How To Fit Sub To CD400 Head Unit
Today I made it my mission to fit my Fli 12" subwoofer into my Astra.
Tools you will need:
Speaker to RCA converter: £6.99 from eBay. I suggest this one as it fits snug behind the CD unit: HERE (see photo below)
[align=center]Screwdriver set (a few siz
How to fit sub and amp to cd400
Hi I'm after some advice to how I go a out wiring a sub and amp to my new car in getting.... as much help would be amazing along with simple Instructions as I'm a bit of an amateur but I think it's so getting I could do with your help xx
Sub Install
Recently got a 1.7 CDTi (12 plate, it's my first car!) and just installed a new Android 7.1.2 Head unit from icebox - all good so far apart from AUX and USB not working (no connection provided that will work with factory USB, Rob looking into it for me)
Just a couple of questions, apologies if they are answered somewhere!
Has anyone installed a Sub & Amp and if so, how did you route the wiring?
Also, to anyone who has purchased a DAB module, where did you locate the aerial
sub amp
im thinking of fitting a sub/amp, the main power wire needs to connect to the battery (+)
can any one tell me if there is any where in side the car I can connect to.
