Shauny - Replies:
Starting issue astra j 2010 1.7 cdti
Hi could anybody help with my astra j starting issue.it starts very intermittantly when engine is warm will not start at all. Runs very well when aventually does start. I have changed glow plugs, fuel filter, but cant locate the fuel pump to see if that is an issue.had it to the dealer and they want to do a process of alimination which i cant afford...any ideas please help. Thanks shaun
Car starting issues
This morning I went to start the car as usual but all I got was a click tried a few more times and eventually it started however I had no lights on my radio even when lights were switched on I pressed the radio button and all was fine!I have changed the battery and starter motor last year as was having problems.but this is out of the blue?!
Not Starting on first turn and Service Theft Deterrent System
Hi Guys,
Need your help folks.
A month or so ago, I was getting a random "Service Theft Deterrent System" message coming up randomly and my start/stop wasnt working.
So googled it and everything pointed towards a dodgy battery, especially as the start/stop want working.
Anyway, I replaced the battery for another good second hand one and low & behold, the start/stop started working so that nailed that S/S problem. However randomly I was still getting a "Service Theft Deterrent System"
Intermittent starting issue?
I've owned my 63 plate 2.0cdti elite auto for around a year now, this being my 4th J.
Anyway for around a year now this one has suffered from a very intermittent starting prob.
I went to start the car today, as you do. Just before setting off to work. Sat in my car, gearstick within the parked position (being an auto), turned ignition key on to start it, nothing. Turned key off, then back on again, but within the on, not starting position. Clocks did their checks, turned it on, nothing again. Tu
Intermittend starting problem
I own an astra J 1.4 turbo (A14NET, bifuel, 40XXX km) and having some intermittent starting problems for a few weeks now. The problem is an extended cranking time, altough it doesn't always occur. Sometimes it starts up perfectly fine from the first crank, sometimes it coughs into life and sometimes it takes 5-6 cranks to start. Ones started up, it runs perfectly.
Already checked fuel pressures (perfect, no big drops), plugs are fine as well (changed 8 months ago). Fuel pressure regu
Meriva B 1.7 A17DTS (130) Weird Starting thing
Car is the Meriva B 1.7CDTI the 130bhp model, been faultless pretty much, had a new battery a few months ago, Anyway its been coming up with the service vehicle soon message every now and again, but i gather that is for fault codes to be read? it doesn't show up all the time...
Anyway this morning i was out taking pictures somewhere, had driven there engine had been up to temperature and that before i arrived. Put the key in the Ignition had the radio on for 5 mins went to start a
lordmpl - Replies:
Astra J 2012 1.3cdti Starting Issues
I have a 2012 Astra J 1.3 CDTi, only had the car for 6 weeks now, when i went to view it it was fine, started fine was in really good condition in and out so decided to purchase it.
The next morning it took ages to start and when it eventually did was a bit chuggy till it warmed up.
I took it too a mechanic who said there were 3 codes which related to glowplug 1,2 and 3, so i had him change all four. After having this done, it was fine for about 10 days now seem to have gone back to
Wabe_IV - Replies:
Squeek/Rattle when starting engine
Morning all, wondering if somebody could please shed some light
Had my car sitting at work for 9 hours yesterday and when I started it I heard a 2 second ish rattle/squeek which I'm unaware of and this has never happened before. I turned the car off and on again but didn't hear it again. Around 10pm last night I had to move my car, so turned it on after it been sitting with no movement for 5 hours, cold engine but heard nothing. Then again this morning I heard the squeek/rattle again
Any i
Astra J self starting problem
Hi guys,i have astra j 1.7 110hp and when i turn off the car i pull the key out and put it back in half way ,so the radio can shut off. But few days ago i noticed when i put the key back in ,my car wants to start by itself and press clutch light is blinking,today i was accidentaly holding the clutch and car just started and then shut off by itself,anyone knows what could be the problem?
Thanks.
Starting my GTC
Hi all. New to the forum, just starting to take the first steps into modding / upgrading my 2013 GTC 1.4T.
Owned the car almost a year, but not really been the year to start with the dreaded C virus!
Ordered the Racechip GTS to get me up and running. Trying to work on performance alongside looks. Will likely setup an Insta for the transformation.
Nice to meet you all!
