problem starting intermittend
Intermittend starting problem
I own an astra J 1.4 turbo (A14NET, bifuel, 40XXX km) and having some intermittent starting problems for a few weeks now. The problem is an extended cranking time, altough it doesn't always occur. Sometimes it starts up perfectly fine from the first crank, sometimes it coughs into life and sometimes it takes 5-6 cranks to start. Ones started up, it runs perfectly.
Already checked fuel pressures (perfect, no big drops), plugs are fine as well (changed 8 months ago). Fuel pressure regulator is fine as well.
Thinking it could be following things:
Coil pack or Camshaft/crankshaft position sensor. Is there anyone who what this issue as well? The weird thing is that it's intermittent, which makes me believe that it's no CPS. No fault codes stored as well.
Anyone who has an idea how to test/diagnose this or what could be the problem? Car is services regularly (every 10k km) and runs fine otherwise.
Many thanks,
Elias
Hows the battery? I know with mine if low it takes longer to crank over could be worth a test.
I think it's okay, but not really sure how i can measure that? It's still the original battery (from 2013). Voltage goed from 12.0-12.4 when not being charged to 14+ when charging. Charging is not continious when driving, noticed alternator sometimes doenst charge. Does it have an electronic clutch and only engages when voltage drops below certain level?
Sad Astra 1.7 CDTI fuel quality problem klajdi 0 3,836 10:th-Sep-2020, 12:10:05
Last Post: klajdi
  Injectors or SCV problem? kartush45 1 4,614 11:th-Mar-2020, 11:08:58
  Electric Window intermittent problem Stanhope 3 6,917 21:st-Mar-2019, 14:35:49
Last Post: Stanhope
  Astra J self starting problem Jopo2311 8 7,857 16:th-Mar-2019, 10:29:33
  Squeek/Rattle when starting engine Wabe_IV 4 6,150 7:th-Feb-2019, 12:15:33
  Astra J 2012 1.3cdti Starting Issues lordmpl 4 8,020 13:th-Jan-2019, 10:06:13
Last Post: lordmpl
  Help-2012 Astra J S model rear window demister button problem irishastraowner 14 18,112 26:th-Sep-2018, 23:50:59
Last Post: everson38
  Can't get in gear - clutch problem? klargon 0 4,839 9:th-Dec-2017, 16:21:11
Last Post: klargon
  Problem with DRL mw2299 5 6,836 21:st-Sep-2017, 07:25:38
Last Post: andiman t
  Intermittent starting issue? Boroboy 10 11,018 15:th-May-2017, 07:08:44
