if anyone wants any more info just shout! Time to get my new wheels on, managed to get a set of 20' Limited Edition wheels  Hyper
what's happening with yours?
(25:th-Jul-2017, 22:32:18)zzattack Wrote: what's happening with yours?
Mine I'm installing the infinity sound system got the dash out etc as I need to make all the wiring changes.
I saw the infinity system mentioned somewhere, I thought it would just be up-rated speakers or something Shifty what have you got to do wiring wise?
Need to run all new wires from the radio plug to AMP.
Then from the AMP to the speakers.
Once that's done swap speakers for the better quality ones.
[Image: 1.JPG]
[Image: 2.JPG]
[Image: 3.JPG]
[Image: 4.JPG]
well damn, I'm not afraid to take some ***** apart but that looks scary
good luck
Yeah that
I was just thinking of running RCA's and power down the side with an active sub... any pointers on how to take inside trim off from the sides, will it just all 'unclip' or are there hidden screws about the place?
would love to see your final install once you get finished up for sure!
They unclip. Do make sure not to run the power wiring for your active sub near the signal wiring, you'll be guaranteed alternator whine if you do.
(3:rd-Aug-2017, 09:42:37)zzattack Wrote: They unclip. Do make sure not to run the power wiring for your active sub near the signal wiring, you'll be guaranteed alternator whine if you do.
Check. made that mistake years back Looney
I have got it in, ran the power down left side, and RCA and Amp remote wire down centre, not ideal as wires exposed between centre console and back seat, I am thinking re-route centre wires over to right side and hide in sill, I think leads are long enough, any other suggestions welcome Wink
Took a ground from one of the rear seat bolts, no interference, so all good so far.
Nothing exciting, just a cheap Sub from Amazon, it's on about 50% gain and loud enough not to be irritating Wink
  How to Install aftermarket head unit Rusty2009 55 81,954 14:th-Mar-2021, 15:16:56
Last Post: GTC-Nut
  CD400 buttons not working Android head unit install mephisto 4 11,806 27:th-Oct-2019, 17:30:00
Last Post: mephisto
  How to Install Android Head Unit + Wireless Reverse Camera sheppy1 64 67,425 9:th-Jan-2019, 15:07:53
Last Post: Shorty5
Question Android Auto Install Marek 3 10,694 4:th-Aug-2018, 07:47:17
  Tablet install..... millsy417 0 3,983 7:th-Jul-2017, 19:44:13
Last Post: millsy417
  M072 (S160) Android Head Unit Install/Info sheppy1 654 532,207 21:st-May-2017, 12:55:12
  How to install Sat Nav to a safe location grahamfromoldham 4 9,230 25:th-Mar-2015, 22:00:21
