led lights fitted warning now bulb rear issues
Fitted rear led lights, now bulb warning issues
So i have bought a new GTC, it came with no led rear lens, so got the dealer to order and fit them. Now he says it throws up rear bulb light failure display on the dash. Pressing the button on the steering wheel stalk turns of the issue warnings. can live with that , but is there a way to eliminate this, a guy told me you can go into the ecu and change the settings in the codes menu.
The dealer may need to apply for a VCI from GM for this.
I've not had one in so I can't comment on if there is a drop down option or not.
Or buy HappyBlue module and turn bulb warnings off.
http://www.happylightshow.com/happyblue/happyblue.html
(29:th-Jun-2017, 07:40:27)Rusty2009 Wrote: The dealer may need to apply for a VCI from GM for this.
It requires a VCI code for getting the LED rearlight coded.
I booked for the coding when I had mounted the LED rear lights. But technician came to me and said they could not code it without VCI code, which was 50£ to require and even is code were ordered, he were not sure he could code it anyway..
I didn´t go further as I have the HappyBlue module and simply switched the bulb warnings off.
  Astra 1.6 CDTi Turbo Issues P2598 shaky411 1 7,656 12:th-Sep-2021, 15:24:05
  Lowering springs identify front rear martinpe68 1 4,159 12:th-Sep-2021, 15:22:37
  Astra J Rear Bench Seat Clip. MrScottyMan 1 7,162 24:th-Jan-2021, 14:44:22
  Check Number Plate Lamp Warning mp21 10 16,065 10:th-Nov-2020, 23:33:17
Last Post: Galway11
  remote issues Qaranc 5 5,568 20:th-Oct-2020, 08:28:26
Question Blower issues Abc 9 9,791 14:th-Oct-2020, 13:29:13
  Rear diffuser Elad1962 3 5,262 29:th-Sep-2020, 22:14:18
  I bought a used GTC! - Fantastic car but a few issues i could do with advice about Mattymush 5 9,068 12:th-Jul-2020, 07:45:59
  BiTurbo Rear Bumper Dudderz 3 6,899 5:th-Jun-2020, 19:49:44
  Rear Bumper PN 13346637 Jonnymac07 1 4,030 13:th-May-2020, 14:56:05
Last Post: paula9568
