schematic needed diagram
Schematic Diagram needed
Good evening to all. Thanks for accepting me to your forum.
I have a problem with my Astra J and I need the radio/nav schematic manual.
I  cannot open the links for the schematics in this site:
http://workshop-manuals.com/vauxhall/ast...itle_page/
My problem is that randomly ( especially when the ambient temperature is rising - during summer for example) the RH speakers are producing a heavily distorted audio. This is irrespective of the audio source i.e. radio, cd, usb etc.
Since all rh speakers are affected I was thinking of a radio problem, but I saw that there is a separate speaker amplifier in place. I need the schematic in order to troubleshoot.
Thank you in advance
i would remove the door cards and check the speakers out first
(27:th-May-2016, 22:39:44)tucpal Wrote: i would remove the door cards and check the speakers out first
I am trying to check your thread for speakers replacement but the photos are not visible.
should be ok work for me there in the ice section now
https://www.vxoc.org.uk/forum/Thread-how...e-speakers
check the connections are ok they may be rusted bad but if i were you i would just replace them
The wiring diagrams are at the bottom of 1st post Tucpal linked you to, it's the same for all radios just depends if you have standard speaker system or infinity system.
Thank you all, I have found the diagram, still cannot see the pictures (don't know why, maybe because I am in UAE right now? ) I will try as soon as I go back home and post here the results. Thank you again.
  Technical (electrical?) info needed for the DVD800 radio and HVAC control panel i.rosca 1 10,899 22:nd-Jan-2019, 09:51:25
  Wiring diagram Badenj 1 4,953 19:th-Oct-2018, 11:16:07
  Wiring Diagram [Internal Lights] cubez0 3 6,543 25:th-Jun-2018, 11:28:03
  Part number needed Fmcnic 9 9,873 5:th-Oct-2014, 20:22:45
  How to needed Cameron UK 5 8,183 21:st-May-2014, 19:42:07
jas7c5-2008 (8:th-Feb-2025, 19:43:00)
