to led stereo conversion and console centre how
How-to Stereo and centre console LED conversion
[Image: vx.o.c.jpeg]
This is How-to for changing the LEDs in the stereo and centre console switches
Tools required
Stubby Philips s/driver
Small flat blade s/driver
7mm socket
T8 driver
Fine tip soldering iron
Qty 30 805 smd leds for stereo
Start by removing the following parts. 1. Rubber mat 2. Plastic cover 3. Gear gaiter
[Image: 1.JPG]
I removed the gear gaiter completely by pushing in the 2 black tabs and lifting the blue collar. You can remove the 2 screws holding the centre console surround, then remove the surround completely.
[Image: 2.JPG]
There a 4 7mm bolts to be removed
[Image: 3.JPG]
2 are located behind two flaps by the centre air vent
[Image: 4.JPG]
Disconnect the elec connectors circled in yellow, remove T8 screws circled in red and remove the stereo buttons from the housing
[Image: 5.JPG]
Remove the 2 T8 screws marked blue in above pic and unclip front panel from 2 small tabs
[Image: 6.JPG]
Remove knobs and rubber cover to expose the circuit board
[Image: 7.JPG]
[Image: 8.JPG]
Tabs for removing TC/Eco/Park assist Switches 1 at each end of the switch
[Image: 9.JPG]
Carefully remove the label and remove switch back unclipping 4 tabs
[Image: 10.JPG]
Replace the lower 805 smd led
[Image: 11.JPG]
Remove 2 7mm bolts holding stereo and display surround
[Image: 12.JPG]
Remove the switch electrical connectors
[Image: 13.JPG]
Door lock switch assembly
[Image: 14.JPG]
Remove the rear of the switch assembly
[Image: 15.JPG]
Qty 2 PLCC-2 leds required(lefthand 2)
[Image: 16.JPG]
Switch led orientation
[Image: 17.JPG]
VXR/Sport led pcb
[Image: 18.JPG]
well done mate really looking forward to the final results Thumbs
Wow these conversions look hard but the end results make it worth it
Lewis6317 Wrote:Wow these conversions look hard but the end results make it worth it
Not too difficult just time consuming due to led size
Here is a image showing the positive and negative of the led's on a CD400 board
[Image: cd400.jpg]
  How-to Instrument Cluster LED Conversion Rusty2009 66 82,155 19:th-Sep-2020, 18:35:05
Last Post: fratiee
  Heater Panel LED Conversion cornishtaz 30 35,195 29:th-Oct-2017, 08:37:18
Last Post: umognog
  Various switch LED conversion cornishtaz 15 30,269 6:th-May-2016, 21:05:01
Last Post: cornishtaz
  Steering wheel Switch Conversion Rusty2009 1 13,911 27:th-Jul-2015, 10:09:53
obsidian (31:st-Aug-2025, 20:28:36), N0madd_builds (11:th-Mar-2026, 11:07:53)
