issue coolant
coolant issue
Evening guys,
Ive been keeping an eye on my expansion tank for a while but yesterday I went to the the kids to nursery and was prompted with a low coolant level warning. So i checked to see where it was at and there was just under half when I always keep my tank topped up.
I took the cap off and started the car to see if there was perhaps an air lock in the system. Ran the car for about 10 minutes and held it at 2000 rpm for about 2 minutes. The level returned to normal.
Checked it again today and the level had dropped again. there is no staining around the water pump and I cant see any wet patches on the ground or in the engine bay. The car is not over heating and still runs smooth however I have noticed a small amount of bubbling coming through the return pipe back into the expansion tank.
Any ideas???
Update:
Went out this morning to have a good look over the car.
[Image: 20161106_113719_zpsj8gmcvly.jpg]
The bubbles were appearing in the top return hose when the cap was off while the system was bled. Bubbles have now stopped when the cap is.
Pulled the oil cap off and spotted some mayo on the cap and instantly thought the worst  given the fact that coolant was going missing.
[Image: 20161106_114050_zps2jpithh8.jpg]
Me being me went into fault find mode and took the rocker cover off.
[Image: 20161106_124110_zpst79nndak.jpg]
[Image: 20161106_124132_zpsqnn6mf7z.jpg]
No mayo in the cams or anywhere else. Just a little bit in the rocker cover which is fairly typical of vauxhall engines. No mayo on the dipstick either. Glad its not the head.
What I did find was a really small crack in the expansion tank though  Wtf
[Image: 20161106_131758_zps7icenzad.jpg]
Lets hope that is the issue
Where is the coolant full/ low lark i.e is mine low, I've put a couple of guess lines in?
[Image: 5f42e67983135f4c9829c3c2a9a0cf52.png]
yeah thats it mate. You get a warning if your coolant gets low and you should always top it up when its cold too.
(8:th-Jan-2017, 19:19:20)Shorty S91 Wrote: yeah thats it mate. You get a warning if your coolant gets low and you should always top it up when its cold too.
Cheers mate ;-)
  2010 Astra J - Cooling Fan issue Madal101_uk 3 883 19:th-Dec-2024, 22:04:08
Last Post: Madal101_uk
  Gear Knob issue (Automatic 2014 Astra GTC) DC23 1 6,456 22:nd-Feb-2021, 08:08:37
  Another blower issue.. Zcubed 25 19,198 4:th-Jul-2020, 13:19:48
Photo Bleeding coolant liquid pipe kebagwan 3 3,646 22:nd-Sep-2019, 07:04:31
  Engine Coolant and remote locking dm1996 1 4,336 14:th-Nov-2018, 10:19:53
  Drl issue Daniel199025 4 6,675 8:th-Sep-2017, 15:13:49
Last Post: stigeye
  GTC Coolant temp sensor chris_yorks 2 5,546 11:th-Jul-2017, 07:38:42
  Blower issue Lewis6317 61 52,258 13:th-Apr-2017, 09:26:59
Last Post: Jerry
  Black filter/cap under coolant cap won't budge ellis0896 7 7,653 18:th-Jan-2017, 20:32:15
  Airflow issue? Dookified 5 10,057 30:th-Oct-2016, 19:43:44
Last Post: Dookified
Jordan_Sparkes (5:th-Mar-2025, 00:48:59)
